Mounting reverse y pipe
Old Aug 29, 2005 | 07:19 PM
wunfstmax's Avatar
Anyone running a reverse y pipe how and where did you hang the feed pipe? Ive just spent all day trying to hang mine, but the only thing that i have accomplished was skinning my elbows and cutting my hand up. Very fusterated.
Old Aug 29, 2005 | 10:41 PM
I30tMikeD's Avatar
What do yo mean by hanging? As in having it secured so the pipe doesn't hold the weight of the turbo and hang down? I have a few ways if that is what your talking about
Old Aug 30, 2005 | 10:33 AM
wunfstmax's Avatar
yes, thats what i meant, just didnt know how to say it.
Old Aug 30, 2005 | 11:48 AM
I30tMikeD's Avatar
I gotta run to work but I can get you some pics of how I have mine mounted when I get home tonight
Old Aug 30, 2005 | 12:44 PM
wunfstmax's Avatar
That would be great, thank you.
Old Aug 30, 2005 | 07:15 PM
jcy98maxse's Avatar
Turbo is too much fun!
i wanna see to... plz post and some pics of how high the pipe is off the ground if u have em.
Old Aug 30, 2005 | 07:37 PM
wunfstmax's Avatar
it cant be too high off of the ground, mine is about 1" below the cross member, and i have teins s techs so they might before sale soon
Old Aug 30, 2005 | 10:07 PM
jcy98maxse's Avatar
and rubbing issues? I know its gonna be pretty low but I also would like to see the placement of where the pipes goes... I'm having the pipe made so I would like to see how it would look.
Old Aug 31, 2005 | 08:38 AM
JAY25's Avatar
what do you have the PFI kit? If its not then it has these metal hangers and you secure the feed pipe and the Downpipe almost right next to each other. What rubs on this reverse y pipe set up is the downpipe at the bottom. Thats the part that usually rubs coming out of steep drive ways or curbs. Also since the flex section of the downpipe is over 3 inch diameter that may rub too if you do not secure it properly. Pushing the feedpipe up to high and it may rub the rear of the transmission making it hard to shift the 5 speed manual. So you cant shove it all the way up in there.
Old Aug 31, 2005 | 09:04 AM
I30tMikeD's Avatar
This pic shows the hanger welded to the feed pipe, it is comming off the back of feed pipe in the pic. The original design was to use that post, in additioin to a post welded in the engine bay, and a rubber hanger to support the feed pipe. Just like our exhaust hangers for the muffler
http://img.photobucket.com/albums/v1...d/113_1330.jpg
These pics kinda show what I used instead. See the turbo flange? See the stock battery tray hole? They happend to line up almost perfect for me. So what I did was use an extra long bolt on the corner of that flange and ran it through the turbo flang hole, feed pipe flang hole, then through the battery tray hole with the bolt on the underside of the battery tray. Securing the feed pipe to the battery tray.
http://img.photobucket.com/albums/v1...d/113_1326.jpg
http://img.photobucket.com/albums/v1...d/113_1327.jpg
http://img.photobucket.com/albums/v1...d/54bea749.jpg
Before I redid my feed pipe and down pipe I ended up ripping away that mouting location when I banged the feed pipe going over some railroad tracks. It ripped apart the battery tray hole.
I now have it remounted in a similar fashion using the other battery tray bolt hole, but reinforced with some 1/8" steel plates, and my feed pipe and down pipe were redone with 3" oval SS piping under the tranny to increase ground clearance. I hardly ever scrape anymore and don't have to drive so carefully.
I don't have a PFI kit, but a custom one with a similar design
Old Aug 31, 2005 | 10:49 PM
wunfstmax's Avatar
well i think that i may have found some of my problem, the pipe i made was about 1 or so shorter than yours so i extended it havent had a chance to re-mount it but ill try tomorrow. thanx again
Old Sep 2, 2005 | 08:41 AM
I30tMikeD's Avatar
Here is how I have it mounted now, more secure
Unclejunebug
Apr 2, 2016 05:42 AM
Pnjboyzz
Nov 16, 2015 12:27 PM
Pnjboyzz
Oct 7, 2015 10:47 PM
sliptap
Sep 30, 2015 05:57 AM
