ARP torque specs
Old Nov 2, 2005 | 01:08 AM
Turbo95Max's Avatar
Turtle turtle... Moderator
ARP torque specs
so does anyone kno what the torque specs are for ARP studs on a VQ30? please specify with or without moly. i also got connecting rods with ARP fastners on them. Does anyone kno the spec for that?? putting my car back together...heeh. thanks!
Old Nov 2, 2005 | 06:17 AM
stephenlc's Avatar
they have arp fastners for the VQ30 rods?
Old Nov 2, 2005 | 11:27 AM
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
You sure the connecting rod fasteners are not for VQ35 rods? Do they have a nut for each bolt?
Old Nov 2, 2005 | 12:22 PM
Y2KevSE's Avatar
Rice Boy in Denial =)
Not sure about specs on VQ but the torque specs for the ARP head studs will be different than factory specs. The Evo guys do 85 ft.-lbs. with oil and 65 ft.-lbs. with moly (some even do 85 ft.-lbs. with moly to prevent head gasket leaks). I'll be using 85 with moly when I do mine within a couple days.
The instructions will tell you how much to torque.
Old Nov 2, 2005 | 12:24 PM
Y2KevSE's Avatar
That's 85 on the nut... not the actual stud. The stud should be hand tight (no torque spec).
Old Nov 2, 2005 | 12:36 PM
Turbo95Max's Avatar
uhmmm....their not stock rods.
for the head stud kit. SGP says to follow the factory method of torquing down the heads, but i rmemeber ARP gave me some number with and without moly and it was different from the FSM...i am lost again.
Old Nov 2, 2005 | 12:38 PM
Turbo95Max's Avatar
cool....that number sounds about right...hahah
if the Evo studs are the same size then the torque spec is the same too, cause i remmeber calling up ARP and i needed to measure the stud diameter for the correct torque..didnt matter on what application it was being used on.
Old Nov 2, 2005 | 12:40 PM
Y2KevSE's Avatar
190,000 psi... 7/16-inch diameter. Same for the VQ?
Old Nov 2, 2005 | 01:21 PM
Turbo95Max's Avatar
i dunno i need to check, but then if i did check, then i could call ARP for the specs too......heeh
Old Nov 2, 2005 | 01:25 PM
Y2KevSE's Avatar
j00 = lazy hehe
Call them.
Old Nov 2, 2005 | 02:50 PM
MardiGrasMax's Avatar
Use the ARP Lube.
Old Nov 2, 2005 | 03:51 PM
Turbo95Max's Avatar
Originally Posted by MardiGrasMax
Use the ARP Lube.
Matt
you kno these torque specs? i think your holding out on me!! haha. so how much does this ARP lube cost? thanks
Old Nov 2, 2005 | 05:22 PM
I paid like $7 at a local speed shop for a tube. Honestly I dont recall. Search the My350z.com you might find them their. Or try SGP in Houston, ask for Kyle.
Old Nov 2, 2005 | 05:43 PM
Y2KevSE's Avatar
You should have gotten a packet of ARP lube with the head studs.
Old Nov 2, 2005 | 07:08 PM
Turbo95Max's Avatar
i got those long time ago when i got the kit, im reusing it again...i dont rmemeber what i used.
Old Nov 2, 2005 | 07:15 PM
Y2KevSE's Avatar
Ohhh... gotcha.
Old Nov 2, 2005 | 11:31 PM
alexnissan2000's Avatar
Whats the max horse power on your maxima
Old Nov 3, 2005 | 04:50 PM
Turbo95Max's Avatar
ok so i got some a ss lube and lubed those boys up good today. torqued down the heads, but now i cant figure out the torque spec for the connecting rod caps. FSM says 15ft lb and turn 90 degrees, but that was for the factory torque to yield bolts...ugh i dont even rmemeber the brand of rods i got...
Old Nov 3, 2005 | 07:30 PM
jdmmax's Avatar
uhhhhh matthel are you sure you know what you are doing?????
Old Nov 4, 2005 | 01:16 AM
Y2KevSE's Avatar
Motor go BOOM! hehe
Old Nov 4, 2005 | 09:32 AM
desertmaxima's Avatar
Uh oh mad scientists at work on this thread. Watch out cause a monster can be born from all this smoke and dust
Old Nov 4, 2005 | 09:58 AM
Royal_T's Avatar
Kyle does not work there any more. You should ask for Shawnn or Mark they know there stuff.
James92SE
142
Jan 2, 2024 09:23 AM
jmlee44
Oct 2, 2022 02:13 PM
Quickywd01
Sep 21, 2016 09:36 PM
The Wizard
24
Oct 1, 2015 08:47 PM
