adj fuel press ?
Old Sep 6, 2004 | 07:48 PM
4signs's Avatar
adj fuel press ?
I need to adjust my fuel pressure (for bigger injectors). Need help trying to deciding between an adjustable regulator like the AEM or just ditching my FMU for a SFMU, to adjust base fuel pressure. Anyone have good experiences using either or? Thanks
Old Sep 9, 2004 | 05:23 PM
4signs's Avatar
bumipty bump bump
Old Sep 10, 2004 | 06:09 AM
Stephen Max's Avatar
Both Iansw and I have Cartech fmus, which are tuneable like the sfmu except that you can't adjust base fuel pressure at idle with it like the sfmu, so I also have a separate adjustable fpr.
I like having it. I think it's a good thing to have as many tuning ***** as you can, as long as you know what you're doing.
Old Sep 14, 2004 | 06:14 PM
4signs's Avatar
hey thanks, after you removed the stock fpr what did you use for an adapter, and where did you get it?
Old Sep 14, 2004 | 07:11 PM
iansw's Avatar
I don't actually have the Cartech installed right now.
I need to get it installed soon however - I can't be running 14.1:1 AFR at 6800RPM forever.....
Just been lucky as hell I've had 0 detonation.
<knock on wood>
Old Sep 14, 2004 | 08:13 PM
Prodeje79's Avatar
I am using a SARD afpr I got from Jay25. It is working good so far. :>
I got my fittings from sx7r.
Old Sep 15, 2004 | 05:06 AM
I had a spare oem fpr, so I just drilled out its guts and used it as the adapter.
jmlee44
Oct 2, 2022 02:13 PM
aw11power
Oct 10, 2021 04:57 AM
salty318
Sep 29, 2015 01:21 PM
salty318
Sep 28, 2015 07:22 PM
