Fuel leak
Fuel leak
Been messing with my defi electronic fuel pressure gauge all afternoon. I keep gettig a leak at the T-fitting. The hose ends are fine, but where the sensor goes into the T-fitting I am getting a pretty bad leak.
I am using teflon paste, the directions say teflon tape...don't know if that is the problem
I tried using the PT-NPT adapter that comes with the gauge and it did not leak for a little while then it started again.
What to do?
What to do?
I think you need to crank on it more. Oh yeah...what kind of teflon paste? They do make a huge difference. I tried atleast 4 kinds of paste with my nitrous system which exceeds more than 1400 psi. The one that came in a jar with brush worked the best. I got it at home depot. The ones come in the tube wouldn't hold the nitrous pressue even though the spec said it would. I believe the name is Hercules teflon paste.
I have permatex. It is in a jar with a brush.
Looks like the tape did the trick. I think the paste has to cure. But no leak for now. The car has been running for 10 min and so far so good.
Originally Posted by crewchief264
I've never heard of or seen teflon paste!! And I 've been working on cars for 15 years and planes for 6. All I've ever used on either is the tape why stray from what works-- just a friendly suggestion.
litch
123
Jan 4, 2024 07:01 PM
jmlee44
Oct 2, 2022 02:13 PM
Forge277
Jun 13, 2016 09:26 PM
