Advantages of a: Built VQ35 vs Built VQ30
Old Aug 18, 2005 | 12:18 PM
SpeedCrazie's Avatar
I was just looking at the advantages of building a VQ35 vs building a VQ30.
When I say build I am talking along the lines of Madigrasmax.
Will they both acomplish the same thing, is the power potential better in one application then the other?
Thoughts?
Thanks Guys!
JP
Old Aug 18, 2005 | 12:33 PM
emmas97's Avatar
for more info on vq35's see the all motor forum... i didnt really read mardigras' thread cause im still in awe over his stock internal vq30.... but a lot of vq35 info can be found in the all motor forum
Old Aug 18, 2005 | 12:40 PM
mingo's Avatar
also look into other forums like the 350's and g35's
the advantages of the vq35 over the vq30 is more aftermarket support.
Old Aug 18, 2005 | 01:08 PM
Larrio's Avatar
The Definitive AE Master
advantages of a vq35 over the vq30 in general:
1. displacement
2. lighter components
3. better designed heads
since the vq30 is more stout with a shorter stroke, I guess it can rev higher more safely at super high hp levels. However with the right tuning and a built engine, the vq35 can easily be compensated for that (IMO)
Old Aug 19, 2005 | 12:10 PM
SPiG's Avatar
SomePsychoGuy
If you want to build an engine then I would say go for the VQ35 for the displacement, off the shelf part access, and better heads. Until you start blowing engines from power I say stick with the VQ30 or just put some VQ35 heads on there and lower the compression a bit. The pathfinder heads are supposed to work with the VQ30 oval style IMs.
Old Aug 19, 2005 | 12:16 PM
Nealoc187's Avatar
SLOW
Do the pathfinder heads flow as well as the other VQ35 heads (or at least better than VQ30 heads?)
Old Aug 19, 2005 | 12:41 PM
desertmaxima's Avatar
just do a built vq30 and buy both my rods and pistons lol, j/k. hey did you get the pm i sent ya
Old Aug 20, 2005 | 04:36 PM
SPiG's Avatar
SomePsychoGuy
I really don't know. I know stephenmax has a PF engine that he is taking apart so he would be the only one I know of that could really look at them and comment.
http://forums.maxima.org/showthread....thfinder+heads
James92SE
142
Jan 2, 2024 09:23 AM
mclasser
22
Nov 12, 2020 01:58 PM
trsandrew
Apr 8, 2016 06:45 PM
trsandrew
Oct 25, 2015 02:47 PM
Max Nu-BE
Sep 28, 2015 10:25 AM
