Need Help With Sputtering
Old Oct 11, 2005 | 04:22 PM
*FleXIMA*'s Avatar
I am havin sputtering problems under WOT. sputters like crazy. Can anyone think of wa else i can do inorder to get rid of the problem?
Old Oct 11, 2005 | 04:37 PM
Nealoc187's Avatar
SLOW
lol good description of the problem...
Old Oct 11, 2005 | 05:21 PM
gtr_rider's Avatar
192.168.1.1
good one
Old Oct 12, 2005 | 09:45 AM
*FleXIMA*'s Avatar
The car sputters under WOT.... like crazy doesnt let it go further.... it starts at about 4k... right around boost area. I tried lowerin the fmu disk to a 8:1, i got a SAFC2 and tuned the fuel down a little... any ideas on y its doin that or how i can fix it?
Old Oct 12, 2005 | 10:16 AM
SonicDust187's Avatar
Put it on a dyno man.
Old Oct 12, 2005 | 11:42 AM
Nealoc187's Avatar
SLOW
See if you can get a video of the problem. It sortof sounds like bad coilpacks. But it could be something weird happening with timing or fuel.
Old Oct 12, 2005 | 02:26 PM
*FleXIMA*'s Avatar
well tilley looked at it and said it wasnt the coilpacks
Old Oct 12, 2005 | 03:15 PM
Nealoc187's Avatar
SLOW
Well then it's probably timing or fuel related. Need more info to tell I guess. You don't have a wideband do you?
Old Oct 13, 2005 | 11:51 AM
*FleXIMA*'s Avatar
no gettin dynoed the 18th
Old Oct 13, 2005 | 12:45 PM
slimer's Avatar
A couple of Blaxxx's? Lawls.
Sounds lean. I had that problem when my hobbs switch wasn't turning on.
Old Oct 13, 2005 | 04:45 PM
choray911's Avatar
The Crazy Azz Cracka
what spark plugs are you running. If they are too cold it will act up around 4000 to 4500 at wot.
Old Oct 14, 2005 | 09:44 AM
*FleXIMA*'s Avatar
one step colder plugs......
Old Oct 18, 2005 | 08:42 AM
TILLEYS99's Avatar
Lives in a 11sec maxima
I think your car is possesed. Do you have any check engine lights? I think you should make a drive down here again and we can play around with it.
Old Oct 18, 2005 | 11:48 AM
*FleXIMA*'s Avatar
yeah tilley maybe i should. thats funny u posted at 1142 and i called u at 1:05. hahah very funny
Old Oct 18, 2005 | 03:00 PM
Morfeus17's Avatar
Check your plugs! Perhaps the gapping is off? Under-boost you may be outting the spark. What plugs are you using? What is your gapping? Also, check to see if your plugs are fully seated in the head. Loose plugs can cause this problem too.
Old Oct 19, 2005 | 07:41 AM
vortechpower's Avatar
Sorry for the thread jack... Im getting alot of hesitation on acceleration/ max feels really slugish/cant even break traction. Still gets 10psi. Pulled code for knock sensor, would knock sensor cause this? Also getting rattling from time chain .... thanks
Drunk Uncle
Apr 5, 2003 03:59 PM
blakkrob
Oct 10, 2002 07:47 PM
Jopa416
Sep 20, 2002 12:58 PM
89gle-grey
Aug 15, 2002 02:36 PM
