Just bought 2.87 pulley now need advice!
Old Feb 16, 2005 | 08:38 AM
chris'smax's Avatar
now I had the 440cc Rc injectors but i had to take them back in order to pay for books(costed more than i thought they were going to cost ). Now i am torn between Power Enterprise 510cc and the RC 440's. If i plan on taking out the FMU and t-rex and using a SARD FPR to lower base fuel pressure. Which one can i run with tunning with the SAFC ?
Old Feb 16, 2005 | 09:07 AM
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
Chris...Chris...Chris...
1)Fix your boost
2)Dyno
3)Tune
4a)If you want 440cc/510cc, so you can dump the FMU, GET THE EMANAGE. Nobody has done what you're planning, so you could run into issues.
4b)If you want to stick with the SAFC, you can buy BRAND NEW PE380cc for $400, but you'll need to keep your FMU and FPR.
Old Feb 16, 2005 | 12:45 PM
chris'smax's Avatar
1)Fix your boost
2)Dyno
3)Tune
I am going to dyno, that is why i want to get everything on before so i only have to dyno once. Just ordered the hotshot headers also today so that is going to a fun day installing those .
My setup now is as follows:
V2 w/2.87 pulley and CAI
2.5 wsp exhaust
Hotshot Headers
ATP 3" exhaust cuttout
UR lightned pulley
SAFC 2
SARD FPR
So would 440cc injectors have enough room to run all this with out the FMU and TREX or would i have to go 510cc?
Old Feb 16, 2005 | 12:57 PM
IceY2K1's Avatar
I understand the attempt to get EVERYTHING done and then go to the dyno to save money, however with all that stuff, you'll probably end up with an "issue" on the dyno that kills any valid tuning anyways, ie broken VIAS(you checked lately?), too large a FMU disc, Trex not working, SAFC not able to compensate enough, yada yada.
IMHO, it is better to make small incremental BABY steps or at least group mods together. That way if something goes wrong, it is easier to trouble shoot and you don't waste whole dyno days/trips.
Anyways, the 440cc injectors assuming stock fuel pressure, 20% driveline loss, conservative SCers BSFC of 0.55, and at a safe recommended(but rarely seen) 80% injector duty cycle, they'll support ~293whp. At a NOT recommended 100% duty cycle, they'll support ~366whp.
Old Feb 16, 2005 | 01:29 PM
dadiesel's Avatar
I have a few questions about this whole fuel management thing. 1) Would 380cc or 440cc injectors be necessary w/ 3.25 pulley, SAFC II, at stock puel pressure? 2) Can duty cycle be adjusted or is it automatic depending on injector size?
Old Feb 17, 2005 | 10:47 PM
chris'smax's Avatar
Ok i just bought Power enterprise 510cc injectors. So now the question remains can ithrow out the FMU now and do i need a walboro intake pump or a adj FPR
Old Feb 18, 2005 | 07:59 AM
IceY2K1's Avatar
Mind me asking where/how much?
No FMU that's for sure, Walbro would be GOOD insurance and for $90 it's cheap insurance.
I doubt you'll need an adjustable FPR, however with the Walbro increasing idle fuel pressure, the eManage might not be able to pull enough fuel during cold starts. You could always wire a push button starter like Mardi/S2000s have.
Old Feb 18, 2005 | 08:10 AM
IceY2K1's Avatar
Oops, I forgot you're still not planning on the eManage, correct?
MAYBE, the AFPR and pushbutton will work with the SAFC, not sure though.
Old Feb 18, 2005 | 08:53 AM
chris'smax's Avatar
No i forgot to mention that i plan on getting the emanage . Got the injectors for $415 shipped brand new on ebay
Old Feb 18, 2005 | 08:57 AM
IceY2K1's Avatar
DAAAAAYYYYM....great price...I paid more and they're used.
Old Feb 18, 2005 | 09:09 AM
Blu's Avatar
Blu
the tits
link? thats a steal
Old Feb 18, 2005 | 09:10 AM
chris'smax's Avatar
Alex this is what yours look like? I know when i saw the price it made me skeptical but then again i was the only one to bid on them
Old Feb 18, 2005 | 09:32 AM
IceY2K1's Avatar
Yep, damn steal.....you finally got a break.
Was it just a guy selling one set or a shop?
Old Feb 18, 2005 | 09:35 AM
chris'smax's Avatar
No i think it is a girl that is selling them .
Don't worry they probably wont work and once again chris gets screwed
IceY2K1's Avatar
Used PE380cc are common, since 350Z guys are upgrading.
New PE380cc show up every now and then, but they want $400+.
I've only seen one set of PE510cc for sale and they were used, so I snapped them up.
I've never seen a new set of 510s for sale except from vendors at $800 or so.
You got a STEAL as blu said.
Old Feb 18, 2005 | 09:39 AM
chris'smax's Avatar
Use PE380cc are common, since 350Z guys are upgrading.
I've never seen a new set of 510s for sale except from a vendor at $800 or so.
So should i be skeptical about this, i mean i still have to pay for them in the next couple of days. Her feedback rating was flawless so
. Maybe she was just hoping people would bidd on them up close to cost
Old Feb 18, 2005 | 09:43 AM
IceY2K1's Avatar
No................
Old Feb 18, 2005 | 09:44 AM
IceY2K1's Avatar
Here's a pic of one next to OEM:
Old Feb 18, 2005 | 11:07 AM
mhadford's Avatar
Has anyone done a write-up on e-manage installation for 5th gen?
I'd love a bit of guidance...
Old Feb 18, 2005 | 11:25 AM
IceY2K1's Avatar
No, however minus the injector and ignition harness, it's the same as the SAFC as far as wiring.
What are you having a problem with? Wiring? Settings? Support tool?
Old Feb 18, 2005 | 11:27 AM
chris'smax's Avatar
How bout everything except the main unit wiring
Old Feb 18, 2005 | 01:40 PM
mhadford's Avatar
I have the e-manage, the injector and ignition harnesses, and support tool and I have perused the instructions. I still need to buy the special link cable, but that should come shortly. Apparently I first need to set some dials to tell it how many cylinders I have, airflow sensor type, etc.
Then I need to figure out the wiring or pinout on the ecu to splice in the harnesses. Then hook up the support tool, and tune tune tune. I got the emange to go with some rc440 injectors, not yet installed.
So I guess the info I need is the dial settings and ECU wiring for a 2000 SE; plus any advice about wiring and tuning. I think I read that some diodes or resistors need to be wired into the ignition harness to prevent blowing coils? What diodes and where?
Thanks in advance for any advice you can contribute.
Old Feb 18, 2005 | 05:38 PM
chris'smax's Avatar
I will be getting mine monday so maybe we can help each other out "the blind leading the blind". I am going to be so lost trying to get a roundabout tune just so i can get my car to the dyno which is 2 miles from my house!
BkGreen97
Apr 2, 2016 05:47 AM
DarjeelingRose
Sep 15, 2015 01:20 AM
hntwhttail
Sep 12, 2015 03:43 PM
Violator
Sep 9, 2015 10:14 AM
Johnny9595
Sep 3, 2015 05:18 AM
