SC question
Old Feb 11, 2005 | 03:37 PM
jdmmax's Avatar
SC question
would somebody poinbt me in the right direction???
just wanted to know which head unit would be an upgrade for the v2 SC.
and what is the formula to calculate what the sc is sppining @ w x.xx size pulley.
thanks
frank
Old Feb 11, 2005 | 04:13 PM
Blu's Avatar
Blu
the tits
I can answer the first question for you...V1 T-Trim I'll be getting mine back next week finally. My only worry is being able to run a smaller pulley than a 3.12 bc of belt slippage with the stronger blower.
Old Feb 11, 2005 | 08:07 PM
chris'smax's Avatar
How much more effecient is the t-trim from the sq trim? Also how much did they charge?
Old Feb 11, 2005 | 10:34 PM
slimer's Avatar
A couple of Blaxxx's? Lawls.
blu, i would like to know about an update when you get one.
the possibility of a t-trim is enticing
Old Feb 11, 2005 | 11:58 PM
jdmmax's Avatar
the belt on with 2.87 pulley is slipping @~ 6k
im gonna try a kevlar belt as soon as i get it. currently on order.
i tenisoned it down some more as soon as the rain lets up ill give it a whirl. at sat there with a ruler and a stright edge and tensioned it to exactly 1/4 defection. and i noticed that the belt i have on the blower right now im at pretty much at the limit that it can be tensioned to.
the kevlar belt is said to be alot stronger with i believe 3 times the grip. IIRC
when i take off the air filter there is a good amont of oil build up at the intake side of the compressor. i think i may need a rebuild soon.
question does the t-trim head units use the same compressor housing ??? anyone??
Old Feb 12, 2005 | 05:23 AM
Blu's Avatar
Blu
the tits
yes they use the same housing and upgrade all the internals...bearings, impellar etc etc.
Its also odd you are at the limit of the belt tension with the 2.87 pulley. I would definately try a gatorback belt or something to that nature bc I know plenty are running the 2.87 without problems.
Old Feb 13, 2005 | 04:06 AM
jdmmax's Avatar
well the gator back does not have the size available.
im using a gates 6pk1785 i belive
the kevlar belt im gonna get is a 6pk1780 hopefully it works better.
Old Feb 13, 2005 | 07:37 AM
Blu's Avatar
Blu
the tits
cool, let me know how that belt works out. If it does work without slippage and holds strong I might give it a shot on the t-trim. Im going to need all the grip I can on the little 6 rib pulley to turn this blower.
Unclejunebug
Apr 2, 2016 05:42 AM
Stagnet04
Oct 11, 2015 08:16 PM
Socalstillen
Sep 26, 2015 12:01 PM
