S/C or Turbo'd max with 142,000 miles
Old Aug 18, 2005 | 05:48 AM
jaemax's Avatar
fellas, I am looking into gaining some more hp with either a turbo kit or S/C and I need to know if it will be worth it to drop either one on my car which has 142,000 and growing? What are some of the things that I should consider before going this route? Compression would be one of them anything else that I should consider? Your help is greatly appreciated.
BTW - the max is a 97 5spd....
Jae
Old Aug 18, 2005 | 06:08 AM
JustMaxin96's Avatar
Just so you know I have 200,000 miles on my SC 96. No problems at all. Check the compression and if its good then boost it.
Old Aug 18, 2005 | 08:01 AM
JAY25's Avatar
Jae
With that many miles your water pump is one of the things that will go out. WHen you install that new clutch check that rear main seal to see if its leaking. If it is replace both front and rear upper oil pan seals. Ensure you dont have a CEL and it carries over after you boost it.
Old Aug 21, 2005 | 08:41 PM
SpeedCrazie's Avatar
JAY25 is absouletly correct, I have a 1995 with 160k and the water pump began to leak shortly after being boosted.
Old Aug 21, 2005 | 11:31 PM
Drstove's Avatar
96 5-speed S/C'ed with 250K+ miles and no probs what so ever you should be fine
Cotozic
Jun 28, 2017 08:01 PM
02nissmax
Sep 5, 2015 01:50 PM
paulpearl
Sep 2, 2015 07:50 AM
MAXSE5SPD
Aug 23, 2015 12:06 PM
WeetoddA32
Aug 16, 2015 12:45 PM
