Built VQ35 Progress!
nobody should complain about this time...he set a new maxima record w/ only 2 runs!!!!!!! ontop of just getting the car back w/ a diffrent clutch and turbo, i mean when he tunes this thing the way he wants and gets some more runs its bound to get in the 10's! nice work matt!
AWESOME RUN MARDI GRAS! You are an inspiration to many! Keep doing what you do.I know I'll never invest that much into my car to run even in the 11's, 13's would be cool.
But I guess racing is like modding, once you start it's hard to stop!
Great going man!
nice run matt
I was hoping you were going to stay around for the brackets. I called Jason and you guys had left about a half an hour before they called 11.99's and quicker to the staging lanes. It had cooled off a bunch more than when you ran the 11.4. Keep up the good work
Originally Posted by Charcoal95GXE
CMAX, i thought you were supposed to be setting the bars hommie ? :-)
Here is the link to the video. Its short because I didnt realize that he was running until he was half way down the track. Give it second if its not working yet.
http://videos.streetfire.net/player....7-C87F971DD901
theres two more videos out there as well...hopefully they will be up soon too. the one that was filmed from the starting line shows that sick *** 1.7x 60ft. he pulled
Ive got my OBD2 scanner loaded on my new laptop so I should have the timing datalogged soon.
Oh and I have the E-01 data from the 11.4 run stored and need will share it soon
Timing info on the JWT ECU with ~14psi in a 3rd gear pull
4250 8
4575 10
4963 10
5325 10
5675 10
5975 10
6263 10
6475 10
6725 10
Uhhhh could I get a little more timing please!
4250 8
4575 10
4963 10
5325 10
5675 10
5975 10
6263 10
6475 10
6725 10
4250 8
4575 10
4963 10
5325 10
5675 10
5975 10
6263 10
6475 10
6725 10
4250 8
4575 10
4963 10
5325 10
5675 10
5975 10
6263 10
6475 10
6725 10
what are you j&s ***** set at?
that timing is far to conservative you could easily run another 5-10 degrees especially with the J&S
heres a timing calculator you can download http://www.msefi.com/download.php?id=1644
the chart is rpm/KPA
under 100 being vacume
100kpa being 0 boost
and 200 kpa being about 14.7psi and the calc is on the conservative side
This is exactly the reason why I30tMikeD put down 30whp MORE on a stock ECU even while running 4lbs LESS boost. JWT timing is insanely conservative. I wonder how high that's pushing EGTs?
Post videos if you got them, their are a few.
I must thank Corey at Redlinemax for his parts help. Jason and Adai for their help in the pits and at the starting line. And Tapout for letting me try out a set of 26x10 MT ET Drags. I only got two runs so I know with more time at the track and a bit more tuning I can get more out of her. For this event I had to leave the passanger seat in. I plan on going to a test and tune with it stripped down, a/c removed etc. Perhaps a 10.999 will happen
Today I was running ~18psi and a 75hp shot of juice. Launching at the revlimit with the juice. Im VERY happy with the 330' time. The trap should be a bit higher, the juice wasnt hittinng as hard as it should in the higher gears. All in all dropping over a tenth and a half is great, but I'd love to get her in the 10's.Still, the fact that you ran 11.40 on your SECOND run is a very good sign.
They're going to start harassing you for a 6-point cage soon enough
[QUOTE=MardiGrasMax]
WTF ran a 15.504@60.52? Even my worst track time (16.748) trapped 83.48, with a 2.497 60ft.
Looks like he broke down or shut it down halfway through the run? 1.841 60ft...
Originally Posted by Nismo3112
Looks like he broke something after the 1/8th.
Whhhooaaa! That thing was scootin at half track!
Take the stroller out of the trunk, and take out the car seats, and cash in that $17 worth of change from the cup holder and your in the 10s easily!
Choray
Choray
QUOTE]
You are the MAN!! I wish I was home, cause I would have been there. Oh well, at least I saw your 11.7 earlier this year. Congrats Matt, you deserve this, and I'm sure your work will pay off, and if you think you can pull a 10.9, I'm sure it's only a matter of time before it happens. Way to go man. I can't believe I almost missed this thread/news.
(only to Matt)
QUOTE]
(only to Matt)
Choray
Choray
