Fuel Delivery Setup question.
Old Apr 8, 2005 | 12:23 AM
Oblongshapes's Avatar
If running the 255LPH Walbro fuel pump with 370cc injectors and Z32 MAF hooked into a SAFC II, would both an AFPR and FMU be needed (or a SFMU)?
Or, would just a FMU be needed- (I read from another post that the ECU can compensate and give a stoich mixture at an acceptable pressure).
Or do you suggest just playing it safe and getting a SFMU to cover both ends of the spectrum and avoid any potential problems and possibly open up some fine tuning options?
(anyone have an idea what WHP this setup would be good to?)
Thanks a lot,
Jeff
Old Apr 8, 2005 | 02:05 AM
slimer's Avatar
A couple of Blaxxx's? Lawls.
You most definitely need a fmu. afpr would be suggested.
it would be safe to around 340 hp.
Im too tired to find the formula to find injector duty cycle and wheel horsepower.
Old Apr 15, 2005 | 11:01 AM
Broaner's Avatar
2060lbs and falling...
I thought an AFPR would be required. Wouldn't it run extremely rich in cold start and idle. So rich to the point of stalling out?
Old Apr 15, 2005 | 09:26 PM
I30tMikeD's Avatar
From what I have read, you should be able to get by w/o an AFPR. The 370's shouldn't give you too much of a problem on cold start. In addition, your probably going to want an FMU because you gonna have to make too large of corrections with just an SAFC. Not good to be adjusting large amounts with an SAFC, try and stay under +/- 10%.
But if your gonna buy an FMU then just get a SFMU then you can adjust base fuel pressure if you need to.
Old Apr 16, 2005 | 08:55 AM
MaxInProgress's Avatar
Proud of his GroceryGetter!!!!
HOld on so im gonna need a fmu and a sfmu? And whats the s before the fmu. i was guesssing safety..?
Old Apr 16, 2005 | 12:50 PM
I30tMikeD's Avatar
an FMU (fuel management unit) and a SFMU (super fuel management unit) are the same thing except the SFMU is the newer version that does not use disks but an adjustment screw and it can raise/lower base fuel pressure. SFMU is superior but costs alot more
Old Apr 16, 2005 | 10:14 PM
Broaner's Avatar
SFMU also adjusts the base FP. Thats why I'm getting it. I don't mind playing around with discs.
litch
123
Jan 4, 2024 07:01 PM
jmlee44
Oct 2, 2022 02:13 PM
Forge277
Jun 13, 2016 09:26 PM
doctorpullit
Mar 29, 2016 11:08 AM
