Exhaust clamps and gaskets
Just gathering the last few small items I need.
My exhaust is not flanged at certain points, looks like I need to use some sort of clamp. What is it called exactly that I need to connect two exhaust pipes together....is this what I need
http://www.prostreetonline.com/buy/d...xhaust_clamps/
or
http://www.jegs.com/cgi-bin/ncommerc...16&prmenbr=361
I also need to make a gasket for where my feed pipe bolts to the turbo. I have bought gasket material from Napa in the past for my PF TB but from what I remember what they had is not going to be good for this application. I would like to use a metal gakset. Is there sheets of metal gasket I can buy and cut to shape?
or
Originally Posted by spanishrice
you can find the metal gasket for whatever flange you have on e-ay or at a local performance shop.
Like this for my T4/o4e
http://cgi.ebay.com/ebaymotors/ws/eB...951536560&rd=1
Originally Posted by I30tMikeD
ya that is the one looks just like mine. Also for your exhaust you could use this, V-band clamp:
http://cgi.ebay.com/ebaymotors/ws/eB...sPageName=WD1V
I hope that helps.
I hope that helps.
I hope that helps.
I am not very familiar with v-bands, Although I have for my turbo and I kinds see how that works by looking at it but on that the flange had to be welded on. So would I need to weld on this flange to connect exhuast piping? It does not seem like the clamp would be wide enough to hold two pipes together.
If you could give a description of how this would work on exhaust pipes I wold appreciate it.
I need two of them as well....man, I am spending well over $150 alone on couplers and t-bolts
This flange would get welded to your exhuast pipe, another one just like it gets welded to the other exhuast pipe.
then this clamp connects the two
this is what you would get when you order it two flanges and one clamp to connect them. But you do have to weld the flages to the pipes.
I HOPE THAT HELPS
I HOPE THAT HELPS
If one of the ends of the pipe is flared so that the other connecting side can slide into it - then you can just get that jeg's clamp and use that. The PFI kit comes with similar clamps for the feed pipe as well as exhaust piping
your right, the pipes are like that. I don't actually have my exhaust yet but after you said that I looked at the pics I had and that is how it seems to be designed.
i thought v-bands was only for a v-band turbo?
v-bands are a type of flange.. they can be all over your exhaust.. kev had them where his cat was for those "screw the air moments"
Originally Posted by Broaner
I've always wondered why turbo people are so biased toward clamping the piping rather than just welding. Someone please enlighten me.
have a shop weld a flange on each side and just bolt them up with a gasket in between - they shouldnt charge you more than a couple of bucks to do it. probably around $20-30 for the flanges and bolts, and $10-20 for the welding (unless you can weld yourself) - much cheaper than v-band... but, if you are rich then v-band is the sh*t
knight_yyz
Nov 1, 2015 01:34 PM
