Need help! V2 SC kit question
Old Jan 31, 2005 | 07:31 AM
Stephen Max's Avatar
A friend of mine with a V2 supercharger kit called and said his car is making a noise and he thinks the idler pulley is melted.
I know on my V1 kit I can simply remove the SC belt and run the oem belt and bypass the SC pullies.
Is this true with the V2 kit?
Old Jan 31, 2005 | 10:47 AM
slimer's Avatar
A couple of Blaxxx's? Lawls.
yes, you can.
that is basically how i got home when i had those brackets crack on me
Old Jan 31, 2005 | 11:01 AM
Originally Posted by slimer
yes, you can.
Okay, thanks, Steve.
Old Jan 31, 2005 | 11:20 AM
slimer's Avatar
no problem. thats why i always keep the stock belt and extensions in my car.
Old Jan 31, 2005 | 08:36 PM
MAXimumHP's Avatar
I thought when I toasted my belt at the track I had to swap one of the pulleys to get it to fit.
Old Jan 31, 2005 | 08:43 PM
slimer's Avatar
i never did. its a little looser, but it still works for a temp fix. it worked for me for about 2 months last year
Old Jan 31, 2005 | 08:47 PM
MAXimumHP's Avatar
Now that I think about it, my problem was that I f-ed up the pulley too, so I tried to use the stock tensioner pulley and it didn't work. I luckily had another smaller pulley. Man my brain sucks. I can't even remember what I did.
Old Jan 31, 2005 | 09:08 PM
slimer's Avatar
that was the nite that i was supposed to come up to gld and then came the next nite instead.
Old Jan 31, 2005 | 09:16 PM
MAXimumHP's Avatar
We'll have to meet up there this year. I just get kinda sick of making the long drive when I have one 10 minutes from my house. I'm definitely an outcast up here though with an import sedan...
Otherwise we have some coilovers to install, and detail meets.
Old Jan 31, 2005 | 09:18 PM
slimer's Avatar
yeah, i think the first detail meet for our area might be at my house. I put in the d2 thread that maybe we could get it to be a d2 weekend.
Old Jan 31, 2005 | 11:02 PM
meccanoble's Avatar
Sports Button FTW
stephen, is the problem happening to the guy i sold my kit to?
Old Feb 1, 2005 | 05:31 AM
Yes, but I took a look at it last night and it doesn't appear to be a problem with the SC kit after all. The pulley is not melted and the belt is running straight and true. It may be that he has an alternator bearing going bad and is making some noise.
Old Feb 1, 2005 | 06:46 PM
meccanoble's Avatar
Sports Button FTW
thank god, i would hate to be responsible for an issue like that. BTW, sorry bout the windshield wasther fluid holder....
Old Feb 1, 2005 | 11:49 PM
vortechpower's Avatar
Sometimes you can get strange noises. You just have to figure them out..
Old Feb 2, 2005 | 03:15 AM
JAY25's Avatar
I had a similar issue with noises too. I thought the alternator was really bad. Turns out the belt was touching the bracket just a little bit. I took it to Nissan and one of the Master Techs told me is not your alternator is the belt touching the bracket. He simply applied brake cleaner and the noise would go away. I removed the SCer and hacked off that one piece off the bracket. Noise was completely gone. It was a nasty noise as if a bearing had gone bad. Hope this helps.
If you damage the idler or belt tensioner pulley, kiss the belt good bye. Your more then likely to shred the belt almost immediately.
The Frye
Sep 2, 2021 11:03 AM
pears
Sep 18, 2015 05:25 AM
Jamie Bolus
Sep 13, 2015 05:56 PM
