Any 5th gens with BLUE eManage timing harness?
Old Aug 29, 2005 | 01:54 PM
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
If so, did you have a P1320 ignition misfire code?
Old Aug 30, 2005 | 04:11 PM
IceY2K1's Avatar
Okay...found out studman and BigDogJonx both have/had it. Worked fine for studman, but caused a P1320 pending code for BigDogJonx.
Any others? pimpjuice, HNDA ETR maybe?
Old Aug 30, 2005 | 04:43 PM
pimpjuice's Avatar
No codes here
Old Aug 30, 2005 | 04:46 PM
IceY2K1's Avatar
That's two 5.5gens with no code and two 5.0gens with...what the hell.
Thanks for the input.
Old Aug 30, 2005 | 06:53 PM
choray911's Avatar
The Crazy Azz Cracka
I'm getting a misfire code with a 4th gen, is there any trick to fix it. I was going to post a new thread but why waste the space.
Old Aug 30, 2005 | 07:31 PM
IceY2K1's Avatar
Per John@J&S, you should do two things that *MAY* help:
1)Use a ground directly from the battery negative terminal vs. just tapping the ECUs.
2)Put a 300-ohm 1/4-watt resistor on EACH ignition channel output from the stock ECU(input to emanage) to ground.
Old Sep 1, 2005 | 08:09 PM
choray911's Avatar
I'm using the updated software with no diodes, will that make a difference? I'll give it a wheral in the next few days and see what happens. Thanks Ice!
Choray
Old Sep 1, 2005 | 09:03 PM
IceY2K1's Avatar
NO, the diodes purpose is to drop the voltage OUT of the emanage to the coils to prevent them from overheating.
The 300-470 ohm resistors are on the INPUT to the emanage to keep the factory ECU from thinking the coil isn't there.
I'll let you know this weekend if it works hopefully.
Old Sep 9, 2005 | 03:06 PM
choray911's Avatar
Ice your the man!! Soldered in the resistors and wala, no codes. I was then able to find out that my boost conroler was bad, spiking up to 10psi on a 6psi tune. Took that sucker out and she runs likea scalded dog. I guess no dyno competition for me at NOPI, Oh well. I'll get a profec before Christmas.
Choray
Old Sep 9, 2005 | 04:10 PM
IceY2K1's Avatar
All credit goes to John@J&S.
Just got mine soldered in today also. Will play more tomorrow hopefully.
Old Sep 18, 2005 | 10:55 AM
DandyMax's Avatar
3.5 in the works
Looks good Alex. I'm going to do this on mine now too. I'm repeatedly getting P1320 on my 96 ECU.
Old Sep 18, 2005 | 02:30 PM
slimer's Avatar
A couple of Blaxxx's? Lawls.
yeah, but we still do not have access to the cam/crank signal.
Old Sep 18, 2005 | 03:35 PM
DandyMax's Avatar
3.5 in the works
Greddy's adding it.. we just have to wait unfortunately.
vingodine
45
May 21, 2016 12:46 PM
Finkle
Sep 27, 2015 09:53 PM
doobadoo
Aug 15, 2015 06:43 PM
