550cc injectors
550cc injectors
I just got some 550's. Is there anyone running these with the Emanage. I have an ajustable fpr. I just want to know if I will have any problems running these? Thanks for the help.
There are a few people here running 550's and e-Manage without any problems as far as I know. Not sure about anyone with 550's without e-Manage or JWT ECU though. You'd really have to drop the pressure.
What do you need to get the Emanage working ?? I hear people gettin Diods from Radio shack for each Coil and some say its as easy as wiring an SAFC...is emanage easy to use once you install and get used to it or can only shops use it ?
I will be V1...3.125 pulley, cartech FMU, AEM FPR till next spring...then I need to decide if im gonna go with JWT program with 370's, or Emanage with 370's..what do you think
-matt
-matt
That's only for the ignition harness..
This should help a little..
http://forums.maxima.org/showthread....hlight=emanage
jmlee44
Oct 2, 2022 02:13 PM
