Have emmissions this month.
Just want to verify one more time...make sure I'm doing the right thing here.
Currently, in WA State if you have an ODBII type setup on your car (1996 and above) then they only scan your ECU for codes and that's all - they dont' do a pipe test.
So I need to pass emmissions - problem is I have a JWT ECU for running my 370cc Injectors and SC. I have a permanant unclearable 1005 code.
I've heard that I can put the stock ECU in and run on the 370cc Injectors if I unhook the SC and use a Z32 MAF instead of the A32 MAF.
This true? Does this work?
Or do I have to unhook the SC, re-install the stock injectors, and put the stock ECU back in to pass emmissions?
Originally Posted by desertmaxima
Sounds like too much effort for something unsure, dont ya know a person who knows a person if you know what i mean.
No way around it. I already have a Z32 MAF, so if that will work - then I'm good.
If not, I've got a good day or two of work ahead of me to pass emmissions.
Yea that does suck. See you should just move down to cali lol. Yea im not to sure how the emissions works out there. Here if you do it the right way as long as you dont throw a code and the guy who is doing the smog doesnt know the diff between MAF and whatever stuff and it can pass the sniffer then you are fine. One of my buddys went with a full B16 swap into his CRX and only prob was that he threw a code but he passed visual cause the mech didnt know the diff between a SOHC and DOHC honda motor. Good luck man Id hate to hear if you have to take yer car apart to put it to stock
So I just have to get it to where it won't throw a code...and runs somewhat normal - that's all.
worse case you'll be a little rich.
Originally Posted by Bags
You clear it it comes right back.
I have the same issue, different code
It's basically impossible to get 0505. This is the curse of being a 97 with a JWT ECU.
I can't just slap the stock ECU back in - I'm running 370cc Injectors and a SuperCharger with no FMU because the JWT controls that.
We need to dig up some older threads, I know we decided to have you try something.
I have the a32 MAF, walbro, 370s, APR with FP lowered. I run perfect.
I think we were gonna have you swap ECUs back to stock. I think we determined that as long as you didn't go WOT you would fuction enough to pass the test? You would run z32 MAF, 370s, and stock ECU.
Let me see what I can find. :>
EDIT:
I have found a few threads, but not the one I am looking for.
Your for sure route would be to use my current setup.
I still cannot find where someone used the z32maf, a32 ecu, and 370s. I think Stephen did, but with an AFC to correct things? :\
EDIT 2:
http://forums.maxima.org/showthread.php?t=296185
http://forums.maxima.org/showthread.php?t=288529
EDIT:
EDIT 2:
Actually, I clear it, don't even start the car, and it's still there. (And yes, I know the procedure and I'm doing it right - I've done i about 100 times on my car before this ECU and others).
I think I heard something somewhere about Z32 MAF + Stock ECU + 370's with NO FPR works fine....which is what I'm trying to verify.
Mainly I don't want to spend a bunch on an FPR I'll only use for 1 emmissions test.
For the record:
370cc/min injectors, Z32 maf, oem fuel pressure (34 psi base), A32 ecu results in perfect stoichiometric afr when cruising and idling. It goes lean at about 5000 rpm when at WOT and boosting.
So, Ian, with this setup you should be able to drive to the test station no problemo.
Damn...that's the next problem.
My Walbro FP makes my car do 40PSI at idle.
Or maybe it's the JWT ECU doing that...hmmmmm....guess I'll find out!
Thanks Stephen!
Thanks Stephen!
Originally Posted by IceY2K1
A32 ECU, Z32 MAF in, don't go WOT, and leave everything else, ie SC, 370cc, etc, alone...I thought we already agreed on this.
Your only issue was getting the Z32 MAF to work, right?
But otherwise - I did it today - everything works great.
A32 (stock) ECU
370cc Injectors
Z32 MAF
SC unhooked
Car drives perfectly, no codes. Even went WOT to 5500RPM just to see what would happen, and it was fine. Some fuel smell from the tailpipe, but very faint (ie: pretty normal)
FP is now at 36PSI.
Now I can go pass!
Hmmm...Interesting.
I found on an onramp that when going above 5k RPM - AFTER letting go of the gas and then gassing it again (like in a shift), the engine stutters....This unexploded fuel left over in teh cylinder or something?
Oh well - I'll just keep it under 4k for now...seems to run fine then.
Gotta drive it some more before I go get tested....dont' wanna be in open loop mode or anything....
Problem is I live 1 mile from work....so I'm just driving aorund in traffic after work every day to get some miles on.
I'd bet that's from the SC and piping restricting intake flow, but just a guess.
Yeah, take it easy until you get everything back together man.
Good luck and as long as the ECU isn't reset the night before and it has had time to do all its "emissions" checks, it should be ready to rock. I know my OBD scanner shows whether all the tests have been completed. It does take multiple trips to complete all of them, but if you have a scanner, you might try looking to see if any are pending still.
I do have a scanner, I borrowed it form maximase86's neighbor.
Don't know how to read it tho - I can see there are 0 codes, but there's a lot of other symbols on it I don't understand.
I'll google the model number and see if I can find a manual.
I love google.
It appears this one does do that. I scanned my car and only "C" <Catalyst> was flashing. When I first put the stock ECU in, everything was flashing. Not sure why nothing but Catalyst is now...(it should be nothing at all after 70 miles now) hmmm...I'll have to figure that out. May just be the way it is....
(See the link to know what I'm talking about...last set of pics at the bottom of the page)
http://www.troublecodes.net/articles...e_reader.shtml
Ian,
Do you have a y-pipe? What about a main cat?
So I don't think it's really a problem with the Catalyst system right now, but just that I need to drive it aorund some more. Only time will tell I guess.
I have a Cattman 3" Y-Pipe and 3" Carsound Cat and 3" B-Pipe/Muffler.
I've never thrown a Cat or O2 code of any kind on the JWT ECU....and it reads the same <I believe> as a stock ECU in the case of the Catalyst.
If someone knows different, let me know....
Could also be an OEM specific signal that will make the "C" on the display always flash and it's no big deal.
Anyone else out there have an INNOVA 3100 Scanner?
Flashing, but no MIL means pending. 1-trip doesn't necessarily mean one on/off of the key.
Once you've drove enough to satisfy whatever "2nd-trip" is necessary, if the fault is still there, it will throw a MIL.
However, if the fault goes away, in "3-trips" the MIL will turn off, but it will take 40 "warm-up" periods to erase the DTC from memory once it turned off.
Sounds like you're in one of those limbo states or one of the other possible cases.
Sounds like you're in one of those limbo states.
That's what I'm trying to say - I realize a simple turn of the key or even short drive doesn't mean "trip". But every other 2-trip logic has been reset (nothing else is flashing) so that tells me the ECU has detected 2 trips....and I've made 3 long drives.
I'm obviously in a "limbo" state - the question is - after 3 trips and no codes, pending or otherwise - why?
I don't know. My guess is that you haven't satisfied the driving conditions needed for the ECU to say the cat is working normally. I say keep driving until either it completes or a code is stored because of your y-pipe/high-flow cat. Otherwise, your emissions tester might fail you according to other members horror stories or by looking under the car and seeing modificaitons.
I hope the laws change to force lazy ignorant emissions testers to understand that some ECUs can be flaky, yet still operate 100% within the sniffer limits, which is all that matters.
In WA State you can have all the mods you want as long as you have a Cat. Which I do. So it shouldn't be a problem.
Last time I went (2 yrs ago) I failed the ODBII Scan due to being in Open Loop mode. They then put me on the sniffer and I passed. ALthough the guy said that wasn't "procedure".
So I want to be sure before I go this time, since I may get some guy who doesn't want to be nice.
I found a loophole
Reading the WA State Ordinance on Emmissions testing it says:
"If a 1996 through 2000 model year vehicle has THREE or more readiness monitors not set to ready, the vehicle is rejected."
So even with this one, I should pass.
So I went this morning with that "Catalyst" monitor still not ready.
I passed!...like it says above, as long as I have less than 3 monitors not ready, it's OK.
Then as I was pulling out of the emmissions station I hit a large bump and knocked the MAF harness loose (I didn't clip it down because it's temporary), causing the car to run like azz and a CEL. I drifted down the hill out of sight, reconnected it and drove home.
Couldn't leave everything on - I had a code with the JWT.
1005 - EVAP Solenoid Circuit Fault.
They would have failed me immediately if I had that when I went in.
Theo nly thing I did have when I did go in was that the Catalysts 2-trip test hadn't completed - I didn't have any codes.
I ment everything but the JWT ecu
