What are you Using for Cold Air Piping ?
Alright Ive had the same setup since ive done my S/C and the pipeing keeps comeing un-done...its coming off the blower and between the section of piping and the piping I have tucked into the fender-well...
The first section is from Home-Depot,...that is connected to the second 90 degree bend with a section of pipe that holds...its coming apart there too
Heres a pic
You can tell the white peice of pipeing between the two rubber sections coeming apart a bit...its about to fall off in this pic
Any ideas on how to fix this. ?? I drive around, and come home, and its coming off...I dont mind changing it all around, if it will work.
It actually worked better with my old screw type clamps...it never came off
Thats the same type rubber connector from Home Depot..I tryed hacking it up to make it work better, but it didnt
-matt
Heres a pic
-matt
Go to NAPA and buy 3 inch heater hose from a Tractor trailer. I just use one section and thats it. You can use the T bolts to secure for more piece of mind.
Originally Posted by Stephen Max
I got a 3.5" mandrel bent U-bend from Stahlheaders.com.
PVC is way too restrictive to flow well, being thick-walled.
Seems like a better idea since I cant really get this to stay on the blower
-matt
Matty I got that same Home Depot POS sh*t. Grab that crap and trash it. My CAI keeps on coming loose. Ill be going to NAPA or a boat shop to get some 3-3.5 inch heater hosing. That works way better then that rubber garbage.
OK , stop what your doing!!!
No, I have the same connector from HOME DEPOT! YOU need to CUT OFF the edge connected to the blower. The "lip" , just cut that off at the edge as smooth as posible. Then put it back on and it will not slip off, that is how I figured this out, it kept slipping off after so many miles or high boost runs... It works!
Oh, leave as litte of rubber (visible rubber) between the clamp and the blower. This will solve the problem
I am still trashing that short az garbage. I am going with the good old reliable connector that the blowers with come with but in 3 inch.
Originally Posted by Requin6
i have the same coupler from home depot on my 4th gen and have never has a problem with it coming off.
-matt
-matt
Originally Posted by matty
I just recieved that in the mail this morning. How much of a section did you cut off of it to make it work ??
-matt
-matt
Anyone know a good size K & N filter to use ?? Right now Im using one with a big base and I have a plastic peice making the 3 1/2 larger...I dont think that will work once I use the metal mandral bend
What one you think ??
-matt
-matt
-matt
-matt
TallTom
57
Oct 14, 2025 05:16 PM
litch
123
Jan 4, 2024 07:01 PM
