New 3" exhaust ocmponents....
Old May 3, 2005 | 07:07 PM
iansw's Avatar
My new hotness....
Now I just have to try and make the round one fit here:
Old May 3, 2005 | 07:20 PM
slimer's Avatar
A couple of Blaxxx's? Lawls.
great, was the old setup too loud for you?
Old May 3, 2005 | 07:31 PM
stephenlc's Avatar
looks nice.
Old May 3, 2005 | 07:57 PM
Bags's Avatar
VG Ridah's Biatch Hoe
Nice .....
Old May 3, 2005 | 08:24 PM
iansw's Avatar
Way too loud.
Still not sure how I'm going to fit that resonator in there with the piping so close to the wall there.
Maybe enough give to move it and use welded hangars to keep it in place??
Old May 3, 2005 | 08:25 PM
iansw's Avatar
LOL - I just realized I forgot to buy a tip!!!
I'd better go do that...
Any ideas on 3" muffler tips that look good?
Old May 3, 2005 | 10:14 PM
stephenlc's Avatar
use a 3 inch tip so it looks stock.
Old May 3, 2005 | 10:26 PM
96_vqmax's Avatar
Nice,what brand was it?And what's your old set up?Was it loud?
Old May 4, 2005 | 07:47 AM
Stephen Max's Avatar
Is the muffler a Magnaflow, too?
Edit: Nevermind, I see it is a Dynomax.
Old May 4, 2005 | 09:47 AM
iansw's Avatar
The current setup I have is
3" Cattman Y-Pipe
3" RT Cat (gutted itself out after 2 weeks - still looking for something else that will work - but for now it stays as a test pipe)
3" Custom mandrel bent B-Pipe
3" Louvered resonator (I'm losing power off this so I bought a straight-through magnaflow muffler to use instead)
3" Magnaflow Muffler
With this setup it is WAY too loud - cops can hear me coming a mile away and the drone on the freeway is unbearable.....not to mention my neighbors hate me.
New setup:
Cattman 3" Y-Pipe
Unknown Cat (haven't found one that works yet)
Magnaflow 3" straight through Muffler (used as resonator if I can make it fit)
Same Mandrel bent 3" B-pipe
Dynomax Super Turbo Muffler (Part #17673)
Old May 4, 2005 | 09:56 AM
1FSTMAX's Avatar
Ian, can you answer my questions in the thread you posted in the 4g forum? Thanks.
Old May 4, 2005 | 10:17 AM
Broaner's Avatar
2060lbs and falling...
Dude, if you pull that heat sheilding out of there you can get tons of space in there. I stuffed this monster Magnaflow into the tunnel. The casing is 6" round and fits snuggly but doesn't rub or bang. ID is 3" and the case is 30" long. Its very loud but I have no res or cat. Despite the volume the sound is awesome. It is extremely deep and muscle car'ish. But the volume is getting to me. My CD player skips any time I go WOT or engine brake through the 3-4K RPM range.
What are the dems on those muffs? That Magna looks like the smallest 3" ID they sell(18") I don't know what Dynomax's are like but my guess is that will still be very loud. Let me tell you what I suggest. Forget the whole cat thing since it really bottles up power with boost. Start the b right after the y just as I have done. Return that smallish magnaflow and get the biggest you feel comfortable. With no cat there is room to get the largest 6" case muff Magna sells. As I said, the case on mine is 30" long. With the end piping it is 36". There is plenty of room. Then continue the B-pipe on toward the rear into that Dynomax you have. It will be nice and quiet and depending on what Dynomax's are like, very deep.
Old May 4, 2005 | 12:19 PM
iansw's Avatar
Unfortunately during inspection time they look under there with a mirror and look for a Cat.
Can't do that.
But thanks for the pic - that makes me feel better about making this fit.
I'll probably just leave the gutted Cat on there - it's empty right now anyway and they don't do the "pipe test" at inspection time on my car - they just plug in the ODBII Scanner and look for codes and stick a mirror under my car.
Old May 5, 2005 | 11:29 AM
Broaner's Avatar
I didn't really you had to pass testing. Well then you could get a Summit Bullet Muffler. They are really short and could look similar to a cat. Maybe if you wanna go to that extent you could weld on some heat shielding stuff that makes it look like a cat.
Old May 5, 2005 | 12:30 PM
iansw's Avatar
lol.
I don't mind having a Cat at all....
The DynoMax was suggested by MardigrasMax who owned a Magnaflow before a Dynomax and said that it was far better tone and volume.
And since Mardi is the fastest recorded Maxima and the god of pushing the envelope - I'll take his advice.
Besides - I already bought it.
So you just have that muffler and then open air behind it?
Must be insanely loud....!
Old May 5, 2005 | 01:07 PM
Kevlo911's Avatar
Kevlo for President
When is this going on? I want to know if it drones.
Old May 5, 2005 | 03:04 PM
iansw's Avatar
I'm sure it will drone - I'm just hoping not so damned much!
Old May 5, 2005 | 07:55 PM
turbomax97's Avatar
I couldn't fix your brakes, so I made your horn louder
Yeah this magnaflow 3 inch inlet muffler is a pos - i have the same one as iansw - and it's loud as **** - i hate it. I'm ordering a blitz nur spec 80mm - that thing should purr.
Old May 5, 2005 | 07:56 PM
iansw's Avatar
seximagtr....
Thanks again for the help - sucks that my sister can be gullible....
Old May 5, 2005 | 08:09 PM
turbomax97's Avatar
Yeah - hope it's all running well now. You get your exhaust done?
Old May 5, 2005 | 09:55 PM
iansw's Avatar
Heh - this post is about doing my exhaust.
Soon - need to buy a tip and find a Cat that will work.
Old May 8, 2005 | 08:26 AM
Nissan Shift
i just installed a warpspeed full 3inch exhaust system not to loud pipes hit alittle bit though
Old May 8, 2005 | 02:26 PM
Nissan Shift
my car feels alittle slower since i installed this exhaust buit after like 3500k car feels good
Old May 8, 2005 | 02:34 PM
chris'smax's Avatar
Can't do that.
I'd like to see them get a mirror underneath my car
Old May 8, 2005 | 02:49 PM
Kevlo911's Avatar
Kevlo for President
Put the splash guard cover of the cat over a test pipe, they will never know the difference
Old May 8, 2005 | 02:51 PM
Kevlo911's Avatar
Kevlo for President
http://www.fle-online.com/MAGNAFLOW/...4000series.htm
CARK94009
Can you use that one?
Old May 8, 2005 | 09:59 PM
96_vqmax's Avatar
Originally Posted by Kevlo911
Well not bad for $63,have anyone use this before?
Might try out this one with the O2 bung weld on too,for my 95.
http://www.fle-online.com/MagnaflowP...4033-94039.jpg
Old May 8, 2005 | 10:01 PM
iansw's Avatar
Yeah,. the "3" In/Out Magnaflow Catalytic Converter" is just a Carsound Cat. <Magnaflow = Carsound>
That's what I was looking at before....Unfortunately, it's 18" long - needs to be 12" Max.
Either way - since my current Cat is gutted it's basically a test-pipe anyway.
I went with this tip:
Borla 20122 - Resonated 3" inlet, 3.5" outlet.
Old May 8, 2005 | 10:05 PM
96_vqmax's Avatar
Old May 8, 2005 | 10:07 PM
96_vqmax's Avatar
Very nice!
Old May 9, 2005 | 12:47 PM
Kevlo911's Avatar
Kevlo for President
CARK94139 That one is 13in long. But I guess you don;t need it.
Get this bad boy on
Old May 10, 2005 | 11:13 AM
SPiG's Avatar
SomePsychoGuy
You may be able to use the Carsound 53009. It is 13" long, but round instead of the normal oval shape. It doesn't have an O2 bung but it wouldn't be too hard to get one welded on.
Old May 14, 2005 | 05:45 PM
iansw's Avatar
Installed.
Only problem was he couldn't get the resonator to fit due to the way the pipe bent. I saw what he meant and it's kind of hard to explain...but he was right.
However- I don't think I even needed it - Dynomax > Magnaflow by FAR.
Nice tone now - a little raspier than I would like, but you can't really hear that from inside the car. The drone is 100% better. I can hear myself think now.
Exhaust looks simple - just the way I like it.
(Oh - and check my new garage floor - just finished laying the Epoxy coating a few days ago....in this pic is the first time my car's gotten to sit in the garage since I finished laying it down.)
Old May 14, 2005 | 07:13 PM
stephenlc's Avatar
it sticks out really far.
Old May 14, 2005 | 09:52 PM
iansw's Avatar
optical illusion - it really doesn't stick out a lot.
it's slant cut and you're looking at it from the top also.
Old May 15, 2005 | 01:23 AM
SPiG's Avatar
SomePsychoGuy
Looks good.
Did you get a cat?
What are you going to do about the resonator?
Old May 15, 2005 | 07:21 AM
iansw's Avatar
Nah - I'm just going to lave the gutted Cat on there.
And I'll probably just return the resonator to Summit.
I don't think I need it now.
Old May 16, 2005 | 09:33 PM
iansw's Avatar
The guy at the shop also informed me that I have an exhaust leak at the front of the Cat. (where Cat meets Downpipe).
So today I went and bought some Mr. Gasket (rubber/cardboard like gasket maker stuff) and cut out my own gasket.
The old gasket was fairly warped and in no shape to be reused. I made 2 gaskets, the first one sitll leaked badly and the 2nd one leaked only slightly. I gave up for now at that point.
BUT - the leak is far less now - the car is now even quieter - I can hear road noise again! But I can also hear every noise my engine makes and now I've got several new tranny/engine noises I just noticed....they probably don't mean anything, but since I just noticed them I'm worrying about them....lol
Justin Kroll
Oct 1, 2015 07:03 PM
09maxshawn11
Sep 30, 2015 10:28 AM
Socalstillen
Sep 26, 2015 12:01 PM
TheMafia
Sep 4, 2015 08:26 AM
