V2 Blower and Plate on Ebay
Old Aug 16, 2005 | 08:04 PM
matty's Avatar
This isnt mine, I just figured I would let everyone know since Stillen discontinued the S/C kit
http://cgi.ebay.com/ebaymotors/Vorte...67275918QQrdZ1
$1000 which isnt that bad with a plate and blower
-matt
p.s. Everyone waiting on a price for the V1 plate, its still in the working...Im sorry, ive just been really busy
Old Aug 16, 2005 | 10:21 PM
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
Hmmmmnnn....anyone know who that is?
Old Aug 17, 2005 | 12:39 PM
mensur724's Avatar
is that all you would need to supercharge the car what else would you need to buy to install that blower
Old Aug 17, 2005 | 07:46 PM
CBass69187's Avatar
Granted you dont need ALL of this, but it should give you an idea.
2000-2001 MAXIMA BILL OF MATERIALS
PART# DESCRIPTION - PART# 407500 QTY
AIR FILTER ASSEMBLY
402960L K&N Air Filter 1
407500-29 Adapter air filter 1
407500-30 support bracket, tubular 1
407500-31 support bracket, "Z" type 1
407000-67 rubber isolator 2
407000-68 rubber isolator, inner sleeve 2
407500-34 M6-1.0x 16mm flange HHCS 5
407500-40 M6-1.0x 30mm flange HHCS 2
407500-41 M6-1.0 flange hex nut 1
402991 #1/4 flat washer 2
VORTECH SUPERCHARGER ASSEMBLY
407500-01 Supercharger 1
407500-02 modify supercharger drive pulley 1
407500-03 modify supercharger pulley washer 1
407000-05 Supercharger adapter plate assembly - Aluminum 1
407000-36 M12x70mm Flat head bolt 2
407000-37 3/8 -16x 4-1/2 flat head cap screw 4
407000-74 M 12X50 mm Flat Head Bolt 1
407500-04 Steel Fitting, 90 deg - 4 AN - 1/8 NPT M (fitted into S/C) 1
407000-45 M6x 1.0x 55mm hex head cap screw ZP 2
407500-08 Serpentine Belt 1
400950-4 serrated spring washer 2
407000-76 3/8-24X1" flat head cap screw 1
CRANKCASE BREATHER HOSE ASSEMBLY
402935-6 5/8" ID Crank case breather hose (407000-15 may sub)2ft
407500-32 hose elbow 90 deg, 5/8" w/ 1/4" tee 1
407500-43 vacuum tee, 5/16"run x 3/16" branch 1
OIL FEED LINE ASSEMBLY
407500-25 OIL FEED LINE,-4S.S BRAIDED LINE 1
407000-17 aluminum spacers, dia 1/2" OD x dia 1/4" ID x 1/2" long 3
402990 M6x 1.0 x25mm HHCS 3
318110 M6 flatwasher 3
407000-56 Steel Fitting, 4m. To 1/8 NPT M 1
407000-57 Steel Fitting, 1/8 NPT M - 1/8NPT M 1
407000-58 Steel Fitting, 1/8 NT FEM, 3 way tee 1
407100-04 Adel clamps, size SG6 3
BELT ADJUSTER/PULLEY ASSEMBLY
407500-24 Flat Belt Idler Pulley, 2" w/o rails 1
407500-22 Base Bracket ( tensioner brkt assy! ) 1
407500-23 Spacer Pulley 1
IDLER PULLEY ASSEMBLY
407500-09 2" DIA Pulley w/o side rails 1
407500-07 1/2 - 13x 1-1/2 HHCS ZP 1
407000-73 M12 Flat Washer 1
407500-10 Idler Pulley Bushing 1
FUEL PUMP ASSEMBLY
402991 1/4 Flat Washer 2
318109 M6 Split Lock Washer 2
402990 M6-1.0 x 25mm Hex HD cap screw 2
405030-6 Cable ties 11" 4
407000-09 Bracket, Auxiliary fuel pump 1
407000-40 1/4-20 nyloc hex nut 2
407000-47 FMU mounting bracket 1
407000-64 5/16 MPI fuel hose 8ft
407000-67 Isolator rubber grommet 2
407000-68 Isolator sleeve 2
407000-75 #4 hose clamp 9
407000-80 10-24 x 3/8" PH pan hd screw 3
407000-85 1/4-20x 1/2" FL, Soc., hd screw 2
407000-87 #20 Adel Clamp 2
407500-20 FMU 8:1, w/ 5/16" barb fitting (w/vortec) 1
407500-27 Fuel Pump Assy w/ 5/16" barb fitting 1
407500-44 5/16" barb fuel hose joiner 3
407000-27 neopren rubber isolator 1/4-20 2
AUXILIARY FUEL PUMP ELECTRICAL ASSEMBLY
Fuel pump relay electrical assembly (Bosch relay from Vortec)
318110 M6 flat washer 1
407000-49 Fuel pump pressure switch 1
407000-55 Hobb/boost switch bracket 1
407000-60 1/2" OD x 1-1/2" aluminum spacer 1
407000-88 Blue3M splice 1
407500-06 M6-1.0x 65mm HHCS 1
407000-89 Relay Bosch 12v 20/30 amp 1
407000-90 Inline ATC fuse holder, 10-12GA Red 1
407000-91 Fuse, ATC 25 amp 1
407000-92 Wire - 18GA yellow - 6 ft. 1
407000-93 Wire recepticle, female 18GA 3
407000-94 Wire, 12GA red - 14 1/2"L 1
407000-95 Wire recepticle, female 12GA 1
407000-96 Butt connector 12GA 1
407000-97 Wire connector, 10-12GA with 1/4" ring 2
407000-98 Wire connector, 18-22GA with #10 ring 2
407000-99 Wire, 18GA Black 2
407000-100 Wire, 18GA Red 2
POWER STEERING ASSEMBLY
407000-16 Hose Power Steering to oil cooler, 3/8" ID 8ft
407500-37 12"L foam tube 1
407000-75 hose clamp #4 2
407100-01 aluminum "U" tube 1
407100-02 perforated back strap, 18"L 1
407100-03 M6-1.0x 12mm flange HHCS 3
407100-04 adel clamps SG6 3
COOLANT BOTTLE RELOCATION ASSEMBLY
407500-50 Coolant bottle relocation bracket 1
407500-34 M6-1.0x 16mm flange HHCS 1
WINDSHIELD WASHER BOTTLE ASSEMBLY
407500-36 molded hose 1
408005 hose clamp, #24 2
405030-6 cable ties, 11" 1
BYPASS VALVE ASSEMBLY
407000-24 Bosch bypass valve 1
407000-62 Rubber Hose, 1"ID x 24"L 3ft
407500-33 Hose Clamp, #12 narrow 4
FUSE BOX RELOCATION ASSEMBLY
451070-4 Flat head 10-32x5/8 2
407000-30 Fuse box relocation mounting bracket 1
407000-31 Fuse box mounting brackets (teardrop) 1
407000-35 M6-1.0 X 20mm HHCS 1
407000-42 10-32 nylock nuts 2
402993 M6-1.0 nylock hex nut 1
MODIFIED OIL DRAIN BACK PLATE ASSEMBLY
407000-06 Modified oil drain back plate 1
407500-26 Hose clamp #10 narrow 2
407000-32 Blower oil drain back hose preformed 1
VACUUM LINE ASSEMBLY
407500-28 Vacuum tees, 3/16" 1
503215-6 Vacuum lines, 5/32" 4ft
PRESSURE PIPE ASSEMBLY
404046 hose clamp #36 1
405030-5 hose clamp #40 1
407100-03 m6-1.0x 12mm flange HHCS 2
407500-14 pressure pipe w/ welded mounting tabs 1
407500-15 2" L x 2-3/4"ID silicon hose 1
407500-16 hose clamps #44 2
407500-17 90 deg 3-1/2"ID x 2-1/2 ID hose 1
INLET PIPE ASSEMBLY
407500-18 Inlet pipe assy 1
407500-19 90 deg 3-1/2 ID x 2-1/2 ID hose 1
407000-14 hose clamps #56 1
3m5314 12" long x 1/2"W double sided tape 1
402956-04 14" cable ties 2
ASSOCIATED HARDWARE ASSEMBLY
407500-06 M6-1.0X 65mm HHCS, S/C plate to engine 1
407500-42 m6 stand-off bolts, S/C plate to engine 2
407000-33 M10-1.5x 60mm HHCS 2
407000-34 M10 flat washer 2
407000-45 M6-1.0 x 55mm HHCS 1
407000-46 M6-1.0x 30mm HHCS 1
407000-84 Cam Sensor Retainer Plate 1
407500-11 M8-1.25x 25mm FHCS 1
407500-12 M8-1.25x 30mm HHCS 1
407500-13 m6-1.0 x20mm FHCS 1
318109 M6 flat washer 2
318110 M6 split lock washer 2
407000-35 M6-1.0 x 20mm FHCS 1
400950-4 Serrated spring washer 1
100505 Stillen SuperCharge Emblem
WARNING 92 Octane Label 1
STISUPER Stillen SuperCharge Decal 1
*Posted by Hnda Etr
Old Aug 17, 2005 | 08:11 PM
matty's Avatar
Something like this:
Old Aug 18, 2005 | 08:39 AM
Stephen Max's Avatar
Reserve not met at $1000.
The seller has no feedback score.
Old Aug 18, 2005 | 09:29 AM
Blu's Avatar
Blu
the tits
the only person that I know of in the Charlotte area that had a SC'ed 5th gen was Max'n Out (sp) with the custom IC'ed setup. No idea if this could be his auction or not.
Old Aug 18, 2005 | 09:35 AM
IceY2K1's Avatar
EXACTLY who I was thinking of...
Old Aug 18, 2005 | 09:40 AM
IceY2K1's Avatar
You were correct Blu...
http://forums.maxima.org/showthread....14#post3895714
Originally Posted by max'n out
Supercharger and Intercooler kit for sale
I’ve striped my 2k maxima to concentrate on making it a daily driver and put my energy into my other cars.
As a result, I am selling parts of the car off, of this is the Supercharger setup from my car, which can be viewed here: http://www.cardomain.com/memberpage/407837
If you buy this kit you get, the supercharger complete with 3.25 pulley (about 10psi) and belt (brand new). The blower is in great shape is was just rebuilt b4 I put it back on the car only to pull it off again. You get as well a custom Intercooler that was made just for my car. Custom pressure pipes and custom cold air intake with filter. You also get a crankcase breather assembly along with the 8:1 fmu. You also get the Apexi super afc. I have what I think is all of the vacuum lines as well. You will however need the in tank walbro fuel pump which my mechanic lost, and some fuel lines. The pump should run you around 150 new and the fuel lines at most 50 bucks if you get screwed.
edit: Also Includes the greddy blow off valve.
I am letting this go for only $4100 which you will take note is only 200 bucks more than the stillen kit, which includes way less.
Contact INFO:
All my attempts to contact the forums moderators went unanswered and as a result I could not get the email listed in my profile changed so do not use that. I will also not be told if anyone post here but will check in…. The only way to contact me and those who do will get first come first serve type info and sale is to email me at: SirjBling@yahoo.com
Buyer pays the shipping; it will be likely 3 boxes.
Old Aug 18, 2005 | 09:45 AM
Good detective work, Icey. What's his reserve?
Old Aug 18, 2005 | 09:48 AM
IceY2K1's Avatar
He didn't say, but knowing him from the boards I don't care anymore.
Old Aug 18, 2005 | 10:15 AM
mensur724's Avatar
his reserve is 1800 emailed me
litch
123
Jan 4, 2024 07:01 PM
knight_yyz
Nov 1, 2015 01:34 PM
220k+ A32
25
Oct 3, 2015 09:09 PM
