V2 Kit with alignment problems? How to solve?
My SC belt shredded about five months ago. I had complications getting the blower plate off to replace the belt. I was finally able to get the belt back on on Saturday, and after 3 days of driving the belt has shredded.
I have a V2 blower with aluminum plate and the plastic pulleys running the 3.6" pulley.
What exactly have you guys done to make your blower more reliable in the department of preventing belt shred.
AKA: How do I fix this dam alignment problem??
Blackcat I was told you may have the answer.
Originally Posted by DonSupreme
not sure exactly how many miles but I assume its over 20K.
My pullies are still operational. They are the plastic ones but they are still intact.
Any suggestions?
Any suggestions?
Hey Don
Since the belt moved away from the engine you definitely need some washers. The belt is trying to center itself on a natural and vertical plane while running around the pulleys.
The shop that installed my V2 used 3 very thin washers (paper thin) and stuck them on 3 of the posts between the mounting plate and the blower. I put one washer on each of the posts marked in red in the pic below:
That pushes the blower ever so slightly away from the engine and helped to realign the belt. The time I first took off the blower to swap out the 3.6" pulley for the 3.33" I did not note where these washers were placed. Logically I thought that they should have been on the 3 posts on the right side of the pic and my belt jumped and shredded. I rethought my logic and evenly distributed the washers instead and that did the trick.
As for the V2 mounting plate warping I've never heard of that happening in this forum. Its now 4 years since I've had the V2 kit.
When you've reinstalled everything run the engine for a short while and then turn off the engine. Take your flashlight and look down at the belt and check how they go around the pulleys. The belt should not be touching the side wall of the tensioner pulley but should be centered on both the idler and tensioner pulleys. If they look centered then you're good to go!
The belt was pulling away from the engine (to the left). Do you think some washers would help? If so, what guage washers, where to get them, and where do I put them.
Then again, maybe the 3.6" pulley is loose and is starting to creep towards the engine?
Here's a pic of the time that happened to me:
It was a b#tch to move it off away from the mounting plate.
I've since learned to not reuse the #5 bolt (where that open end wrench is).
Originally Posted by C MAX
wow thats terrible but he said its creeping away from the engine that would pull it towards the engine. its gotta be the main pulley thats the only other thing thast aligns with the s/c itself. either way putting washers in either of these places should solve your propblem.
So now i am confused. Should I follow the blackcat diagram or what?
Which pulley is called the Main pulley? The 3.6" s/c pulley, the idlers pulley, or the tensioner pulley?
Any recommendations on the dimensions of the washers?
Additionally, should the belt be 100% over the idler pulley or just half on it? Mine always seems to sit halfway on it.
Since the main pulley had moved away from the blower and was rubbing against the #5 bolt the belt would have wanted to stay on the same plane as the idler and tensioner pulley and so I can see the belt jumping a rib or two away from the engine while trying to stay in alignment. In my case it didn't happen and the screeching sound of metal on metal alerted me to the problem. Now if the #5 bolt wasn't there I think there could have been the possibility of the belt jumping a rib away from the engine.
My belt sits right in the middle of the tensioner and idler pulleys.
i never cranked it while under the engine, but I will try. I hope that the problem will become evident that quickly, because so far its taken some drive time to show itself.
I will you'll know how it turns out.
We'll see, when i put my belt on last night, I had to make several full throttle runs before it shredded. I pulled over and checked the belt after each run. It seemed fine the times I checked it, and before I could pull over it to check it the last time I SMELT THE RUBBER ahha....
To me it sounds like something is Flexing under boost and alowing the belt the shred....try reving it with a new belt and see what the belt looks like at it spins..if you have to sit there for 5 min reving it up, try and simulate like your taking a ride and boosting...
Just wondering if bolt #14 is on the mounting plate. That's the one with the allen key hole. Its found underneath the idler pulley. I heard that if its missing it can allow the plate to flex.
the p.i.t.a screw. i didnt have that one in also but when i paid jeff to help me he put it in so im not sure if that was a factor also.
This one in the pic is from Sears but in Canada Sears did not carry this tool until recently.
I finally got my hands on a 1/4 x 5/16th Box End offset ratchet from Canadian Tire. Taped the allen key nub from my Craftsman screwdriver and I was good to go!
thats a good idea. another way i do it is to tape a allen wrench to a small pole and dont tighten the tensioner screws until you have that one in makes it a lot easier.
This box end ratchet really speeded up the process. I always put that bolt in first before any other bolt. I found out the hard way when that bolt didn't line up with the hole after putting in all of the other bolts. Now I need a box end ratchet for the bolt for the idler pulley.
I used to tape an Allen key to the top of my Craftsman screwdriver but it took too much time to put it in, turn, put it out, reposition, put it in, etc.
I've never used that screw and never had a problem, but I've got a V1 bracket.
you snapped your CRANK PULLEY??? Oh god....
Didn't you just have a spark plug blow up on an engine before this one?
Why did you lower all the way to 8.5:1 for an SCer?
I also have thet craftsman tool, but I just put a hex socket into the rachet as suggested by Jay25.
I am trying to find a local org member with a V2 to help me do the reinstall. I can't crank the engine and look from underneath by myself. Plus it would be good to have someone who got their v2 working right.
P.S. I am not missing any bolts.... All the holes are filled.
Blackcat your inbox is filled up.....
I was going to ask if I can use the 3.33" pulley without shaving a post?
I used a flat file to flatten the post more for the 3.33". I've burnt out my Dremel shaving off the entire post a few weekends ago in preparation for my 3.125".
Which pulley is the MAIN pulley?
Having read all 30 posts it is as clear as mud to me. Currently my SC is in a box. I tried spacers, new anodized pullleys, belts etc. Finally I gave up. Not sure if I want to try again.
I never tried adjusting the crank pullley.
Again, which pulley is the MAIN?
its the one you tighten the belt with it replaces the stock pulley that comes with the car. the other pulley is located on the s/c bracket itself. to properly align it you have to watch its rotation to see how the belt is revolving around the the pullies.
bbsitum
Sep 11, 2015 04:55 PM
