Car running lean as ****.
Old Sep 25, 2004 | 08:02 AM
turbomax97's Avatar
I couldn't fix your brakes, so I made your horn louder
Few background bits of info
pfi kit t4/t04e ball bearing - leaky
swapped 555cc injectors in again after replacing busted o ring
My wideband o2 is reading 22-23 a/f ratio... at idle... wtf?...
as far as i know, fuel is getting through the fuel rail - fuel press is at 34 psi.
Are there any other causes that could lead me to be running this freakin lean
Old Sep 25, 2004 | 08:09 AM
stephenlc's Avatar
fuel pump, fuel filter? Did you run lean with the stock injectors?
Old Sep 25, 2004 | 08:11 AM
turbomax97's Avatar
fuel pump is fine - excellent pressure - fuel filter has less than 1k on it... it didnt run lean with stock injectors
Old Sep 25, 2004 | 08:12 AM
SonicDust187's Avatar
Injectors not working properly?
Old Sep 25, 2004 | 08:16 AM
turbomax97's Avatar
I'm not sure why they wouldnt - they were working ok before besides them being leaky b/c of the o rings..
Old Sep 25, 2004 | 08:19 AM
stephenlc's Avatar
using e-manage?
maybe try running the car without the fuel pressure regulator, maybe its not reading right? Pinched fuel line?
Old Sep 25, 2004 | 08:20 AM
turbomax97's Avatar
Yeah i'm using e-manage - it's not the fpr or a pinched line - i've got 2 fuel press gauges reading from different ports and they read about the same
Old Sep 25, 2004 | 08:21 AM
BigDogJonx's Avatar
Alot of widebands dont pickup well at idle. I wouldnt be too concerned about that. Take it out for a spin and see what the a/f gets on partial throttle.
My techedge wideband reads 25:1 at idle because it cant really read the idle a/f too well and just resorts to the highest reading and sits there till it is given some gas.
Dixit
Old Sep 25, 2004 | 08:24 AM
turbomax97's Avatar
I guees I'm just tripping out because before when the car was leaky, it'd read really rich - like 9 - 10:1....
hopefully that's all it is.... guys i really appreciate the handful of replies in less than 5 minutes
Old Sep 25, 2004 | 08:36 AM
stephenlc's Avatar
why your trubo leaking? Feed, drain?
Old Sep 25, 2004 | 08:48 AM
turbomax97's Avatar
Neither- i think a seal is blown in the turbo
Old Sep 25, 2004 | 09:10 AM
stephenlc's Avatar
how old is the turbo?
Old Sep 25, 2004 | 09:23 AM
turbomax97's Avatar
<1000 .............
Old Sep 25, 2004 | 11:18 AM
stephenlc's Avatar
doesn't it come with a one year warranty?
Lakersallday24
Jun 16, 2019 01:35 AM
kjlouis
Nov 24, 2018 06:09 AM
acw
Aug 13, 2015 12:50 AM
Balkins
Aug 12, 2015 06:39 AM
acw
Aug 7, 2015 04:20 PM
