Where is your EGT probe?
Old Oct 2, 2004 | 06:31 PM
|Bijan|'s Avatar
UCF Lexus
Ex. manifold or y pipe.....or other?
Which is more accurate?
Old Oct 2, 2004 | 07:23 PM
Nealoc187's Avatar
SLOW
Best place to put it would be where both banks come together at the Ypipe, that way you can't be running super lean in one bank and just fine in the other and possibly not know it.
Old Oct 2, 2004 | 07:35 PM
turbomax97's Avatar
I couldn't fix your brakes, so I made your horn louder
That's where mine was tapped before - only problem is you're reading is off because the gases have lost heat by the time they get there -i'm currently tapped in the front bank of the y pipe - it tends to run leaner... so i feel it has more use there - it's about 2 inches below the o2 sensor.
Old Oct 3, 2004 | 01:14 AM
Chunger's Avatar
My other car is a Hybrid
Closest to the exhaust port is best... but I put mine at the collector of one bank:
Old Oct 3, 2004 | 11:16 PM
turbo97SE's Avatar
Best is to have one EGT probe per cylinder in the runners, next best is one EGT per bank in the collector so you can tell which bank is lean, after that is where the down pipes come together. After that you say EGTs is for sissies and don't bother.
Old Oct 3, 2004 | 11:24 PM
|Bijan|'s Avatar
UCF Lexus
Nigel......I dont follow
1 EGT per runner of the exh. manifold?? 6 total?
or
1 probe on both collectors of each manifold?
Old Oct 4, 2004 | 06:22 AM
Stephen Max's Avatar
Sure. It really helps with the aircraft cockpit look, too. Of course you need a flight engineer along to keep track of all the temperatures.
This begs a question, though. How do you correct just one cylinder or even one bank that is running lean without affecting the others?
Okay, I know the answer is most people don't. Typically you just tune based on the lean cylinder or bank. But do some piggybacks or standalones allow for tweaking of individual injector pulse widths, so that you could tune each cylinder individually?
Old Oct 4, 2004 | 07:23 AM
Nealoc187's Avatar
SLOW
Wouldn't a single cylinder running significantly hotter than the others be indicative of a problem in that cylinder? Something which you would want to rectify by fixing it, rather than just adding more fuel to lower the cylinder temperature and continuing on as if everything were ok? It would be neat to be able to tweak individual cylinders though.
Old Oct 4, 2004 | 08:06 AM
Cylinders usually run at very slightly different afrs due to uneven air flow distribution through the intake manifold. Cylinders that get more air are going to run leaner if the injection pulse widths are the same for every cylinder. Most factory intake manifolds are engineered pretty well, so you don't see much variation in flow from one cylinder to the next.
Another cause of cylinder temperature variation is how the coolant path is designed. The cylinders towards the end of the coolant path are going to be cooled with warmer coolant and therefore less efficiently than the ones at the beginning. In this case, the temperature variation is not due to afr, but making the hotter cylinders run a bit richer can help reduce temperature and forestall detonation problems.
Old Oct 4, 2004 | 09:33 PM
|Bijan|'s Avatar
UCF Lexus
So, unless you're running an extremely powerful setup, 1 is fine huh? Does the MEVI make the flow of "uneven air flow distribution" BETTER or has it not been THAT serious of an issue?
Old Oct 5, 2004 | 05:43 AM
Not enough to be a problem.
Old Oct 8, 2004 | 12:30 PM
Prodeje79's Avatar
So for a one probe setup, you put it where the down pipes come together?
Old Oct 8, 2004 | 12:38 PM
Chunger's Avatar
If your definition of best is the easiest... yes.
As for accuracy, it was explained in post #5 above.
Old Oct 8, 2004 | 05:03 PM
densetsu's Avatar
correct. if you have only one probe and only take readings from one bank of cylinders, the readings will be accurate to run the motor, but in the event that one of the cylinders on the opposing bank starts to take a sh*t on you, you wont know until its basically too late. if you have one probe you have to take the reading somewhere where all the exhaust from all the cylinders is flowing - not half or any other fraction of them.
Ramius83
Nov 12, 2001 02:00 PM
Ramius83
26
Nov 10, 2001 06:21 PM
ZuMBLe
Apr 16, 2001 06:53 AM
1MAX2NV
Feb 1, 2001 08:02 AM
