Pop! goes third gear...
Old Jul 10, 2005 | 01:41 PM
Nealoc187's Avatar
SLOW
Popped 3rd gear today. Lame.
I was out doing some tuning with emanage, 3rd gear runs datalogging and watching the wideband. I had only done 3 WOT runs in the last 20 minutes or so, 2 of which spun the tires instead of hooking, then on the 4th run, (the 2nd run I'd done in the past 5 minutes or so) I got into it about 3000rpm and around 4000rpm it felt just like I had pressed the clutch in, no more pulling just the engine revving. I was only on the gas for about 3-4 seconds probably when it went, I quickly let off and coasted. I didn't know what had happened at this point. I revved it in neutral and everything sounded good. Real Time Data display on the emanage wasn't showing anything out of the norm, no oil pressure warning light, no smoke or crud trailing behind me. Air fuel was good, so I put it in 5th gear and let the clutch out and nothing weird happened. So I thought it was maybe just a hiccup of some sort, so I tried to put it back in 3rd and do a run and then I realized 3rd wasn't there. Free revving just like as if I was in neutral. So I went to the next exit and turned around and went home.
So today I hadn't done too much 3rd gear abuse, but in the past it's had quite a bit of abuse. Sometimes 20+ WOT 13-15psi runs at a time. Looks like it had just had enough this time.
Good thing I've got that AE LSD sitting in the garage
Old Jul 10, 2005 | 01:56 PM
maxmaxima91's Avatar
If your tranny did that at 13 psi what is mine going to do when i hit that kindof boost, we will have to find out soon. 9-10 psi in the next week or two
Old Jul 10, 2005 | 02:03 PM
Nealoc187's Avatar
SLOW
Well I'm a VQ and you're a VG, not sure how the trans internals compare though.
Old Jul 10, 2005 | 02:05 PM
slimer's Avatar
A couple of Blaxxx's? Lawls.
well, time to drop that sucker in!
sorry to hear neal. when do you think it will be up and running again?
Kevlo911's Avatar
Kevlo for President
Time to upgrade to the stronger 5thgen 5speed.
Old Jul 10, 2005 | 02:19 PM
all i know is that my dumb Borg Warner tranny cant handle what the newer ones can. Ill figure that one out when i get there i guess
Old Jul 10, 2005 | 02:25 PM
Nealoc187's Avatar
SLOW
I don't know I may actually keep this trans in for a bit. Since it's already shot, but all the other gears are working just fine, I may use it as my tuning trans and just do everything in 4th gear to get the car tuned. If I blow another gear it's no biggie. I won't be daily driving the car for a long time anyways (tuned with the new injectors, an exhaust on it, etc). All I really do with it right now is take it out and tune it so it's no big deal really.
Or I could put the AE LSD in next weekend.
Old Jul 10, 2005 | 02:32 PM
Kevlo911's Avatar
Kevlo for President
Have more fun with this tranny Get it tuned right so when new tranny is in you wont need to tune.
Old Jul 10, 2005 | 02:36 PM
Nealoc187's Avatar
SLOW
Exactly what I was thinking. Of course I was hoping to head to the track this coming weekend too...
Old Jul 10, 2005 | 02:49 PM
I30tMikeD's Avatar
Sucks Neal, but hey you got the AE so it is all good. Give me a call.
Old Jul 10, 2005 | 04:10 PM
subs1000w's Avatar
VG/VQ non lsd trans internals are identicle but the VG wont make as much power as the VQ at the same # so it may hold but there have been NA guys that have broken 3rd so its not necisarily a certain whp that it breaks at its how much abuse and how strong your clutch is that breaks it
Old Jul 10, 2005 | 04:40 PM
JClaw's Avatar
Welcome to the 3rd gear club. I wheelhopped first, then wheelhopped 2nd, then shifted into 3rd, and BOOM.
Third gear is the one always prone to crapping out because it is just as thin as 4th and 5th, while 1st and 2nd are thicker (unless I'm blind).
Anyway, using the current tranny as a tuning tranny is a really good idea. I know how it feels when you really want to go to the track, but if I were you I would hold it for a few more weeks and beat the f*ck out of this one.
Old Jul 10, 2005 | 04:41 PM
Jason R's Avatar
aka UNCDooD
my 3rd gear broke about 2 years ago now and that was on a stuck clutch and flywheel. I would definitely continue tuning with the busted tranny until you get a real good tune then swap in that AE LSD tranny and hit the track.
Old Jul 10, 2005 | 05:13 PM
Morfeus17's Avatar
Believe it or not the trannies are identical internally.
Old Jul 10, 2005 | 05:36 PM
Nealoc187's Avatar
SLOW
The cruddy thing about tuning in 4th rather than 3rd is that I have to run it out to ~130mph to tune to the end of the powerband, as opposed to ~95 for 3rd gear. But it's not that much of a change really because I am at the limit (sometimes past the limit) of traction in 3rd at 12psi anyways, so when I start tuning the higher psi levels, 13, 14, 15, etc i will have to use 4th. It's alot easier to find the space to do a 30-95 run than a 40-135 run
Old Jul 10, 2005 | 05:55 PM
JClaw's Avatar
Like the cops are really going to be able to catch you anyway
Old Jul 10, 2005 | 07:06 PM
vortechpower's Avatar
I have dropped 3rd gear 3 times now. Only problem you might have is the parts/teath getting stuck in the rest of your gears. Can you hear any flopping around inside? I will be surprised if you can drive without any issues.
Old Jul 10, 2005 | 07:45 PM
how are the six speeds for toughness?
Old Jul 10, 2005 | 07:55 PM
VIP Maxima
i would keep usin the same tranny for now....
Old Jul 10, 2005 | 09:04 PM
Nealoc187's Avatar
SLOW
I hear no unusual noises whatsoever from the transmission. Otherwise I wouldn't be considering keeping it in there for a while. But I notice no bad symptoms other than the fact that the car free revs when you try to put it in 3rd.
Old Jul 10, 2005 | 09:10 PM
JClaw's Avatar
I opened my tranny myself last week after blowing third gear, and there were pieces of gear all over.
One of those ****** gets into another set of gear, and civic guys will be bragging about almost keeping up with a maxima stuck in 5th gear from a dig.
Old Jul 10, 2005 | 10:05 PM
hlh0501's Avatar
Sorry to hear, 3rd gear is like a timebomb.
And yes, often times the shattered pieces will find their ways into bad places and tear out more gears , or stick you in one. If you aren't afraid of a towtruck ride home, hammer!
Old Jul 11, 2005 | 03:17 AM
maxima_kid's Avatar
that sux. I hope mine holds out until ... well forever. Not much of a chance but a guy can hope. How are you tuning your emanage anyway? I havent installed mines yet and also considering the profec to install altogether. Is it worth it?
Old Jul 11, 2005 | 06:04 AM
DA-MAX's Avatar
Eat, sleep, and sh*t 2JZ
been there before....except it was 18psi in Redmax's car and yeah 3rd gear went out like a light. when you open it up you'll be presently surprised at the metal waterfall that pours out what are your plans? cryo?? because 14-16 psi seems to be the breaking point no matter what...
Old Jul 11, 2005 | 06:07 AM
Nealoc187's Avatar
SLOW
I don't have any plans for the broken one it's probably going to go for sale on here for like $50, I already have too many car parts laying around.
Old Jul 11, 2005 | 06:21 AM
maximamaybe74's Avatar
Are all the 5th gen 5 speeds stronger than the 4th gens or just the 5th gen AE lsd ones are the ones that are built well casue i have a 96 trans with the quaife in it and i dont want to have buy an AE trans since my 3rd gear recently dissapeared last week on my 96 trans.
Old Jul 11, 2005 | 06:34 AM
DA-MAX's Avatar
truthfully I don't see the 5th gen trans lasting any longer than the 4th gen at regular usage over 16psi...has anyone proven it?
Old Jul 11, 2005 | 07:18 AM
slimer's Avatar
supposedly the 3rd gear has a different part number for the 5th gen. everything else is the same.
Old Jul 11, 2005 | 07:45 AM
DanNY's Avatar
Ad·min·is·tra·tor
are you looking to use it for your VG?
Old Jul 11, 2005 | 09:07 AM
Prodeje79's Avatar
That is a bummer!
I am glad you have another tranny to use.
Old Jul 11, 2005 | 09:23 AM
AsthmaMax11's Avatar
Damn Neal, it's like everytime I check the boosted forum something else has gone wrong with your car. It's really too bad what happened to your first Max...
Old Jul 11, 2005 | 09:40 AM
Broaner's Avatar
2060lbs and falling...
My hookup at Nissan actually looked at all that for me in an AE when it was being rebuilt. He put it like JClaw. He said third was much thicker than 4th and 5th and it wasn't all hollowed out like some of them can be.
Old Jul 11, 2005 | 11:14 AM
MardiGrasMax's Avatar
What really sucks is that third is at the bottom of the shafts, so to cryo and then shotpeen you need to rip both shafts down. Neal, if you dont treat the gears at least run the Redline Shock Proof Heavy gear oil.
Like Hal said, if you dont mind a tow truck ride (get AAA )and hammer!
Old Jul 11, 2005 | 01:12 PM
Yea through the use of an adapter plate, flywheel spacer, and custom axles. I know ill run into plenty of other hurtles but im sure ill clear them or knock them over. that is when my stock tranny goes out. Probably won't be all that long from now because ive made my kit good for at least 500 hp and my engine is prolly good to about 400 so it just a matter of how much boost i dare to run. and i know now that my stock tranny aint going to hold all that much. everything depends on $$ what i can afford at the given time.
Anyways .. how much tougher are the 6 speeds. if any..?
Old Jul 11, 2005 | 01:39 PM
Dont mean to hoard your thread but since im getting a 2000-2001 trans will it be any different from installing the quaife on the original 96 trans since the 5th gen 5sp has to use different axles and does anybody know what bearings i have to get casue the ones from the vqpower site (38440-96E00) arent showing up on the parts list at my dealer.
Old Jul 11, 2005 | 02:10 PM
Jeff92se's Avatar
I'm needing a caw
Got pics??
Old Jul 11, 2005 | 02:15 PM
DanNY's Avatar
Ad·min·is·tra·tor
yeah i was going to ask if you have any pics of your set up.
Old Jul 11, 2005 | 02:19 PM
working on geting some hosted. ill most likely have then by tonight. Neals seen my setup
Old Jul 11, 2005 | 02:24 PM
MrGone's Avatar
I have 3 servers
mrgone@maxima.org
will have them up within 30 seconds of them hitting my inbox
Old Jul 11, 2005 | 02:33 PM
Im going to start a new thread with this , sorry for sidetracking you thread neal
