VQ30DET Connecting Rods
Old Jan 17, 2005 | 09:31 PM
JeffesonM's Avatar
living out of a maxima...
found these while browing around... Connecting Rods for VQ30DET Crankshaft
supposedly for use with the Crank Shaft VQ30DET 73.3mm Stroke 50mm Rod Journal
Old Jan 18, 2005 | 05:45 AM
stephenlc's Avatar
cool find.
Old Jan 18, 2005 | 05:44 PM
SPiG's Avatar
SomePsychoGuy
So someone with a VQ35 would put in a VQ30DET crank and rods and make a 3.2L? I know that the VQ30DET has stronger rods than the VQ30DE and the VQ35 had a bad batch of rods or something but would this really be a good idea for a VQ35 engine builder. I can definitely see good potential for VQ30 builders.
Old Jan 18, 2005 | 11:57 PM
Redmax's Avatar
Redlinemax Owner
from what i thought the det rods werent much better than the de rods
Old Jan 19, 2005 | 05:52 AM
stephenlc's Avatar
those are not DET rods. Those are carillo forged rods. Thats the price per a rod a think.
Old Jan 19, 2005 | 07:58 AM
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
http://www.nissanperformancemag.com/july03/goughary/
Old Jan 19, 2005 | 08:00 AM
IceY2K1's Avatar
Carrillo makes a light weight Pro-A rod that are cheaper then their beefier Pro-H rods for the VQ35. I don't see anything listed for the VQ30, at least in their Product list.
If they make Pro-A rods for VQ30s, that would be awesome.
Old Jan 19, 2005 | 09:37 AM
Larrio's Avatar
The Definitive AE Master
I talked to carrillo yesterday and they do not have rods for us but will make them after I sent them the piston specs.
and speaking of jim goughary
http://larrio.maximaclubca.com/350ZDYNO1.jpg
Old Jan 19, 2005 | 09:41 AM
IceY2K1's Avatar
Larry,
Ask they what bhp their Pro-A rods would support.
Old Jan 19, 2005 | 11:27 AM
Larrio's Avatar
which one do you want
CUSTOM Roller Bearing Bottom End
or
CUSTOM Plain Bearing Bottom End
they've already told me that the rods I want for NA build up will not work with a turbo setup. Something about tensile strength.
try their form alex:
http://www.carrilloind.com/contact.html
Old Jan 19, 2005 | 11:58 AM
IceY2K1's Avatar
I think PLAIN bearing.
Tensile strain will be greater on a NA high RPM motor, so that doesn't make sense.
I'm sure their Pro-A would be plenty for 400-450whp, if stockers can.
Old Jan 19, 2005 | 04:39 PM
SPiG's Avatar
SomePsychoGuy
Is the price really $300 per rod for the DET rods? I didn't realize that forged rods were that expensive. I would assume that if they were to get a new crank and destroke your engine that the rods would be really strong.
Old Jan 19, 2005 | 05:04 PM
stephenlc's Avatar
anything a little bit beefier than than the stock rods would be able to support 500-600 whp.
Old Jan 19, 2005 | 05:40 PM
subs1000w's Avatar
i think most people order custom rods from other companies for about 100$ a rod
Old Jan 20, 2005 | 12:23 AM
SPiG's Avatar
SomePsychoGuy
That is what I thought. Even if you were to get them to get them to fit the DET crank they wouldn't be much more expensive than the ~$100 a rod. That is 3x the price. I couldn't see spending $1800 on just rods unless you were going for some MASSIVE power goals.
Old Jan 20, 2005 | 07:44 AM
IceY2K1's Avatar
You can get VQ35 Pauter rods for <$1K.
Old Jan 20, 2005 | 05:29 PM
stephenlc's Avatar
you can not get custom rods for $100 each. if they were that cheap everyone would but custom rods.
Old Jan 20, 2005 | 07:33 PM
subs1000w's Avatar
if you call around you could probobly come pretty close notice i said about
and dont be jelous because us VE guys can use any VG30DE rod or piston like the eagle h beams for 529$ a set
http://www.cdpautomachine.com/ecatalog/importrods.html
but according to the 300zxtt guys the stockers have been proven reliable at 600hp so im not to worried
Old Jan 21, 2005 | 08:14 AM
stephenlc's Avatar
why am I jealous? I have called the cheapest anybody has quoted me was like $219 a rod.
Old Jan 21, 2005 | 12:18 PM
subs1000w's Avatar
im kidding about the jealous part but man 219 a rod
i know people have gotten custom rods made for the vq30 but i thought they were alot less than that
Old Jan 21, 2005 | 12:26 PM
stephenlc's Avatar
thats why I am saying SGP sells a massed produced rod for 1099 for 6. The best deal so far has been with the group deal recently at my350z.com. I think they got them for $600-$800.
user 11122324
42
Jul 18, 2022 03:35 PM
knight_yyz
Nov 1, 2015 01:34 PM
zmcneely13
Sep 26, 2015 02:26 PM
londonflu
Sep 19, 2015 02:33 PM
