To those with SC alignment issues
Old Mar 15, 2005 | 11:16 PM
slimer's Avatar
A couple of Blaxxx's? Lawls.
have you seen these?
http://cgi.ebay.com/ebaymotors/ws/eB...ategory=33741f
Old Mar 16, 2005 | 08:44 AM
BlackCat's Avatar
RIP '98 Maxima SE
They look nice but, really, you can go to home depot/Pep Boys/NAPA shop and get washers. The ones I've got on are smooth, unlike in the pic, and are paper thin.
Old Mar 16, 2005 | 08:57 AM
slimer's Avatar
i just found them last nite.
Old Mar 17, 2005 | 07:44 AM
How common are these alignment issues? I'll be installing my SC next week, and it would be nice to know what to look for now and possibly fix the alignment issue right off the bat.(if I have one)
Or, does the alignment issue happen over time, and I'll have to wait and see?
Thanks.
James
Old Mar 17, 2005 | 08:47 AM
BlackCat's Avatar
RIP '98 Maxima SE
Its very common for the V2 system. I found shims on my blower when I did my first pulley swap from a 3.6" to a 3.33". Seems that the shop that installed my blower saw what was happening and added shims in to correct the belt alignment.
Old Mar 17, 2005 | 12:33 PM
vortechpower's Avatar
My brother has a v2 and never seen a problem. It still has the same belt since we put it on a year ago!
My v1 must not like to eat belts cause , well it never has. I have run my sc with only the 2 big bolts with no probs. Got lucky? I know I cant put my bracket on without the blower. It just doesn't want to match up the bolts. Seems like bolting the blower on the bracket causes it to flex or bend straight.
I have cracked every mounting post on the bracket thats the blower bolts go into. Had them welded and have been holding fine for 2 years.
Old Mar 22, 2005 | 03:02 PM
basevoid's Avatar
Should the shimms be the same width? I found three different width shims on mine and my belt has jumped the trk and shredded.
Old Mar 22, 2005 | 03:19 PM
slimer's Avatar
there may be other alignment issues. are you using every bolt?
Old Mar 22, 2005 | 03:22 PM
basevoid's Avatar
Every bolt on the plate except the short, fat center one. It looked like the 3.125 pully might rub against it.
Old Mar 22, 2005 | 03:54 PM
BlackCat's Avatar
RIP '98 Maxima SE
Ok, you've shaved off that center post for belt clearance like I did. That wouldn't cause the alignment problem.
Does the belt shift positions towards the body of the car and away from the engine block? If so, then you have to add some washer shims.
Old Mar 22, 2005 | 03:55 PM
BlackCat's Avatar
RIP '98 Maxima SE
My shims are all the same width. I think that's where your problem is.
First time I put my shims back on I loaded them on three uppermost posts. Found out very shortly that the belt wasn't happy and jumped a rib. I evenly distributed the three washer shims the second time around and my belt was happy.
Old Mar 22, 2005 | 03:56 PM
BlackCat's Avatar
RIP '98 Maxima SE
[QUOTE=vortechpower]My brother has a v2 and never seen a problem. It still has the same belt since we put it on a year ago!
[/ QUOTE]
Your brothers d*mn lucky!
Old Mar 22, 2005 | 03:58 PM
basevoid's Avatar
What width are your shims? How many do I need?
Old Mar 22, 2005 | 03:59 PM
slimer's Avatar
or take those others away.
alahjahwan09
18
Sep 21, 2015 09:12 PM
Bonka
Sep 14, 2015 11:18 PM
bbsitum
Sep 11, 2015 04:55 PM
dcam0326
Sep 8, 2015 11:02 PM
