OIL (SC/TC guys)
Old Jun 17, 2004 | 02:00 PM
DonSupreme's Avatar
OIL (SC/TC guys)
Do you guys run synthetic oil? (Amisol or Mobil 1)
If you run synthetic how often do you guys change oil/filter?
Do the guidelines posted in the OIL, Fluid forum apply to our cars?
Old Jun 17, 2004 | 03:34 PM
hlh0501's Avatar
Mobil 1 synthetic @ 2500 miles..
turbos run at high temps and syn. oil holds up better
no point in risking an expensive turbo on a few dollars of oil
Old Jun 17, 2004 | 03:40 PM
maxlinegtr's Avatar
I also use synthetic...Mobile 1. I tried experimenting with the thicker stuff....15/50. What do you guys think. I am also experiencing the oil light flickering when I am at a stop. Think its too thick? or should I stay with the 10/40.
Old Jun 18, 2004 | 03:53 AM
Stephen Max's Avatar
10W-30 Mobil 1, changed every 3000 miles.
Old Jun 18, 2004 | 04:37 AM
DonSupreme's Avatar
So even though Synthetic is suppose to provide longer change interval you guys still change @ 2500 - 3000 miles?
Old Jun 18, 2004 | 06:39 AM
Yeah. Maybe it's overkill, but it makes me feel better about abusing the engine and SC when revving to 7200 rpm.
Old Jun 19, 2004 | 01:54 PM
VQ30DES's Avatar
(vortechpower) No question, mobile one 10w-30 is the only way to go. I change mine depending on my driving conditions like longer for a highway trip. I have pushed the limit to 5500 miles. Usually I change I go 3000-3500 miles.
Old Jun 19, 2004 | 02:18 PM
DonSupreme's Avatar
OOpps I just bought a case of 5w-30 instead of 10w-30. I guess I better return it!
So the general consensus here is to ignore the 8K + synthetic change interval due to the extra heat created by the SC, even though Mobil 1 costs $30.00 + per case?
P.S. Will it hurt to put the 5W-30 in the car with 100K miles on it?
Old Jun 19, 2004 | 09:22 PM
MaximaRider's Avatar
How about 15W-50?
Old Jun 19, 2004 | 10:22 PM
iansw's Avatar
I've been using 5w-30 Mobil 1 - change every 3k.
I wasn't aware others were using 10w-30. I overspin my blower to 56,000RPM with my 2.87" Pulley and 7200RPM limiter.
Never had a problem.
Should I possibly switch to 10w-30?
Old Jun 20, 2004 | 05:20 PM
JAY25's Avatar
Originally Posted by MaximaRider
How about 15W-50?
I started using that as of yesterday. That 15/50 rocks for this hot azzz weather. I am turboed so the oil has got to lub/cool. Lets see what the Dyno will be for this Thurs
Old Jun 22, 2004 | 06:41 AM
VQ30DES's Avatar
I found a 5 QT jug of mobile 1 for $18.99 @ walmart!!!! I have never seen it that cheap anywhere...
(vortechpower)
Cotozic
Jun 28, 2017 08:01 PM
MatthewsMaxima
Sep 11, 2015 03:21 AM
4 door GT-R
Aug 22, 2015 07:50 AM
maxipower
Aug 21, 2015 11:10 AM
maxinout93
Aug 20, 2015 02:17 AM
