Need Help With Fmu Disk
Old Aug 9, 2005 | 12:16 PM
*FleXIMA*'s Avatar
I just got my turbo max back and its having some issues....
its starts to sputter at peak boost. i think its due to the fact that i am running to RICH... and the fmu is a 10:1. So my question is will a 8:1 be good... and where can i find one. Any info will be greatly appreciated
Old Aug 9, 2005 | 02:10 PM
slimer's Avatar
A couple of Blaxxx's? Lawls.
http://www.superchargersonline.com/p...2=fmu_cal_disk
slimer's Avatar
do you have an upgraded fuel pump?
Old Aug 9, 2005 | 04:25 PM
*FleXIMA*'s Avatar
255 walboro pump
Old Aug 9, 2005 | 04:27 PM
*FleXIMA*'s Avatar
wat do u guys suggest... with stock injectors wa disk should i use... 8:1 7:1 or 4:1???
Old Aug 10, 2005 | 11:24 AM
Chief Brody's Avatar
What you might want to do is go backwards and calulate how much fuel pressure would be required for a desired HP. There are tons of online calculators. Then decide what disc would get you that fuel line pressure at your given psi.
Old Aug 11, 2005 | 10:23 AM
I30tMikeD's Avatar
I would hate to assume your running rich and drop down a disk size, get less fuel then find out your actually running lean.
If you don't have a wide band then I would get to a dyno with a few different size disks and see which one is best.
It really helps to have an SAFC in conjuction with an FMU. When I was tuning with an FMU an 8:1 disk had me hitting 13:1 AFR close to redline but a 10:1 had me below a 10:1 AFR. Having the SAFC allowed me to tune in between the two.
In my case, at 5psi, a 10:1 disk, and subtracting fuel fuel via an SAFC worked. T
Old Aug 12, 2005 | 07:11 PM
*FleXIMA*'s Avatar
damn that picture looks good mike.... and yeah the SAFC was ordered sat waiting on it to come.... i just heard that the SAFC might not tune it down enuff.... and oh yeah gettin dyno tuned the 22nd . Thanx for the help........ But if that doenst work can u guys think of anythin else? cuz it really sux i cant even push it over 5k cuz its starts to sputter like crazy and it dont go no where
Old Aug 13, 2005 | 07:32 AM
JAY25's Avatar
I have some 8:1 disks if you want to buy one. Just let me know
Jaime
Old Aug 14, 2005 | 08:45 AM
slimer's Avatar
thats lean. it happened to me when my aux fuel pump wasnt hooked up correctly.
pull your spark plugs. white=lean black=rich.
Old Aug 14, 2005 | 11:04 AM
*FleXIMA*'s Avatar
tilley did the testing for me and i have a A/f guage telling me i am rich
JAY25
Feb 6, 2002 11:20 AM
jhans114
Jan 3, 2002 08:15 PM
OnTheRoad
Dec 4, 2001 01:14 PM
jgadlage
Sep 15, 2001 11:44 AM
