pistons?????
Old Apr 6, 2005 | 08:26 PM
Milehifastmax's Avatar
pistons?????
does anyone know of a place that makes pistons for the maxima for boost???? if so please let me know i have a 96 with a 2000 motor and i am trying to find pistons so i can build up the motor so please let me know asap
thanks
Old Apr 6, 2005 | 10:31 PM
slimer's Avatar
A couple of Blaxxx's? Lawls.
what are your goals. stock internals can hold 500whp if tuned properly. If you are looking to lower compression for a s/c, then you will lose both performance and gas mileage efficiency.
I would suggest talking with a specialist before you try anything. You have to do a lot of your own research on this subject. Only a precious few have even attempted it (three people come to mind and two no longer are on this board.) If you think that this board will give you a quick solution, then you're wrong.
Old Apr 8, 2005 | 12:00 PM
Dreizehn's Avatar
Autozone is a good place to start. I just picked up my 600hp rods and pistons there.
Old Apr 8, 2005 | 12:04 PM
Stephen Max's Avatar
Can't beat that lifetime warranty, can you?
Old Apr 8, 2005 | 12:28 PM
98I30t's Avatar
"Autozone" and "600whp" in the same sentence..I smell blaspheme.
Old Apr 8, 2005 | 12:31 PM
Dreizehn's Avatar
Say what you want, I got those when I got high flow head, and turbo crane cams.
Old Apr 10, 2005 | 11:38 AM
Studio718's Avatar
I almost fried my monitor from spitting my juice onto it while reading this.
Old Apr 11, 2005 | 10:48 AM
you know what i was just wondering if anyone knew any place i was not looking for a quick solution so slimer get your facts stright. if i wanted to get a smart *** answer i would have gone to some kind of import shop or something so thank you anyway.
Old Apr 11, 2005 | 10:59 AM
Blu's Avatar
Blu
the tits
so what else are you planning, or do you plan to just slap some pistons in and expect to have a bulletproof motor?
Old Apr 11, 2005 | 11:09 AM
slimer's Avatar
I wasn't giving you a smart @ss comment.
you said that you wanted to know asap, so doesnt that mean that you were looking for a quick solution. most people who post things like that really haven't done their research and just ask questions real quick without thinking what you need and how much things cost.
as in talking to a specialist: Have you contacted a rep from eagle, pauter, arp?
Thats what I was saying. not to go to some stupid import shop. 90% of those people just want top sell you their little ricey accessories or do a half @ss job of installing bolt ons. Its hard to find a good one that you can trust.
You might want to consider running a hybrid with a little lower compression pistons that are stock sized. unless you are thinking of making a strict drag car, something like that can suffice.
I'm really trying to help, but it is very beneficial to do your own research.
Old Apr 14, 2005 | 02:18 PM
desertmaxima's Avatar
I got some custom internals you can buy, arias pistons ill sell em to ya for 3k but catch is you need the rods also and I have those and ill sell those to ya for 2k lol
Old Apr 14, 2005 | 07:35 PM
maxinitout's Avatar
everyone on this site is just a f*cking d*ck
Old Apr 14, 2005 | 08:05 PM
stephenlc's Avatar
ouch. I would try google.com then if that doesn't work, pay $20 to be able to use the search function here. And look how many damn times this has been asked.
Old Apr 14, 2005 | 08:51 PM
mtrai760's Avatar
'Trynna' is not a word
Contact JE, Arias, etc. Most of the quality piston manufactures will make you custom pistons to your specs.
Stupid questions often deserve stupid answers.
Old Apr 14, 2005 | 08:52 PM
mtrai760's Avatar
Then go somewhere else.
Old Apr 14, 2005 | 08:56 PM
mtrai760's Avatar
You could also buy one of these: VQ30DET Swap the lower compression pistons out and call it a day.
Old Apr 15, 2005 | 05:17 AM
larryseibel's Avatar
i dont understand? why are you putting pistons in? might as well put in a stronger crank, stud the bottom end, and re-do the heads because you must plan on putting over 500hp to the ground. if you are not putting 500hp down then leave the engine alone. lower compression pistons will actually make your car slower! if you really want lower compression pistons you will probaly need something custom...maybe try wiseco and give them the specs...i am sure they can make you some.
Old Apr 15, 2005 | 06:11 AM
stephenlc's Avatar
Q
Crank? The VQ crank is good for like 1000 hp.
Old Apr 15, 2005 | 12:56 PM
Yup VQ crank is pretty stout heck most of the motor is stout from the get go but that crank is pretty overworked
Old Apr 21, 2005 | 10:46 AM
maxima_kid's Avatar
thanks
I imagine the vq 300z would have the same internals wouldnt it? I never got around researching it though. But if so, wouldnt it be possible to just switch out NA parts for boosted stock internals?
Old Apr 21, 2005 | 10:49 AM
DA-MAX's Avatar
Eat, sleep, and sh*t 2JZ
VQ 300z??
Old Apr 21, 2005 | 10:50 AM
The 300zx has the VG30 engine and there is no sharing of VQ and VG internal parts.
Old Apr 21, 2005 | 11:50 PM
Oblongshapes's Avatar
Even if you did find pistons, that isnt where you start. You dump money into the bottom end (the reciprocating). i.e. block (die grinding all raised casting marks), crank (billet turned or forged, then align bored and sized with proper undersized bearings), ARP cap studs, enlarging and chamfering oil passages... The list goes on. You build a motor that can handle what you are doing. Then you get hypereutic pistons and size the rings in the cylinder so they are squared and grind them taking into consideration expansion clearences.
Good luck getting these things. Then when its all done, you have to figure out how to keep traction on that FWD car.
up to it?
Apr 16, 2020 05:15 AM
6spd4dsc
Mar 4, 2016 05:19 PM
imported_Nismo_max
Sep 21, 2015 07:24 PM
ballerchris510
Sep 11, 2015 05:29 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
