another 3" charge pipe question
Ok guys not to be repetive, but i need a solid answer on the 3" charge piping. With my stock size throttle body would it be worthwhile to swith to a 3" charge pipe? Have any of you with the 3" charge pipe noticed any boost gains?
I would say spend the $ on a few dyno pulls before spending the dough on 3" charge piping.
your MAF is on the non-charged side, right? The LatinMax CAI would be a worthier investment. You wouldn't be able to fit the larger piping there anyway.
Steve
Steve
Steve
Steve
I wanted to do the cai and 3" charge pipe at the same time. Why wouldn't i be able to run the larger pipe?
well with the crossover, it takes up so much space so clearance is a factor. if you get the cai and crossover at the same time, more power to ya!
how is everything running?
She runs beeeeeaaaauuuuutttiiful. Just cross my fingers the tranny holds every time i get on it
You could always put a Pathfinder TB and bore out that DEK manifold a little. I have one at my house that I would be willing to sell you cheap if you wanted to buy it, otherwise I am keeping it for myself. I am not positive if the TPS is the same style as the 4th gen/PF though.
My opinion has almost become if Mardigras did it then it is probably not a bad idea.
x10000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 0000000000000000000000000000000000000000000
:o)
I would like to know the answer to Chris's question too.
I received my Miata aftercooler and now is the time to go all 3". The easiest thing to do is just cut out a 12" section of existing 2.5" crossover tube and slap this baby in. In the Miata, it goes from a 2.5" intake to the 3" cooler back to 2.5". I would be doing the same thing if I simply cut out a 12" section. I'm really torn. If three inches is better, I'll do it, if it is worse and/or makes no difference, I'd much prefer to stay 2.5".
http://forums.maxima.org/showthread.php?t=419709
shilov
Feb 19, 2024 09:40 PM
Mar 12, 2020 12:06 AM
