90 Degree elbow "Vortech Owners"
Old May 9, 2005 | 11:31 AM
Blu's Avatar
Blu
the tits
I can't figure out how to keep the back part of the elbow from making contact to the rear of the headlight bulb. Any ideas on what to do to get the thing off of the headlight? Its making the light twitch and its pretty annoying at night. Im just confused a lost at what to do. If Im not making sense I will try and snap a pic tonight to show what im talking about.
Old May 9, 2005 | 11:35 AM
ptatohed's Avatar
Licensed to Spell
Are you talking about the stock 90^ elbow that comes with the kit (has a flat spot, not "madral bent") or did you replace it with a "mandral bent" true 90^? The stock flat one should clear? Are you sure the elbow is all the way on the Vortech? The method The Wizard and I use is place the elbow on first, crank down the hose clamp, then stick in the crossover tube. If you try to do both at the same time or even the crossover tube first, it is very difficult to get the 90^ all the way on the snail outlet. Good luck.
Old May 9, 2005 | 12:47 PM
matty's Avatar
It is Tight but you can Gain a 1/4 maybe 1/2 inch by pushing on the 90 degree bend ONTO the Vortech really well, clamping that down, then proceed to put on your cross-over.
The trick it to make sure the 90 degree bend be On the blower all the way
-matt
Old May 9, 2005 | 12:56 PM
Blu's Avatar
Blu
the tits
Ill check it out later today....I just need to get all my motor issues resolved and upgrade to a 3" crossover.
Old May 9, 2005 | 01:20 PM
matty's Avatar
Im waiting for my 3" back from Performance Coatings.
Then it all goes in = Z32 MAF, JWT, 370's, 3" cross-over
-matt
Old May 9, 2005 | 01:40 PM
slimer's Avatar
A couple of Blaxxx's? Lawls.
reclock the blower a little bit, but you have to remove it to do that.
Old May 9, 2005 | 04:33 PM
I30tMikeD's Avatar
use a hammer lol. That is what I had to do for my down pipe to clear my radiator fan
Old May 18, 2005 | 01:28 PM
VQ30DENX_SC's Avatar
dont know how old this is, but u got that 18 inches of extra piping before the z32 maf? or was there another way around this? if so, link me to a thread where there is a solution to the maf....thanks...
Old May 18, 2005 | 02:24 PM
matty's Avatar
Im not too sure what you are asking ??
the 3" piping I am using before the MAF is 22" long
-matt
TKHanson
Nov 24, 2018 01:39 AM
VQ'ed
Forced Induction
Feb 29, 2016 08:05 AM
KabirUTA13
19
Oct 17, 2015 02:15 AM
DC_Juggernaut
Sep 28, 2015 04:07 PM
97_GXE
Sep 15, 2015 06:47 AM
