Best place to tap lower oil pan?
Old Sep 20, 2005 | 12:27 PM
wunfstmax's Avatar
Getting ready to install my return line. For those of you who have the return line going to the lower oil pan is there a certain spot that is best to drain it thanx.
Lorenzo
Old Sep 20, 2005 | 03:12 PM
stephenlc's Avatar
the higest point on the low oil pan I guess. Theres really no best point I guess
Old Sep 20, 2005 | 04:40 PM
95turbo gxe's Avatar
yeah like spanishrice said you want to be in the highest point so it can drain back into the pan, and where it will suit you best for you kit. DOnt go to low in the pan becasue it will just puddle up. YOu can fully insert the dip stick and check the full level to see where the high point is in the pan
Old Sep 20, 2005 | 09:03 PM
Bags's Avatar
VG Ridah's Biatch Hoe
the lower steel pan?
I don't think this is what your asking for, but here is a thread with some pics just in case.
http://forums.maxima.org/showthread....hlight=oil+pan
Old Sep 20, 2005 | 10:36 PM
wunfstmax's Avatar
So that would be a good spot for the return line to drain to?
Old Sep 20, 2005 | 11:08 PM
96_vqmax's Avatar
Are you talking about the one with the red circle or the HOLE in the middle of the pan?I tap mine in the middle of the upper pan,look next to the O2 sensor.
Old Sep 20, 2005 | 11:10 PM
wunfstmax's Avatar
Old Sep 20, 2005 | 11:23 PM
jcy98maxse's Avatar
Turbo is too much fun!
Thats where the ac compressor is so if you're not running ac, that would be a good spot.
Old Sep 20, 2005 | 11:27 PM
mingo's Avatar
that would be a great place to tap if you don't want to run your a/c anymore.. then you can just drop the steel pan and let the shavings fall out the bottom. that way you don't need to remove the upper pan.
Old Sep 20, 2005 | 11:34 PM
jcy98maxse's Avatar
Mingo, are you gonna do that L fitting inside the lower oil pan like you said? I really dont want to drop the upper oil pan so if your plan works thats what I may do.
Old Sep 21, 2005 | 12:36 AM
mad-max98's Avatar
if you do the L shape thing you gonna have to force engine oil upward for whatever length it's gonna be so i'm not sure if this is gonna be of any benefits to your setup
Old Sep 21, 2005 | 08:18 AM
mingo's Avatar
no i'm not going to do that anymore. i'm going to tap the upper oil pan
kjlouis
Oct 3, 2015 05:29 AM
The Wizard
24
Oct 1, 2015 08:47 PM
dcam0326
Sep 18, 2015 04:52 PM
tardrex
Sep 11, 2015 07:35 PM
sdotcarter
Sep 2, 2015 09:53 PM
