Maximum boost level
Old Oct 24, 2004 | 09:53 PM
Redmax's Avatar
Redlinemax Owner
Maximum boost level
on a 9:1 compression motor with a good tune of 11.5 af what do you guys think the maximum amount of boost that can be run is before something breaks?
Any ideas to help increase the boost are welcome.
Old Oct 24, 2004 | 10:02 PM
subs1000w's Avatar
with forged internals 20psi daily easily
i bet you could run 25 or more at the track
Old Oct 25, 2004 | 02:38 AM
Boosted Maxima's Avatar
From the book "turbocharging" it states that when you run 15lbs of boost it theroeticly double's your cubic inch. (or forces twice the amount of air) than would be at atmospheric pressure. At that level is says that your only putting 25% more load on bottom end parts.
9-1 is a fine compression ratio for boost especialy with allum. heads. Forged pistons melt at the same tempature as cast pistons. The key to any boosted or nitrous engine is not to detonate. The tune is critical and will make the difference between Power and Picking up parts.
~Scott
Old Oct 25, 2004 | 09:21 AM
mtcookson's Avatar
i've heard of guys running 50 psi on 12:1 compression.... its all in the tuning. just like Scott said, keep it from detonating and you should be pretty good for a while.
Old Oct 25, 2004 | 10:05 AM
vortechpower's Avatar
cause you are double the atmosheric pressure I think is 14.7, Ive heard that too
Old Oct 25, 2004 | 10:15 AM
MardiGrasMax's Avatar
The DET parts are no stronger than DE, they are just lower CR. I'd have to say youll surpase the 590cc injector before you blow it if its tuned properly.
Old Oct 25, 2004 | 01:05 PM
VQ30DES's Avatar
I just wish the max was rear wheel drive. the engine can make some incredible power, but it is still a front wheel drive car.
Old Oct 25, 2004 | 02:32 PM
Nealoc187's Avatar
SLOW
Could swap it into an RX7 or some other cool little RWD car (VQ30 powered S14 or MR2 anybody? ).
Old Oct 30, 2004 | 07:07 PM
pawnstar12's Avatar
BUY MY CARS PLEASE!!!
VQ30 miata with 20psi!!!!!!!
Old Oct 30, 2004 | 07:38 PM
stephenlc's Avatar
I was thinking old school 200sx. It came with the VG so the Vq would be equal in size but less weight. I might do it with a VQ30Det but I can't find one cheap.
Old Oct 31, 2004 | 07:36 AM
pawnstar12's Avatar
the dets go for $1200 there was a place in jersey that have them i forgot the name
Old Oct 31, 2004 | 10:52 AM
stephenlc's Avatar
I meant a 200sx.
Old Nov 1, 2004 | 01:39 AM
pawnstar12's Avatar
ohh i know that there was one for sale around me
Old Nov 1, 2004 | 04:35 AM
stephenlc's Avatar
sorry I know this is off-topic. I found a 200sx but older than I wanted 1980 one. The only RWD tranny that will bolt up to the VQ30DET is the 350z one correct?
Old Nov 1, 2004 | 09:38 AM
BlackBIRDVQ's Avatar
drag racing is for wussies
Yes I you can find 350Z trannies for dime a dozzen. Ask SR20DEN if he still has his 350Z tranny layn around. I sold mines 2 weeks ago.
Old Nov 1, 2004 | 11:06 AM
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
Here's a 350Z 6spd for $850 w/90day warranty:
http://www.karking.com/catalog/produ...c551ce87e7be9e
Old Nov 1, 2004 | 02:45 PM
I was letting mine go for 450 each with 4K miles on them. If you look around you can get them for even less.
Old Nov 1, 2004 | 05:44 PM
mtcookson's Avatar
do they happen to have a removable bell housing?
Old Nov 2, 2004 | 06:25 PM
pawnstar12's Avatar
but the 6 speeds have been having some problems ...right?
Old Nov 2, 2004 | 06:26 PM
mtcookson's Avatar
yeah, it seems a lot of people have been having difficulty shifting after a few thousand miles or so.
litch
123
Jan 4, 2024 07:01 PM
aw11power
Oct 10, 2021 04:57 AM
gavin68
Sep 18, 2021 12:36 PM
MichMaxFan
Sep 30, 2015 09:18 AM
