88 300z turbo injectors in a 94 maxima
Old Jun 5, 2004 | 07:30 PM
motomike40's Avatar
i saw for sale a set of 300z turbo injectors and i was wondering if they would fit directly into my 94 maxima. should i buy these? are they wort buying. thanks,
mike
Old Jun 5, 2004 | 08:38 PM
mtcookson's Avatar
i believe the later injectors should work (87-89) but unless you are going to turbocharge your car or put on a lot of bolt on mods causing you to run lean there is really no need for them.
Old Jun 5, 2004 | 08:39 PM
Nismo87SE's Avatar
They would fit only if you intend to use the 300z upper and lower intake manifolds. If you want turbo injectors get them from a 90-94 300zx TT if your VG or 95-96 TT if you have a VE.
Old Jun 6, 2004 | 06:41 AM
Ramius83
As Nismo stated, the VEs are identical to the 4th Gens injector wise. They would use the 95-96 300zx TT injectors, not the early model injectors from the late 80s. And if you have a VG, the 90-94 will fit.
Old Jun 10, 2004 | 08:13 PM
Maxpwer's Avatar
No turbo, no care!
[QUOTE=Ramius83]As Nismo stated, the VEs are identical to the 4th Gens injector wise. They would use the 95-96 300zx TT injectors, not the early model injectors from the late 80s. And if you have a VG, the 90-94 will fit.[/QUOTE
Actualy there is some misinformation here, there are two different style of injectors
Old style: 89-92 Maxima VG, 90-93 300ZX NA, 90-94 300ZX TT
New style: 93-94 Maxima VG, 92-94 VE, 94-96 300ZX NA, 95-96 300ZX TT
Im not too sure about the Z31 injectors, but since they are only 259cc/min why not just use the Z31s TT 370cc
Old Jun 13, 2004 | 03:28 PM
HowlerMonkey's Avatar
There are also two styles of Z31 injectors.
The early ones had top feed.
The 86 and later did not.
kjlouis
Nov 24, 2018 06:09 AM
Finkle
Sep 27, 2015 09:53 PM
Ray229Harris
Sep 16, 2015 08:16 PM
MAXSE5SPD
Aug 23, 2015 12:06 PM
Balkins
Aug 12, 2015 06:39 AM
