Oil Residue Under Blower
Old Oct 18, 2004 | 03:07 PM
matty's Avatar
Ive had my, Brand New Rebuilt V1 blower on my car for less than 1K miles and I have an Oily residue forming under the blower on that black ledge by the idler pulley...i wipped up what was there with a towel and it's "clean oil" like i have in my engine now
there is no way that the oil is coming from the blower, So maybe from the drain line..my drain line is brand new with tight clamps on it...anybody have an idea because Ive seen a few other S/C maxima's and they kinda look like they have the same residue
-matt
Old Oct 18, 2004 | 03:10 PM
BlackCat's Avatar
RIP '98 Maxima SE
Check your oil return line. It may be loose or not clamped securely.
Old Oct 18, 2004 | 03:15 PM
matty's Avatar
Ill have to check that tomorrow..that had to be the only place its coming from..I hope I can get an extention socket in there to tighten that...I made sure it was perfect when I put it in though
-matt
Old Oct 18, 2004 | 03:21 PM
BlackCat's Avatar
RIP '98 Maxima SE
What I usually do is position the blower close to the engine without screwing in the bolts. I then hook up the hose to the oil return nipple and tighten the hose clamp with a flexible cable screwdriver before I finally bolt the mounting plate to the side of the engine. One time I made the mistake of not completely pushing the nipple into the hose and the oil gushed out, leaving a real ugly mess.
Old Oct 18, 2004 | 03:42 PM
Chunger's Avatar
My other car is a Hybrid
If you didn't seal the drain back hose assembly plate to the engine then it can leak from there as well.
Old Oct 18, 2004 | 04:42 PM
slimer's Avatar
A couple of Blaxxx's? Lawls.
what about your power steering lines? i know that i have a leak in there that im going to fix next week.
also, which formagasket did you use? 1A or 2B? one hardens, the other stays soft, i made the mistake of using 2b for the drain back plate.
Old Oct 28, 2004 | 03:36 PM
matty's Avatar
Wound up being the blower !!! grrrr...well i have it off and I noticed the plate is leaking alittle as well...
I used Pertmatex 16B ??? is that wrong ?? its not formagasket .Im getting alittle leak from there as well so Im gonna do that seal over again while the blower is off
-matt
Old Oct 29, 2004 | 03:18 PM
iansw's Avatar
You know - I have oil residue under my blower as well....I have about 7k on it.
It's always been there since hte day I installed the blower and I always assumed it was coming out of the oil plugs (the big allen-wrench bolts) under the blower. I usually reach down there and wipe it up whenever I wash my car....Hadn't thought much of it until now.
damn...now I'm kinda sweating it.
IanS
Old Oct 29, 2004 | 03:49 PM
matty's Avatar
Well crack off the cold air setup and see if theres oil residue on the inside of the case ?? after speaking to alot of guys with blowers, alot of them have had to send them back due to leaking..
NYMJAYJAY, DELIO
-matt
Old Oct 29, 2004 | 03:56 PM
matty's Avatar
How come Stillen directions say to Use 2b. ??
PERMATEX® FORM-A-GASKET® No. 1 Sealant
Fast drying, hard-setting sealant designed for sealing rigid materials and flanges, or patching holes and joints where permanent assembly is desired. Temperature range -65°F to 400°F; resists common shop fluids and fuels.
Suggested Applications:
Freeze plugs, threaded connections, manifold gaskets
PERMATEX® FORM-A-GASKET® No. 2 Sealant
Slow drying, non-hardening sealant designed for sealing cut gaskets and stamped parts. Allows for easy disassembly if required. Temperature range -65°F to 400°F; resists common shop fluids and fuels. Use where sealing is more important than adhesion.
Valve cover gaskets, oil pan gasket
Why Couldnt you use a gasket maker like....This is designed for turbo charged/supercharged cars but its a gasket maker ???
What one do I use ???
Old Oct 30, 2004 | 11:15 AM
matty's Avatar
Anyone know ?>?
-matt
Old Oct 30, 2004 | 05:57 PM
lex4style's Avatar
i had a similar problem with my SC. I know of a guy I met at a maxima meet that used that sealent stuff because of the same problem. And he had nearly 90k on his SC. Not sure....
Old Oct 31, 2004 | 08:30 AM
vortechpower's Avatar
I think that is me...
Old Oct 31, 2004 | 08:51 AM
matty's Avatar
How come nobody knows what type of permatex to use...All of you guys have done the install right ?
-matt
Old Oct 31, 2004 | 12:12 PM
Requin6's Avatar
matty...the stillen instructions call for Permatex form-a-gasket #2.
for some reason i 'may' have used RTV gray. i cant remember for sure, but that is in my mind. i used either the RTV grey or the permatex #2.
Old Oct 31, 2004 | 12:28 PM
slimer's Avatar
my permatex 2 is leaking.
its about 1/2 a quart every 3k.
I make sure that i check everything at least 2x a week.
Old Oct 31, 2004 | 02:39 PM
iansw's Avatar
NYMJAYJAY, DELIO
-matt
Took a look at the underside of my blower today with a mirror and a flashlight. The seals aren't leaking, the place where the 2 SC halves meet are dry as a bone. From what I can tell it looks like the feed line for me.
No oil residue on intake or blower inlet either.
Old Oct 31, 2004 | 03:02 PM
Max97Stick
i just got my sc installed and i had it on about a week looks like i need a new oil feed line cause its wet when i touch it other than that sc no leakin at all
Old Oct 31, 2004 | 06:03 PM
matty's Avatar
I was thinking maybe I should use the Ultra Copper stuff...its meant for Supercharger/Turbo Applications
-matt
mclasser
22
Nov 12, 2020 01:58 PM
05RLS2
Apr 14, 2016 11:49 AM
knight_yyz
Nov 1, 2015 01:34 PM
