How is this blower turned?
Old Feb 7, 2005 | 08:06 PM
|Bijan|'s Avatar
UCF Lexus
It seems as if the tip of the supergcharger is pointed downward a lot more than all others. Is it the same bracket with new bolt holes threaded?
Old Feb 7, 2005 | 08:34 PM
matty's Avatar
Thats Stephen Max's blower, he cut a hole and put his charge pipe down below across the front of the car to make the charge temps lower.
Its clamped at the disscharge of the blower and pointed downward
-matt
Old Feb 7, 2005 | 08:54 PM
|Bijan|'s Avatar
UCF Lexus
-matt
What do you mean? I can see where the coupler attatches, but it seems the the WHOLE blower was tilted clockwise - doesnt it?
Old Feb 7, 2005 | 09:22 PM
matty's Avatar
A little bit yea, but if you look at the plate and the front of the blower, the feed line goes in at the same angle and the front two mounting holed on the blower are correct..its a tricky angle to look at I guess
another good thing to look at is the Vortech Information plate..its in the right spot
-matt
Old Feb 7, 2005 | 09:30 PM
slimer's Avatar
A couple of Blaxxx's? Lawls.
you can clock the blower which ever way you want. there are multiple mounting points on the blower.
Old Feb 7, 2005 | 10:11 PM
|Bijan|'s Avatar
UCF Lexus
Maybe I just need to be shown how the blower is clocked. I see how the info plate is the same. But I dont see how the compressor (I guess) attatches to the info plate structure. Or how it's adjusted.
Obviously Steve did it, but I'm just new to seeing his setup.
Old Feb 8, 2005 | 04:35 AM
JAY25's Avatar
Is nice to see everyone is doing their own thing with these SCers. Stephen thats nice. Congrats all of you
Old Feb 8, 2005 | 05:20 AM
Stephen Max's Avatar
The scroll portion of the blower is held against the housing with tabs, so all you have to do is loosen the tab bolts and you can rotate the scroll any which way you please.
In an earlier incarnation, I had the scroll pointed slightly up:
Old Feb 8, 2005 | 07:26 AM
slimer's Avatar
stephen, are you talking about those small allen screws? i just thought it was the part where the mounting plate fit.
Old Feb 8, 2005 | 07:45 AM
That's right, the small allen screws. There are 5 of them spaced around the scroll.
Old Feb 8, 2005 | 07:47 AM
By the way, Steve, I goofed and edited your post by mistake instead of quoting it. Took me a while to correct the mistake, in case you got a bunch of email notifications.
Old Feb 8, 2005 | 08:43 AM
slimer's Avatar
thats fine. when i was taking the blower out, i was looking at those and thought that they held the case together.
Old Feb 8, 2005 | 08:49 AM
chris'smax's Avatar
So if you loosen these 5 allen bolts, then the compressor will be able to rotate? Or am i missing something?
Old Feb 8, 2005 | 09:13 AM
Well, there are also the same size allen bolts that hold the two gear housing case halves together, but they are on the backside of the blower.
Old Feb 8, 2005 | 09:14 AM
The scroll will rotate relative to the gear housing.
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
OT, but Stephen, what do you do with what looks like an oil pressure sensor switch?
Old Feb 8, 2005 | 09:15 AM
I measure oil pressure going into the blower.
Old Feb 8, 2005 | 09:37 AM
slimer's Avatar
its an oil pressure sender isnt it?
Old Feb 8, 2005 | 09:52 AM
|Bijan|'s Avatar
UCF Lexus
Damn I had no idea....I was looking at it and I said to mylself....something doesnt seem right. Stephen youve got an extremely nice setup.
How many and what angle pipes did you use?
Old Feb 8, 2005 | 09:59 AM
Nismotech1's Avatar
confident nissan owner
thats very smart stephen, who sells the sending unit?
Old Feb 8, 2005 | 10:20 AM
That's the sender to the Autometer oil pressure gauge.
Old Feb 8, 2005 | 10:25 AM
Basically, a short straight section from the blower to a 45 deg bend, a 90 deg bend in the foglight area, a long pipe to the next 90 in the driver's side foglight, a 45, a short straight piece and another 45 to get up to where a PRCAI intake would start, and then it's the PRCAI all the way to the throttle body. All 3" diameter stainless pipe.
Old Feb 8, 2005 | 10:30 AM
Broaner's Avatar
2060lbs and falling...
There was a great demonstration of clocking the blower on Two guys garage several weeks ago. Where were you all in my "Reclocking blower" thread?
Old Feb 8, 2005 | 10:52 AM
matty's Avatar
All you gotta do it loosen those allen keys and that outer plate turns ??
-matt
Old Feb 8, 2005 | 10:54 AM
-matt
Well, sorta. You use an allen key to loosen the allen bolts. Then you can turn the scroll.
Old Feb 8, 2005 | 11:03 AM
cardana24's Avatar
Blown
Did you ever do any tests to see if you were getting any better air flow by having the outlet in different positions? Mine is set in the stock position and I have always felt like I am loosing flow from the S/C going straight into a 90
Broaner's Avatar
Is there an o-ring in there which can be damaged? I want to remove my scroll to polish it but not if there is a possibility of needing a new seal.
Old Feb 8, 2005 | 11:11 AM
I haven't done any tests, but if you believe fluid mechanics theory, you are losing flow. I did this mainly to get the crossover pipe away from the hot engine/manifold/radiator area.
Old Feb 8, 2005 | 11:13 AM
My blower did not have an o-ring, although I retrofitted one later. If you get the allen bolts loose enough, you won't damage the o-ring.
Old Feb 8, 2005 | 12:26 PM
|Bijan|'s Avatar
UCF Lexus
Steph, if you have hi-res pics of your new setup, will you email me some at bijangxe@yahoo.com ?
Old Feb 8, 2005 | 12:33 PM
|Bijan|'s Avatar
UCF Lexus
Old Mar 5, 2005 | 09:03 AM
slimer's Avatar
im still stuck on this.
would this do the job?
these are at a local dsm shop.
http://www.automotosports.com/diy_silicone.asp
Old Mar 5, 2005 | 09:04 AM
slimer's Avatar
also, do the tab bolts have little brackets on them?
on the v2 do i have 6?
Old Mar 5, 2005 | 01:07 PM
JAY25's Avatar
That is all you will need to connect the piping. No need to get bent over on what material is the stuff made out of. As long as it can handle over 10 PSI it should be fine. Those couplers can hold well over 20PSI
Old Mar 5, 2005 | 07:22 PM
slimer's Avatar
i was thinking that instead of the z piece that stephen used.
Old Mar 5, 2005 | 07:59 PM
matty's Avatar
Im kinda confused on how that outer face turnes and how much its aloud to turn ?? when you loosing or Take those allen screws all the way out or just loosen them, does it then turn ?? I dont wanna jsut jump into this without knowing what I need to do...
Will the blower have to come off the plate to do this ??
I was planning on turning it up a tad bit when I put in my new charge pipe to get rid of that 45.
-matt
Old Mar 5, 2005 | 08:03 PM
slimer's Avatar
i kinda want this because i would like to retrofit projectors and there is no space there with the cefiros.
Old Mar 5, 2005 | 08:06 PM
matty's Avatar
Do you have the Ebay link to the peice you used originally for the cross over, over the engine from the Z...it was like 30-40 on ebay. I cant find it
-matt
Old Mar 5, 2005 | 08:11 PM
slimer's Avatar
the part that i posted is what stillen uses for their silicone replacement.
Old Mar 5, 2005 | 08:37 PM
matty's Avatar
Yea i know..im talking about the Z part that is on Ebay...flex section of intake tubing...
Stephan...is that section sterty enough to hold up the charge pipe ?? or will i need to make faseners ?
