Install pics
Old Mar 13, 2005 | 06:36 AM
I30tMikeD's Avatar
Install pics
I will just keep all the pics in this thread.
http://img.photobucket.com/albums/v1...d/113_1325.jpg
http://img.photobucket.com/albums/v1...d/113_1324.jpg
Ran into a few problems yesterday. I need to shorten the down pipe where it meets the cat, weld some pin size holes on found on the up pipe, and figure out how to support the turbo. Nothing big, I expected this stuff to happen. Just sucks it is sunday and I can't get the welding done.
There is a rod welded to the feed pipe that is obviously for a hanger, but need to figure out where to put it. Here is a pic, any suggestions are welcome
http://img.photobucket.com/albums/v1...d/113_1323.jpg
Old Mar 13, 2005 | 07:52 AM
chris'smax's Avatar
It looks like the install is coming along great. That intercooler looks really sexy.
Old Mar 13, 2005 | 08:05 AM
slimer's Avatar
A couple of Blaxxx's? Lawls.
looks like there is a bolt hole directly about it. how about there? Looks great mike, just dont forget to hook all the vacuum lines up again.
are you going to connect the crankcase vent to the non charged side? my suggestion would be to put the evap line on the non charged side too. I ran into emissions problems with mine hooked up to the charged side.
Steve
Old Mar 13, 2005 | 09:09 AM
|Bijan|'s Avatar
UCF Lexus
Doesnt the down pipe support most of it? I know this isnt the PFI kit, but almost same concept...IIRC, the down pipe does support most of the weight, and then a bracket was welded on the downpipe to something else.
|Bijan|'s Avatar
UCF Lexus
Oh yea, install is looking great, hope everything goes as planned for you. YGPM
Old Mar 13, 2005 | 10:42 AM
96_vqmax's Avatar
Looking good,the intercooler fit the opening pretty nice.
Old Mar 13, 2005 | 07:15 PM
I30tMikeD's Avatar
Old Mar 13, 2005 | 07:28 PM
I30tMikeD's Avatar
Had some problems today.
The car that this kit was originally made for did not have ABS, so my ABS got in the way of the pipe going to the compressor. This threw everything off and my down pipe would not clear the radiator fan. Spent the whole day getting around this problem. luckily a friend of a friend helped with some welding
also, I am pretty sure this exhaust was made without the use of a cat. As in the end of the down pipe just bolted to the b-pipe. Had to cut and weld there to. Then forgot about my test pipe having cocked flanges so it will have to be redone latter this week.
But by the end of the day the turbo is mounted and all problems were solved. I should be home clear free here hopefully. Should be able to fire her up by tuesday night or first thing wednesday.
Old Mar 13, 2005 | 08:12 PM
bobbydigital450's Avatar
intercoolers look so sweeet. nice work bro... where are u putting your blow off valve?
Old Mar 13, 2005 | 08:13 PM
MAXimumHP's Avatar
Did you get the turbo bolted in place tonight?
Old Mar 13, 2005 | 08:18 PM
BriGuyMax's Avatar
This is Neal, yes we did.
Old Mar 13, 2005 | 08:22 PM
MAXimumHP's Avatar
sweet, have fun tomorrow.
Old Mar 14, 2005 | 05:07 AM
I30tMikeD's Avatar
Fitment is too tight to not have everything secured. I now have the turbo bolted down to a bracket in the engine bay. Still have room for movement with my flex section, the turbo just ain't movin
Old Mar 14, 2005 | 05:45 AM
C MAX's Avatar
wow good luck with your project, i dont know much about turbos to help but it looks good so far. cant wait to see some numbers
Old Mar 14, 2005 | 11:42 AM
I30tMikeD's Avatar
http://img.photobucket.com/albums/v1...d/113_1329.jpg
http://img.photobucket.com/albums/v1...d/113_1330.jpg
http://img.photobucket.com/albums/v1...d/113_1331.jpg
http://img.photobucket.com/albums/v1...d/113_1332.jpg
http://img.photobucket.com/albums/v1...d/113_1333.jpg
http://img.photobucket.com/albums/v1...d/113_1334.jpg
Old Mar 14, 2005 | 11:48 AM
Kevlo911's Avatar
Kevlo for President
Cool pics
Old Mar 14, 2005 | 12:58 PM
MAXimumHP's Avatar
Looks like you got quite a bit done, gonna be on the streets by tomorrow?
Old Mar 14, 2005 | 05:59 PM
I30tMikeD's Avatar
yhea, things started flying by after we got the whole turbo mounting and piping figured out. I did break on of my oil pan bolts....we will see if it leaks but I doubt it will
I will be done with the install tomorrow, but I imagine there will be some bugs to work out. Hopefully I will get to drive it by tomorrow night
Old Mar 14, 2005 | 07:05 PM
Brad92SE's Avatar
Mike, looks like its going well, you work fast! I broke one of my bolts too, just fill the hole up with silicone, you'll be fine. I can't wait to see the finished product! By the way, I'd be leary of that bend right before the MAF... I just found out tonight that my rough idle is being caused by a bend right before my MAF, so I need to redo my intake piping this weekend.
Old Mar 14, 2005 | 08:20 PM
stephenlc's Avatar
good luck hopefully everything works out.
Old Mar 15, 2005 | 07:59 PM
I30tMikeD's Avatar
She is done!!!!! Started right up and ran great. Have not driven it, still need to put the FMU in and put the bumper back in. She will be on the road tomorrow. I am sooo tired but very happy. Started Friday afternoon and finished Tuesday night, working 14 hrs a day on it.
http://img.photobucket.com/albums/v1...d/113_1342.jpg
Old Mar 15, 2005 | 08:05 PM
Brad92SE's Avatar
Awesome Mike, congrats!! It sure is a good feeling to hear it start, and sit back and enjoy the fruits of your labor, isnt it?
Old Mar 15, 2005 | 08:34 PM
slimer's Avatar
it really looks great!
Old Mar 15, 2005 | 09:08 PM
BriGuyMax's Avatar
can't wait to see it all put together tomorrow man! What time do you plan on starting tomorrow? Maybe I'll stop by and help if I actually get up. :P
Old Mar 15, 2005 | 10:52 PM
I30tMikeD's Avatar
You know me, I will be out there before 8am. Just call, I am sure I will be in the garage.
Old Mar 16, 2005 | 02:36 AM
ivolley's Avatar
Congrats, looks good
Old Mar 16, 2005 | 03:49 AM
C MAX's Avatar
woo hoo!!! welcome aboard fellow booster. hope you enjoy many butterflies in the belly
Old Mar 16, 2005 | 04:11 AM
96sleeper's Avatar
poor little radiator hose looks like he might be an early casualty. The pic makes it look like it is right on the exhaust piping. Other than that looks good.
Old Mar 16, 2005 | 05:10 AM
deezo's Avatar
Good for you Mike. Now get the sucka tuned right and have some fun with it.
Old Mar 16, 2005 | 05:30 AM
I30tMikeD's Avatar
The down pipe? That one is an optical illusion, the down pipe and that upper radiator hose have a good 2" clearance. The down pipe starts going down right after the v-band. Now,There are two places where the intercooler piping is touching a radiator hose but I am not too worried about that.
The two places I am worried about are where the intercooler piping is a 1/2" from the exhaust side of the turbo. I put heater wrap on one spot of the down where a silicone coupler from the intercooler piping rests really close.
I plan to monitor things very closly in the next few weeks and I am sure a little adustment might be necessary.
I am also worried about ground clearance. I sure can't go with any lower of a drop. Looks like I lost about 2" of clearance, won't know how much of a problem it will be till I actually get the car on the ground. I can raise the turbo from its mounting location about 1/4"-1/2" by installing some metal plates which will bring both the down pipe and reverse y-pipe up a bit.
I recently met a guy who does some fabricaton work on the side. He has got a lift and and a tig welder at his house. I may talk with him over the summer about redoing my exhaust piping. I think I can keep my turbo location and get rid of about 3'-4' of piping and gains some ground clearance.
Old Mar 16, 2005 | 03:33 PM
Nealoc187's Avatar
SLOW
Shawn (Shaun? Sean?) has a mig and tig, he just didn't have the mig there that day it was at his work.
Old Mar 16, 2005 | 05:41 PM
MAXimumHP's Avatar
Sweet! Glad to see it's all in and running.
Old Mar 16, 2005 | 08:39 PM
I30tMikeD's Avatar
Took her for a couple drives today. One time the mid-pipe came off the MAF and the other an intercooler pipe seperated. Freaked me out both times. I am running open headers at the moment till I get to an exhaust shop tomorrow. It is just too damn loud to be driving like that so I will wait and go have some more fun after I get the exhaust done.
I did break my tires loose at the top of second though
Old Mar 16, 2005 | 08:54 PM
96_vqmax's Avatar
Good to hear everything work out for you.
Old Mar 16, 2005 | 08:58 PM
Nealoc187's Avatar
SLOW
It's called a downpipe when you are turbo not open headers lol
Old Mar 16, 2005 | 11:24 PM
maximaintheface's Avatar
sounds promising. sucks u live in IL i have 2 welders too. sorry
Old Mar 17, 2005 | 06:52 AM
JamesNH's Avatar
when i saw open headers i was wondering how you where getting boost
Old Mar 17, 2005 | 08:16 PM
il99max's Avatar
Looking good Mike. Say, I didn't see your MEVI on the car. Did you sell it already?
Old Mar 17, 2005 | 08:24 PM
|Bijan|'s Avatar
UCF Lexus
Hey Mike.....can you post a couple pics showing how low/high the pipes are from the ground?
Old Mar 17, 2005 | 09:54 PM
I30tMikeD's Avatar
Yhea, I sold all my previous mods to help fund the turbo. I will do an MEVI or 00VI in the near future though.
