Another Turbo Max (pics inside)
#81
Originally Posted by Brad92SE
Also, once you get tuned somewhat properly, I would like to know if the top end starts to diminish above 6K with this turbo. I doubt it would. Thanks.
#82
Originally Posted by Aaron92SE
So it spikes lean while you're WOT? I would be VERY careful. If it goes leaner than 13:1, I would worry about it. I know the ZEMulator would solve your issue, but I know that doesn't help your current situation. I wish I could help more.
#83
At WOT yes, but it does it sometimes at 3/4 throttle too. I'm thinking its a bad reading though, since my guess is that my engine would have nuked by now if it were running a 40:1 AFR, even for a couple seconds.
This multimeter thing is the same thing as putting a ricer air/fuel gauge in your car, just minus the fancy light show. In order to get the correct voltage, you can simply tap into the "o2 sensor" wire that is coming out of your ECU harness connector. You'll have to look at your FSM to find out which wire to tap into. You can use one of those inline wire taps that snap in place (18-21 ga will work). Those work great.
#84
Low voltage is lean. I read .128v usually at idle on the low part of the fluctation. I don't remember sense its been so long since I sarted this thing. I think it doesn't fluctuate much for me at idle. I'll look at some logged idling tonight. I sometimes get 1.5v right when the throttle snaps shut. Thats also when I get flames out the pipe. This is where an OBD reader comes in handy.
#85
lowpost99
09-08-2015 05:06 AM
