wonding what kind of spool time I would see
Old Feb 17, 2005 | 02:16 PM
95turbo gxe's Avatar
I got a vg 3.0 with a 9:1 ratio.im wondering what kind of spool time I would see with this charger. I get full boost now at 2700 to 3000 rpms. And would this make more power at the same boost level that im at now. Oh yeah by the way im running a stock CT26 from a supra.http://cgi.ebay.com/ebaymotors/ws/eB...spagename=WDVW
Old Feb 17, 2005 | 10:46 PM
subs1000w's Avatar
i would read this before buying a turbo form them
http://www.honda-tech.com/zerothread?id=1097918
back to weather it would work or not im gonna say NO!
1.05 A/R TURBINE HOUSING
GREAT FOR RAPID SPOOL!
rapid spool MY A$$ maybe on a big block
you need to look for some thing with a MAX of .81 A/R on the hot side preferably smaller if you want good street manners
i would look into this one it would suit your car almost perfectly and i would estimate full boost between 3.5 and 4k and it would leave the CT26 in the dust plus its a genuin garret turbo and not a nockoff that could literally fall apart
http://cgi.ebay.com/ebaymotors/ws/eB...954861674&rd=1
Old Feb 18, 2005 | 09:10 AM
Bags's Avatar
VG Ridah's Biatch Hoe
holy shiet... I'll be reading that entire thread and may make a sticky.. thanks for the info
Old Feb 18, 2005 | 09:20 AM
DA-MAX's Avatar
Eat, sleep, and sh*t 2JZ
ssautochrome saying that name to any turbo Honda owner is like calling their mom a *****
Old Feb 18, 2005 | 12:01 PM
Bags's Avatar
Yes, i saw that... wow..
seems like his customer service is decent now that people filled a lawsuit and threatened to kill him..lol
Old Feb 18, 2005 | 02:31 PM
mtcookson's Avatar
on top of the turbine being way to big, the compressor is actually a bit large for the VG engines. if i remember correctly it would surge quite a bit on our engines. ve/vq might handle it pretty well though...
Old Feb 18, 2005 | 05:29 PM
Aaron92SE's Avatar
NWP Engineering.com
I'm glad I found this Honda-Tech thread! I was seriously thinking about buying their turbo! I didn't realize it was so cheap. What other brands can I look into that have proven to be great? Turbonetics? I know Garrett is the best. But are their cheaper alternatives that won't crack apart like this? lol
I have pretty much made up my mind on a smaller type turbo so i can easily make boost out of the hole with a 3000 rpm stall. I am leaning towards a .63 A/R t3 with a t04e .60 or .50 A/R with a 50 to 60 trim. I figured a 50 trim will spool nicely, but I don't know if I will lose power on the top end of each gear. But I figured that it would be easy to change turbos in the future after I have some time to mess around with a cheap ebay one.
Old Feb 18, 2005 | 05:33 PM
Bags's Avatar
Several IS300 folks are running masterpower turbos... Turbonetics is ok, not my personal fav.
Old Feb 18, 2005 | 05:46 PM
Aaron92SE's Avatar
NWP Engineering.com
Thanks. Is this the correct site? http://www.masterpower.com.br
Old Feb 18, 2005 | 05:55 PM
Bags's Avatar
Yeah that's it.. IIRC, they got them in a turbo kit from toyomoto in FL.
Old Feb 18, 2005 | 06:13 PM
Aaron92SE's Avatar
NWP Engineering.com
I did a little quick searching and it seems that Masterpower is in the same boat as XS Turbos. Do you have any thoughts on this?
What turbos have you personally had experience with? Thoughts?
Little something I found when searching for masterpower turbo: http://www.redz31.com/pages/turboupgrade.html
Old Feb 18, 2005 | 06:50 PM
Bags's Avatar
Turbonetics is the only brand I have owned, I have 2 of them. My next one WILL be a garrett.
Good info there as well.
Old Feb 18, 2005 | 08:16 PM
subs1000w's Avatar
i would read this it should clear up the masterpower debate
http://www.turbomustangs.com/forums/...ht=masterpower
"As long as you stay away from the ebay dealers, which some of them have been known to use Master Power housings with cheaper internals that will prematurely fail 99% of the time you'll be alright."
if you search masterpower on there site there are lots of people that have had great sucses with them
MatthewsMaxima
Sep 11, 2015 03:21 AM
soloist3
Sep 2, 2015 12:59 PM
FlaMark
25
Aug 28, 2015 10:15 AM
Tanvirkamal
Aug 5, 2015 01:32 AM
