Engine code update
Old Mar 28, 2005 | 03:27 PM
slimer's Avatar
A couple of Blaxxx's? Lawls.
Engine code update
Alrighty........
So after I reinstalled the stock injectors last nite, I fired it up and it misfired badly. I let it sit on for a little while to let the idle come down and it started idling funny. When I touched the throttle, it almost died. Idle fuel pressure was set at 33-34psi. Idle was at 740-760.
0302-EGR System Hi/Low Flow
I can understand this because the engine had been sitting for four days.
0701-Multiple Cylinder Misfire
This could be due to the fact that the 370's were dumping fuel in many cylinders while there was an air leak in one causing a funny idle. When the gas was ignited, BAM! That probably was the loud pop that I heard.
1302-MAP/Baro SW Solenoid Valve
Had problems with this before, but since its EGR related, It might have triggered it. It also has something to do with gas fume recirculation (I've studied the diagrams when I had problems with it before) so might be thrown in conjunction with the above two.
0115 Fuel Management Right Cylinder Bank: Lean
Could this be from the air leak with the 370's or with the stockers? Since it is the last code that came up, I think it might be from the stockers and thats why the idle is funny.
I have not driven the car yet, but fired it up again after the reset and the codes have not reappeared. I throttled it to around 3k rpms for about 30 seconds at a time and it seems to be running alright, but I am thinking that I may be hearing some knock. Warm idle is still between 740-760 rpms, ~680 is usual, so it is a little higher, but that could be because its just been sitting in the garage.
Idle fuel pressure seems to work best at 36-37psi with the vacuum hose on the fpr.
What does everyone think?
Old Mar 28, 2005 | 03:44 PM
Bags's Avatar
VG Ridah's Biatch Hoe
Air in the lines, very possible. I bet your LT fuel trim is jacked..lol.
I'd drive it around the neighborhood, a few miles, staying under 3000 rpm and see if it clears up.
After I did my motor swap and finally solved my MAF issues, my car ran like crap. LOTS of smoke, it was running very rich. I drove it and it had a bad idle, the more I drove it the better it got. So maybe you need to drive it in closed loop and get some feed back from the 02 sensors to the ecu
Old Mar 28, 2005 | 04:19 PM
slimer's Avatar
thats what i was thinking. i will have my gf follow me when i drive around the subdivision. at least its warm this evening. its hovering around 50 (instead of the usual 20)
btw-what is my LT Fuel Trim?
Old Mar 28, 2005 | 05:24 PM
Bags's Avatar
Long Term Fuel Trim
Old Mar 28, 2005 | 08:15 PM
slimer's Avatar
like the fuel rail?
the 1302 code came back while driving. I could care less about that one. I drove around 2k rpms for about 10 minutes. The idle only got a little low at the end while at a stop sign and when I pulled into the garage. No strange smells, no smoke, no spills. **** it, I'm driving it to work tomorrow.
Thanks for your help Kirk.
Steve
Old Mar 31, 2005 | 11:39 AM
slimer's Avatar
More Codes:
Still the 1302-MAP/Baro, but that doesn't do anything
0308 Closed Loop Control-this makes me think that a fuse has been blown. I'm going to check
there was one that didn't exist->0411?????
Old Mar 31, 2005 | 05:07 PM
Bags's Avatar
Originally Posted by slimer
More Codes:
how's it driving?
Old Mar 31, 2005 | 06:56 PM
slimer's Avatar
its fine until it comes to a stop. then its starts to diesel and idle dropps about 100-120 rpms.
Old Mar 31, 2005 | 07:45 PM
Kevlo911's Avatar
Kevlo for President
Front O2 Sensor-b1 P0131 0411 Ec-158
Old Mar 31, 2005 | 07:50 PM
Bags's Avatar
sounds like a vaccum leak
Old Apr 3, 2005 | 10:00 PM
slimer's Avatar
it was, thanks mike, time to put the sc back in.............
Old Apr 3, 2005 | 10:12 PM
subs1000w's Avatar
it was a vacum leak? where was the vacume leak just curious
Old Apr 3, 2005 | 10:15 PM
slimer's Avatar
on the vertical hard line behind the tb. its hard to see.
mike suggested that i should look at the hard lines, so i traced every one until i found it.
Old Apr 3, 2005 | 10:20 PM
chris'smax's Avatar
i am curious also since i am going to be cranking my car tommorow w/ the stock injectors back in.
Old Apr 3, 2005 | 10:58 PM
slimer's Avatar
make sure all vacuum lines are connected. the diagram on the hood helps.
derekinthez
Nov 13, 2022 04:00 PM
mvm062
Nov 30, 2020 09:00 AM
fastcarny
Oct 6, 2015 10:42 AM
Hdnseek
Sep 9, 2015 05:55 AM
03VQMAX
Sep 5, 2015 03:47 PM
