Another turbo car bites the dust!
Old Oct 9, 2005 | 08:38 AM
choray911's Avatar
The Crazy Azz Cracka
I got hosed! Yesterday I hear a funny sound comming from the timing chain end of the block and there are small aluminium shavings every where. Come to find out the timing ring on the back side of my RVM under drive pully had come loose and was milling out the lower oil pan. Last night while I was trying to limp the POS home the timing ring cut through a oil jacket, or I assume thats what happened, its tight in there. She starts to cough and sputter as I'm going across the dam and I leave a trail of oil a mile long. It will be a few days before I get to tear it apart to see what happened, every boy pray for the best.
Any one got a spare upper pan laying around?
Choray
Old Oct 9, 2005 | 09:19 AM
slimer's Avatar
A couple of Blaxxx's? Lawls.
That sucks. I may have one if I can get some help getting Mike's engine home today.
I thought a lot of people had problems with the RVM pulley.
A side note, I just picked up an underdrive pulley that I do not need. I was going to do some S/C testing with it, but if you need it, I'll sell it to you.
Steve
Old Oct 9, 2005 | 09:53 AM
Nealoc187's Avatar
SLOW
Yeah I think there is a sticky in the 4th gen forum about not using the RVM UDP. Sucks man. But you can get it back up and running.
Old Oct 9, 2005 | 10:33 AM
liqidvenom's Avatar
brotherhood of tq
i think i saw a upper pan on ebay for sale real cheap
Old Oct 9, 2005 | 02:33 PM
turbomax97's Avatar
I couldn't fix your brakes, so I made your horn louder
I've got 2 spares... I'll let it go cheap, shoot me an offer.
Old Oct 9, 2005 | 04:35 PM
Bags's Avatar
VG Ridah's Biatch Hoe
take turbomax up......
and I have 1 as well
sory about the bad luck
Old Oct 9, 2005 | 09:43 PM
95turbo gxe's Avatar
sorry to hear that now pick up the peiece and get that puppy back to blowing off again.
Old Oct 9, 2005 | 10:06 PM
I30tMikeD's Avatar
Sucks, sorry man. My car is down for a while as well, tranny problems
Old Oct 10, 2005 | 09:34 PM
maxgtr2000's Avatar
KH3 by popular demand
Maaan Choray, I guess it could be worst, I hope it's not too bad after you fix the oil pan situation. I'm just up the street in Knoxville, holla at me if you need major help.
Old Oct 11, 2005 | 01:21 AM
chinaonnitrous1's Avatar
Man..unorthodox pullies
Old Oct 11, 2005 | 07:25 AM
choray911's Avatar
I'l take you up on that offer turbo! As soon as I pull the pully off, I'll hit you up. Hopefully none of the timing was off, when I was in boost. She is sputtering a lot, there is a chance I could have burned another valve. Right now I'm too disscusted to work on it, that and midterms coming up.
Thanks for the offers fellas.
Choray
Old Oct 11, 2005 | 04:09 PM
choray911's Avatar
have you guys ever heard of a rod snaping? I'm debating on weither or not to change out the rods or just the pistons. Import performance parts has a rebuild kit with pistons but no rods. The goal was only 400 and I know that the fac rods can take the stress, but if I have to rebuild may as well do it to the extreme.
Old Oct 11, 2005 | 04:28 PM
Nealoc187's Avatar
SLOW
Never heard of breaking a rod on a VQ. The main failure points from power on the VQ that I've seen have been headgasket first and foremost, also ring lands and main bearings (main bearings on VQ35).
From RPM (overreving) I've heard of rod bolts stretching and of valve/piston contact.
Old Oct 11, 2005 | 06:34 PM
Boosted Maxima's Avatar
Sorry to hear that... hope for a speedy recovery for your wounded Max...
Sounds like everyone here's ready to back you up with help and parts.
~Scott
Old Oct 11, 2005 | 08:03 PM
slimer's Avatar
I blew up my VE.
Old Oct 12, 2005 | 05:01 AM
choray911's Avatar
Originally Posted by slimer
I blew up my VE.
I didn't know you had a ve. Was that recently or in the past?
Choray
Old Oct 12, 2005 | 07:43 AM
slimer's Avatar
It was my last car, blew the engine once and the tranny more than I can count. Stupid 94 Auto.
Old Oct 15, 2005 | 08:37 AM
choray911's Avatar
Well I was right and I was wrong! Got some time to pull the pully off and low and behold 2 screws that hold on the timing ring on the back of the under drive pully had backd out. Rather than cutting a hole in the lower oil pan, I milled out the timing chain cover, which would explain the coughing and sputtering when she died. luckally I just so happen to have a spare in the attic. Time was short so I didn't get a chance to pull the chain cover, I'm shooting for monday on that one.
Old Oct 15, 2005 | 08:58 AM
Matt93SE's Avatar
STFU n00b!
sounds like you (sorta) dodged a bullet! good luck getting it fixed!
would probably be a real good idea to pull the oil pan and pickup tube and make sure everything is flushed out.. good chance you got some aluminum shavings in there.
MikesChevelle
Nov 23, 2024 11:17 AM
Lakersallday24
Jun 16, 2019 01:35 AM
MAXSE5SPD
Aug 23, 2015 12:06 PM
Balkins
Aug 12, 2015 06:39 AM
FanaticMadMax
Aug 10, 2015 08:55 PM
