need help please!!
Old Feb 23, 2005 | 12:33 PM
pfactor172's Avatar
need help please!!
First off thanks for looking. I have a problem with my car on the highway when I am at 55-80 mph. at a steady pace my car hesitates or feels like its surging or misfiring its hard to decribe.It only dose it when I am holding a steady speed or letting off the gas to slow down. The car starts up fine and idles normal at 600 rpm with out bouncing. I think it might be the MAF. I don't think it could be an intake leak because it dose idles very good and starts normal any suggestions on what I should check? thanks in advance
Old Feb 23, 2005 | 12:41 PM
Stephen Max's Avatar
Are you boosted?
Old Feb 23, 2005 | 02:48 PM
pfactor172's Avatar
yes runing a v2 and a ypipe.
Old Feb 23, 2005 | 03:03 PM
maxlinegtr's Avatar
I think u are leaking air somewhere. check your joints and piping..I had the same issue when i ran an NSX on the freeway...it feels like it is bogging at certain speeds, and almost feels like misfiring like almost a blown motor. check all the pipings & your MAF
Old Feb 23, 2005 | 04:44 PM
Nealoc187's Avatar
SLOW
Do you have emanage? I get this same thing with emanage between 80-85mph in 5th (actually its RPM dependent, it will happen in other gears at that rpm range). Sounds similar, but I doubt you have emanage so it's probably a totally separate issue with similar symptoms.
Old Feb 23, 2005 | 04:58 PM
pfactor172's Avatar
No I don't have any tuning or tuning device just what came with the stillen kit and a ypipe my car already had.The car was running good for 21/2 weeks or so just started doing this a couple days ago I will have to check for intake leak I just pulled the blower off last weekend to replace a broken belt might have left something loose? BTW is there an alternative to the crossover pipe that puts the MAF and air filter under the battery?
Old Feb 23, 2005 | 11:33 PM
vortechpower's Avatar
Yeah, thats a cold air intake that you would cut a hole in the fender for. Maybe your belt is loose or your bov is not tight enough. What bov do you have?
Old Feb 24, 2005 | 07:10 AM
Broaner's Avatar
2060lbs and falling...
Belt slip seeing as that is the only variable you recently altered. Check that.
