sc on 2001 auto max
Old Sep 27, 2005 | 12:04 PM
2001semax's Avatar
sc on 2001 auto max
I got one question for the Sc guys. If i get the stillen SC and bolted it to my 01 auto and left it at base boost which is i believe 7psi. woould i be able to leave the rest of the car stock and not have to worry about having any problems..
i have 55K miles on my car...
Old Sep 27, 2005 | 01:04 PM
BlackCat's Avatar
RIP '98 Maxima SE
You'll need the vb mod done to preserve the auto tranny. Level 10 I believe is the product. Also you'll need an auto tranny oil cooler like the B&M Supercooler.
Old Sep 27, 2005 | 02:40 PM
Snowy's Avatar
Even at 7psi you should worry about your AFR. I would at least get a FPR off ebay or something.
Better to be safe.
Old Sep 27, 2005 | 04:25 PM
slimer's Avatar
A couple of Blaxxx's? Lawls.
I've heard some horror stories about Level 10, Max tuning and Don's VB mods. Personally, I have mine done by Jeff at Maximum Tuning in Glen Cove, LI.
Tranny Cooler is a great suggestion.
Did you put the whole kit in? If so, the fmu and t-rex pump should be fine for your fueling, but make sure your Hobb's switch is wired in correctly. Mine wasn't at first and was causing a way lean situation.
Old Sep 27, 2005 | 05:19 PM
2001semax's Avatar
Better to be safe.
What is a FPR???
What is a hobbs switch???
Sorry for the dumb questions
Old Sep 27, 2005 | 08:16 PM
slimer's Avatar
Originally Posted by 2001semax
What is a FPR???
No problem. Sorry, some of use get used to using the abbreviations.
An FPR is actually an AFPR, an Adjustable Fuel Pressure Regulator. It allows you to bump or drop fuel pressure. If you are running the stock setup, you will not have to worry about that.
The Hobb's switch is what activates the t-rex (auxillary) fuel pump. When it sees pressure, it turns the pump on so you won't go lean. Your stock pump does not flow enough to supply enough fuel under boosting.
Old Sep 27, 2005 | 08:29 PM
Snowy's Avatar
You can actually get some FPR's to add more fuel based on how many pounds of boost your are pushing automatically. So for instance, for every pound of boost you run it will add x fuel to the mixture.
Old Sep 27, 2005 | 08:41 PM
slimer's Avatar
That is a rising rate fuel pressure regualtor, commonly known as an fmu.
Old Sep 27, 2005 | 08:48 PM
Snowy's Avatar
Yes sir!
Old Sep 28, 2005 | 01:17 PM
2001semax's Avatar
so all in all i will need:
1.vb mod
2.hobbs switch
is that it.
is everything else included in the kit.
thanks everyone for the info
ps are the engine internals strong enough to handle the SC.
do i have to do anything to override the ECU...Like get a SAFCII or the greddy e-m,anage? or is that just simply going overboard....
rememeber i am not gonna adjust it once its dialed in . im keeping it at stock boost for now
thanks
Old Sep 28, 2005 | 01:26 PM
slimer's Avatar
The hobbs switch should be included with the kit. If its used, its that big jumble of wires.
conansriver
Nov 18, 2015 02:46 PM
QueensMAX
Sep 15, 2015 04:14 AM
conansriver
Sep 11, 2015 10:26 AM
Lowered_a33
Sep 10, 2015 09:41 PM
mikebla
Sep 3, 2015 05:37 PM
