Map sensor questions
Old Dec 15, 2004 | 08:30 AM
fratzke7's Avatar
I just went to the auto shop and the guy there told me that there was a code in my cpu for my MAP sensor!! Is there some kind of upgraded or aftermarket MAP sensor that I can buy that will run better with my S/C?? My car has a production date of 11/99 if that matters and I have the the V2 s/c with an automagic, and a levelten tranny.
Old Dec 15, 2004 | 09:15 AM
slimer's Avatar
A couple of Blaxxx's? Lawls.
theyre pulling your chain, your car operates on mass air flow, not manifold pressure.
not sure on the upgraded maf.
anyone else?
Old Dec 15, 2004 | 09:26 AM
fratzke7's Avatar
That is the code that it pulled up, I think it was 105??? on there snap on computer?
Old Dec 15, 2004 | 09:44 AM
DA-MAX's Avatar
Eat, sleep, and sh*t 2JZ
yeah, there is some sort of MAP sensor on the VQ..I think its MAP/BARO or something....I've pulled that code countless times on Redmax's car. but I seriusly doubt it has any involvement in A/F ratio, so an "upgrade" would be pointless. the VQ ECU is 100% MAF driven.
Old Dec 15, 2004 | 01:38 PM
fratzke7's Avatar
Ok, this is prolly a stupid question but where is the Map/baro sensor???
Old Dec 15, 2004 | 01:57 PM
DA-MAX's Avatar
if I can remember(which I usually can't ) it was buried in the mess of wires and sensors near the driver side of the front valve cover...but I can't remember for sure and no FSM in front of me right now to check
Old Dec 15, 2004 | 02:11 PM
meccanoble's Avatar
Sports Button FTW
MAP or Absolute Pressure Sensor (i think the same things) is on the driver side to the right of the valve cover. Originally its supposed to be bolted on some piece of metal where it sits to the right of the valve cover but in my car and many others, you can see it just lugging around by the wires. I had a code for it (0803) and i replaced mine and code went away. If your CEL comes on and u do your own check and get 0803, its most likely that sensor, its like a small rectanle box. Has a harness hook up on one side and i think 1 or 2 hoses hook up on other side.
Old Dec 15, 2004 | 03:46 PM
DA-MAX's Avatar
I guess my brain still works somewhat and I'm not losing it afterall
Old Dec 15, 2004 | 03:59 PM
fratzke7's Avatar
Even with my S/C, I will check tomorrow though so thanks for the information!!!
Glad to see that I am not the only one going
Old Dec 15, 2004 | 04:39 PM
meccanoble's Avatar
Sports Button FTW
experienced noob to the rescue now someone help me wit some javascript
mvm062
Nov 30, 2020 09:00 AM
220k+ A32
Sep 11, 2015 02:18 AM
dcardello
Sep 3, 2015 11:44 PM
sdotcarter
Sep 2, 2015 09:53 PM
