Clutch is almost done-need advice.
My stock oem clutch is almost gone, i barely got to work this morning lol, I need some suggestions on a boosted clutch, what you guys use? I need something durable that will withstand 14-15 psi and around 400whp. Also is it ok if i drop that clutch in now and install my turbo system in about a month or so, hows the clutch going to feel without the boost? Thanks guys I need one asap if anyone is also maybe seeling one or knows someone who sells em.
I have heard a lot of good things about clutchnet clutches. You might want to talk to them. I know mardigras and nealoc are both running them with their turboed cars.
http://maxmods.dyndns.org/index.php?MaximaClutches
![](https://maxima.org/forums/images/smilies/support.gif)
Clutchnet. Neal, Mardi, and Insw use the 6 puck sprung hub. I use their full disk fiber-carbon pro. Great clutch.
No problem at all installing the clutch before boost. Does not make a differnece at all. That is what I did so I did not have to go through the break in period with a newly boosted car. Who wants to intall a turbo and a clutch have to baby the car for the next 500 miles.
I'm in the same boat as you, MaxinProgress.
Currently, I drive my Max almost every day as my daily driver. I have virtually no traffic to deal with, whatsoever. I plan on going to the track every weekend, or every other at the minimum. Ptatohed and I just bought our DOT helmets! Oh yeah!
Alright, total newb questions. What's the difference between sprung and unsprung? What does "puck" mean? I don't know squat when it comes to flywheels/clutches.
Considering I'm boosted at 10 psi, what do you guys recommend for me? Same as Mardi, Neal, and Insw? I know those guys are 300+hp. Also, keep in mind that I'm no where near done with the car, I'm shooting for 325 whp. I estimate right now I'm around 255-260 whp.
Mike, what's the difference between your clutch and the one Mardi and the others are using? (driveability, feel wise)
Researching clutches/flywheels is driving me nuts. So many mixed opinions
The only thing I have figured out, is that if one gets a flywheel, the consensus is to go with Fidanza vs the other companies.
Thanks guys.
![run](https://maxima.org/forums/images/smilies/runaway.gif)
Thanks guys.
This is a full sprung hub disk.
http://clutchnet.com/make/_derived/p...l_txt_C10D.gif
See the six springs in the hub? Those allow for some slippage and not so much an on/off clutch engagement. It is full disk becasue it is a complete round surface, compared to the puck type, which is not a full disk and will grab harder.
http://clutchnet.com/make/C9D.gif
The pressue plate is what holds the power and the clutch is how it graps, more or less.
I went with the full disk for more steetability, per clutchnet's recomendation.
EDIT: Mike, Clutchnet says you must use one of thier pressure plates to accomodate thier clutch. Is that true?
Thanks Mike! Perfect explanation and pics helped too. Much appreciated.
Well, like I said, neal is using an ACT PP with a Cluthnet disk so I would think not.
I should have been more clear, can an OEM PP be utilized as well? or is that not advisable?
I went with spec stage 3 clutch well see how it holds up.
03-12-2020 12:06 AM
spencerwh1
06-30-2016 05:44 AM
carlosvq30
09-26-2015 09:44 AM
