please help tune , post your afr egt and psi thnx
Old Oct 3, 2005 | 05:24 PM
mad-max98's Avatar
i won't have a wide band for a while and i need to make sure my car is safe on 8 psi till my wide band get here,,, i'm running t3 to4,emanage,550cc injectors and z32 maf,also i have boost,egt and afr gauge and since egt and afr are kind of related it would help to know yours since it's already tuned
Old Oct 4, 2005 | 06:19 AM
mad-max98's Avatar
bump,,,,,,,,,,,com'on guys
Old Oct 4, 2005 | 07:13 AM
maxgtr2000's Avatar
KH3 by popular demand
You know the boosted community is sworn to secrecy on where to get certain parts and their running set ups.
Old Oct 4, 2005 | 10:53 AM
mtrai760's Avatar
'Trynna' is not a word
Its not that... Cars vary so widely, its highly doubtful and very dangerous to just take another persons settings and try to run your car. Good way to ensure you spend a lot more money...
Old Oct 4, 2005 | 11:16 AM
I30tMikeD's Avatar
I would stay out of full boost till you know your AFR's are safe. It is not worth it to boost for the next few weeks, or when ever your WB will be in, and risk things.
Old Oct 4, 2005 | 04:19 PM
mad-max98's Avatar
i know the risk i'm taking!!! thnx for making sure though however that's not what i needed !!! i need numbers please if you can provide that i'll be grateful thnx........
Old Oct 4, 2005 | 04:41 PM
Nealoc187's Avatar
SLOW
Most people don't tune via EGT anymore, it's really sortof gone the way of the dodo. I doubt many if any people have both EGT and wideband on their turbo setup.
Old Oct 4, 2005 | 05:27 PM
mtrai760's Avatar
I did not use an EGT to tune, just my wideband. Tuned to 11.5 to be on the safe side. You NEED a wideband to tune. No other way around it.
Old Oct 5, 2005 | 04:30 AM
Boosted Maxima's Avatar
Wide bands are cheap anymore...around 300.00. Innovate or similar. I ran at the track 10.2-10.4 wot @ 12psi. I'm now down to 11.4-11.7wot. One, makes more power and two gas prices suck!!!! At cruze speed it's 14.7-15.1 and part throttle 13.5 (accelleration) Borrow someone's if you can!!! it's good insurance on not hurting the engine. I don't have EGT.
Old Oct 5, 2005 | 11:55 AM
hlh0501's Avatar
Do not try to use EGT for tuning AF. Timing will throw EGT waay up or down!
If you don't have a wideband available, put it on a dyno and use theirs. Remember to start from rich and slowly lean it out to where you want it (I'd suggest 11.5ish). While you are there, tune timing. I am not sure how consistent it would stay with emanage only modifying the timing... so maybe find MBT and back it off a few degrees to give a buffer incase variables change.
Old Oct 6, 2005 | 01:04 AM
mad-max98's Avatar
i don't have access to a dyno or a wideband but i get the idea thnx guys my best bet will be gtech pro i guess j/k
litch
123
Jan 4, 2024 07:01 PM
aw11power
Oct 10, 2021 04:57 AM
09maxshawn11
Sep 30, 2015 10:28 AM
MichMaxFan
Sep 30, 2015 09:18 AM
Socalstillen
Sep 26, 2015 12:01 PM
