Where should I tap for my boost reference?
Old Nov 3, 2004 | 07:01 AM
JustMaxin96's Avatar
Hello,
I am trying to install everything possible before I install my SC, this includes my gauges. I would like to know where I should tap for a boost reference for my boost gauge? If you know, please respond. I appreciate the help!
Thanks,
-Jason
Old Nov 3, 2004 | 07:12 AM
Stephen Max's Avatar
Originally Posted by JustMaxin96
Hello,
Thanks,
-Jason
Tap into the vacuum line going to your fpr.
Old Nov 3, 2004 | 08:09 AM
tap into the OEM FPR vacuum line? Do you think this would be a good time to install my AEM FPR even though I do not have the SC in yet? I really am just trying to do everything possible before the actual blower goes in the car.
Thanks for the reply!
Old Nov 3, 2004 | 08:31 AM
Redmax's Avatar
Redlinemax Owner
Yep you can do that and it will be fine
Old Nov 3, 2004 | 09:17 AM
slimer's Avatar
A couple of Blaxxx's? Lawls.
it will be fine. it was with me.
why do you have the aem, are you putting in a walbro?
Old Nov 3, 2004 | 10:26 AM
Thanks for the replies, yes I do have a walbro. Will I have to mess with the fuel pressure on the adj. FPR before boost?
Thanks again.
Old Nov 3, 2004 | 10:34 AM
The Walbro will most likely raise your base fuel pressure by about 7 psi, so you can use the adjustable fpr to bring that back down to the oem base pressure of 34 psi. On the other hand, it's not absolutely necessary and my engine runs fine with a base fuel pressure of 38-40 psi.
Old Nov 3, 2004 | 11:59 AM
SpeedCrazie's Avatar
Does anyone know if it is okay to have multiple taps coming from the FPR Vaccum line?
Old Nov 3, 2004 | 12:38 PM
Perfectly fine, everybody with a SC does it.
litch
123
Jan 4, 2024 07:01 PM
aw11power
Oct 10, 2021 04:57 AM
Miket2006
Mar 1, 2021 03:55 AM
MichMaxFan
Sep 30, 2015 09:18 AM
