Need help installing injectors.
Old Mar 21, 2005 | 08:26 AM
chris'smax's Avatar
Right now i am installing my injectors and I have all the fuel rail screws removed now and i still can't get the fuel rail to pop out. I pulled on it pretty good but i don't want to mess anything up by pulling to hard. Also how does the harness come off the injector?
I hate cars!!!!!!
Old Mar 21, 2005 | 08:43 AM
LatinMax's Avatar
Push down on the injector harness plugs with a flat screw driver. Then just pull up on the fuel rail and the injectors will come up & out rail and all. The have been in there for a while and wil be a liilte stuck sometimes, but just pull on the rail at each injector ona at a time.
Old Mar 21, 2005 | 10:07 AM
Bags's Avatar
VG Ridah's Biatch Hoe
I left the rail installed and just pulled out each injector. Hit them with some wd-40 and let it sit for 10 min the grabbed the top with some small channel locks and supn them left and right and poped them out
Old Mar 21, 2005 | 10:24 AM
chris'smax's Avatar
got it done. Now i just hope i got them seated correctly. If this car doesn't start up tommorow i am blowing it up
Thanks for the help guys
Old Mar 21, 2005 | 10:28 AM
Jeff92se's Avatar
I'm needing a caw
Remember to use new o-rings and lightly lube the o-rings with some oil before reinstalling the injectors. Or you run the risk of ripping/pinching the o-ring and causing a horrible gas leak.
Old Mar 21, 2005 | 10:37 AM
chris'smax's Avatar
already did that. Thanks for the tip though
Old Mar 21, 2005 | 12:01 PM
SPiG's Avatar
SomePsychoGuy
Wow you are getting some stuff done today. I will be over there after work to help you more on the headers.
Old Mar 22, 2005 | 12:57 PM
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
He's got top feed......
Old Mar 22, 2005 | 09:10 PM
Bags's Avatar
yall and your damn 5th gens mucking up the place
MaxLife17
Jun 27, 2019 01:37 PM
Excalibur23
Oct 13, 2015 04:33 PM
Max8
Sep 22, 2015 02:53 PM
2kmaximel
Sep 16, 2015 03:19 PM
Johnny9595
Sep 3, 2015 05:18 AM
