95-01 Nissan Maxima 3.0L DOHC Street Charger Crank Pulley???
Old Mar 15, 2005 | 12:28 PM
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
Anybody know what the UR Sc pulley for the Maxima underdrives, if anything?
Per the website:
12-Volt Charger Series (Ultra Sc)
Many of our customers have asked for pulleys that do not underdrive their alternators. Some audio competitions require that voltage remain at the factory levels. With our new 12-Volt Charger Series, the alternator is left to spin at stock levels or is spun with a slight overdrive. The remaining accessories are still underdriven (excludes accessories driven off the same belt as the alternator) for additional power gains
Some aftermarket supercharger systems are driven off the alternator section of the Acura/Honda crank pulley. With our 12-Volt Charger Series crank pulleys, boost levels are maintained. For the B-series Acura/Honda engine applications, our 12-Volt Charger Series crank pulleys act as a slight overdrive, providing a slight increase in boost. Typical boost increases are 2 to 3 psi over a stock supercharger kit for the Acura Integra and Honda Civic Si. It is highly recommended that a high flow fuel pump and a boost dependant ignition system with retard control be installed in these applications. All of our 12-Volt Charger Series crank pulleys are available in a natural polished aluminum finish only.
Old Mar 15, 2005 | 03:12 PM
Requin6's Avatar
i think its just lighter....same diameter as stock though.
--Paul
Old Mar 15, 2005 | 03:17 PM
vortechpower's Avatar
Yes, there was a post about this around 1 or 2 months ago. Interesting. I have been told by some knowledgable ones that this is a good thing to have.
Old Mar 15, 2005 | 03:37 PM
IceY2K1's Avatar
Any way to confirm that it doesn't underdrive or overdrive ANYTHING?
Old Mar 15, 2005 | 04:14 PM
Only that it is the same size as stock. It is the same as a lightened fly. Less weight to turn. As long as it is the same size as stock it shouldnt do anything other than cut back on weight the crank has to spin.
I think it was StephenMax that said the gains are probably seen in the lower gears, probably up through 3rd. Once you get it spinning at say just as an example (no factual info here) 80mph there would be no benefit because the crank would have overcome the initial weight of the pulley. Some equations and math I can't explain.
Old Mar 15, 2005 | 04:16 PM
IceY2K1's Avatar
Are you saying it is EXACTLY the same size as stock?
That IS my question.
Old Mar 15, 2005 | 04:19 PM
Now I don't know about this UR pulley. The example I was using and the one the post was refering to was not a UR pulley. Let me go searching.
It was infact a UR pulley. Was not sure so....
Y2KSESteve's Avatar
According to UR, yes they are identical sizes as oem.
Old Mar 15, 2005 | 04:21 PM
IceY2K1's Avatar
Thank you Steve.
Any chance you have the two laying around to compare?
Old Mar 15, 2005 | 04:22 PM
http://forums.maxima.org/showthread.php?t=367903
Unorthodox Racing Ultra S Street Crank Pulley #021001001 in Black
$174 shipped
They usually have the black ones instock. They are also available in Red, Blue, or Polished but those colors will sometimes take about a month.
Ultra Sc 12-Volt Charger Series Crank Pulley #121001012 Polished Only
$184 shipped
Old Mar 15, 2005 | 04:31 PM
So what is the difference between the two?
Ok, 12 volt charger pulley must be for the alternator . Right?
Old Mar 15, 2005 | 04:41 PM
SPiG's Avatar
SomePsychoGuy
I know chris's max just got one. I didn't get a chance to look at it but it SHOULD be the same size as stock. It would be nice if it underdrove the power steering belt but kept the stock size for alternator, a/c, and SC Belt.
I did find a post however that says that the alt, a/c, and SC pulley is slightly smaller, thus underdriving. It could just be the picture or some error on UR's part. http://forums.maxima.org/showthread.php?t=304010
If it was really a problem I guess you could go down one more pulley size and compensate.
Old Mar 15, 2005 | 04:47 PM
slimer's Avatar
A couple of Blaxxx's? Lawls.
wouldnt that increase belt slippage though, less contact with the pulley surfaces?
Old Mar 15, 2005 | 05:05 PM
chris'smax's Avatar
i will let you all know how it turns out and post some comparison pictures when i install it this week
Old Mar 16, 2005 | 03:34 PM
ptatohed's Avatar
Licensed to Spell
:o)
Ice, I received mine a few weeks ago. I beleive this is the answer to your question:
On the same crank pulley, there are two pulleys, using two different belts. The pulley that takes the path of the alternator, supercharger, etc. is NOT under nor over driven. It is 100% stock diameter (6.4" I believe?). The gains come from the lightened weight. The other pulley which takes the path of the power steering, etc. is smaller/underdriven.
Hope that helps.
Old Mar 16, 2005 | 06:23 PM
dadiesel's Avatar
Hope that helps.
So which of these 2 pulleys does the Ultra Sc 12-Volt Charger Series Crank Pulley replace?
Old Mar 16, 2005 | 06:40 PM
ptatohed's Avatar
Licensed to Spell
:o)
Both! That's what I was trying to say. There are two on one. Does that make sense?
I'll try to get some pics if it helps. Also, you can easily get under your car, pull back the plastic shielding and see what I am talking about.
Old Mar 16, 2005 | 06:55 PM
ptatohed's Avatar
Licensed to Spell
:o)
O.k., I am too nice to you guys. I remembered I had a scan of the FSM on my cardomain. I tracked it down. Here it is. I think this will explain everything.
Old Mar 17, 2005 | 04:52 AM
chris'smax's Avatar
It looks like this. There is the drive pulley and then connected to the rear face of the drive pulley is smaller pulley. It looks like a step design if that makes any sense
Old Mar 17, 2005 | 07:09 AM
LatinMax's Avatar
OK. I will clarify:
I have had this pulley for about 18 months. It is exactley the same size as the OEM pulley except it is lighter and brushed aluminum.
And yes are pulley are 2 in one. One for the power steering pump and on for eveything else including the SC.
I never dynoed but the car got to redline much quicker and started spining the tire when my auto would shift from 2nd to 3rd.
NOTE: This was with my 3.125 pulley and it was the only change that was done.
Old Mar 17, 2005 | 07:51 AM
Blu's Avatar
Blu
the tits
I think I'll have to get this when I do the buildup...
Old Mar 17, 2005 | 07:53 AM
ptatohed's Avatar
Licensed to Spell
:o)
Originally Posted by LatinMax
OK. I will clarify:
Latin, so was I correct by saying that the smaller pulley for the power steering is smaller in diameter than stock? I have not compared it to stock, I am only going by what the accompanying Unorthodox Racing instructions read (I didn't know this until after my purchase because they don't say it on the website). Do you feel a difference in steering? Did you need a smaller belt for the PS? Thanks.
P.s. The instructions are awesome by the way. Very professional. You get an 8.5x11 piece of paper with one side being their company pledge to the customer. On the other side is a full set of instructions for our actual car and the actual part we ordered! Not generic. They thank you for buying, they ask for feedback, discuss warranties, etc. Customer service, what a concept. Oh, they even throw in a few stickers.
Old Mar 17, 2005 | 12:36 PM
That is rare!!
Old Mar 18, 2005 | 05:00 AM
chris'smax's Avatar
ptatohed, how long did it take for you to get your pulley from import plus? It has been 2 weeks since i ordered mine and i will finally be getting it today. I called them wednesday to ask what the deal is and the guy said, "oh it will be shipping out today", in other words they forgot to ship it and remembered when i called them
Old Mar 18, 2005 | 07:46 AM
ptatohed's Avatar
Licensed to Spell
:o)
I got it pretty quickly chris. Under a week, I beleive. ...But it doesn't matter, I'm the king of ordering parts and storing them for months (or even years) before installing them. My garage rafters are stuffed with un-installed parts.
Old Mar 18, 2005 | 08:14 AM
chris'smax's Avatar
ha, you are the complete opposite of me. I have to install it as soon as i get it
Old Mar 18, 2005 | 09:05 AM
ptatohed's Avatar
Licensed to Spell
:o)
That's good. I wish I was that way. I'm so bad that I'll order something, store it for so many months that something better comes out and I end up buying the new product (and store it of course - lol). I can't tell you how many things I bought for my '96, never installed them and are now null and void due to my '99 purchase (ex. front/rear '97/'99 bumper covers). :doh:
Old Mar 22, 2005 | 09:06 AM
IceY2K1's Avatar
Very much...thanks~!
Hope that helps.
Old Mar 22, 2005 | 09:22 AM
ptatohed's Avatar
Licensed to Spell
:o)
My pleasure.
LatinMax never answered me. Can anyone confirm that the power steering pulley is smaller than stock? Can anyone who has installed it say if they noticed any change (good or bad) in the steering?
I looked at the instructions again and they say to use the stock length PS belt so I imagine it isn't underdriven that much.
Old Mar 22, 2005 | 08:24 PM
dadiesel's Avatar
Do they include a belt with the purchase?
Old Mar 22, 2005 | 09:10 PM
slimer's Avatar
does anyone know the crank size of the udp?
Old Mar 22, 2005 | 09:31 PM
slimer's Avatar
found it.
i have a couple of ?s though
The stock is 6.5 and the 2.87 pulley overspins the blower a little.
With a UDP (5.25) and a 2.62 pulley the impeller speed is 44935.59.
wouldnt this give a respectable amount of boost.
I am fully aware of the less contact area, but playing devil's advocate.
Old Mar 22, 2005 | 10:10 PM
MAXIN's Avatar
A UR rep told me few months ago that instead of underdriving the alternator it underdrives the power steering. He also said something like atleast 70% of any 'gain' in power comes from the lightweight aspect. The rest from the size. So both pulleys should peform similar. The alt belt is same size as stock, the ps belt that UR recommends is the same as the ps belt for the smaller pulley which is slightly smaller then stock.
Old Mar 23, 2005 | 07:39 AM
ptatohed's Avatar
Licensed to Spell
:o)
No, but if you were reading this thread carefully, you would know you don't need one.
xUNIxPanther
Aug 27, 2015 10:09 PM
District
Aug 15, 2015 08:23 PM
Wolvee
Aug 11, 2015 12:24 PM
julian888
Aug 6, 2015 04:39 AM
julian888
Aug 5, 2015 08:26 PM
