summit rpm swith / nismo fpr
Old Oct 18, 2005 | 07:02 PM
MaxObesset's Avatar
how do you connect the summit rpm switch to the vacum solenoid on to a 3.5 swap 4th gen and on the nismo fpr which way do you turn to lower the fuel and raise the fuel
Old Oct 18, 2005 | 08:20 PM
JAY25's Avatar
For the RPM switch what I did was connected a positive on the vacuum solenoid. The Summit will send a ground to the switch which will make it open. Use the ground.
I got the tip from one of these electronical engineers here on the .org
Old Oct 19, 2005 | 03:48 AM
Jime's Avatar
Screwing clockwise usually increases pressure on fpr's, but the easiest way to check is to turn it either way while watching your pressure gauge.
Old Oct 20, 2005 | 06:27 AM
MaxObesset's Avatar
i adjusted the fpr alil better than before know just need tp get a write up on how to install the summit rpm switch
05RLS2
Apr 14, 2016 11:49 AM
Unclejunebug
Apr 2, 2016 05:42 AM
ef9
Oct 4, 2015 08:43 AM
Need help
23
Oct 2, 2015 08:56 AM
