V2 noisy?
Old Nov 10, 2005 | 09:43 PM
blarg's Avatar
Blah + Arg = Blarg
V2 noisy?
I compared my car to another SCed member. Both cars parked side by side and during idle my V2 is much louder than his. Loud in terms of idle whine. Any ideas?
Old Nov 11, 2005 | 10:19 AM
BlackCat's Avatar
RIP '98 Maxima SE
Are you getting the rattling marbles-in-a-can noise?
Old Nov 11, 2005 | 10:50 AM
blarg's Avatar
Blah + Arg = Blarg
Nope, no marbles-in-the-can type of sound. I guess the I could say it sounds as loud a v-1. However, I do notice a scratching sound. Very faint and rarely do I hear it.
Old Nov 14, 2005 | 08:35 AM
BlackCat's Avatar
RIP '98 Maxima SE
I would loosen your drive belt and check if the pulley is loose, just to rule that out. A loose pulley will generate the rattling marbles in a can noise.
Old Nov 14, 2005 | 09:22 AM
linuxr's Avatar
Is this V2 SC a new one or a used one? Because when I first installed my SC it was Loud as heck until it broke in and now its nice and quite (took about 500-600 miles before it started getting better).
Old Nov 14, 2005 | 10:17 AM
blarg's Avatar
Blah + Arg = Blarg
BlackCat - I will give your suggestion a shot and will check under the hood this weekend.
Linuxr - It's relatively a new kit. I bought it off of somebody who ended up selling his max and never installed the kit. The kit was still in it's original packaging. However, I put about 1000+ miles on it already.
I will try to post a clip tonight of what it sounds like. Maybe I might be missing something that maybe you guys can hear.
Old Nov 14, 2005 | 02:34 PM
VQ30DENX_SC's Avatar
blarg compared to mine (shhhhh!! its me) lol, and it sounds like a v1 compared to mine....mine has about 15k on it, fairly broken in....by the way, i started getting that marble in a can noise at idle, the metal sleeve came out of the air filter and started clanking against the fins and i shut off and put it back on and its not as much, but its still there, could that make my pulley loose? and i only hear it at idle, can u actually SEE the pulley shake or something when its loose? HELP, sorry to hijack blarg, but we are friends so im allowed to, lol....
Old Nov 14, 2005 | 03:30 PM
blarg's Avatar
Blah + Arg = Blarg
It's all good. My SC setup is new so any info is appreciated.
Old Nov 14, 2005 | 08:23 PM
blarg's Avatar
Blah + Arg = Blarg
I took a clip of my SC during idle.
http://media.putfile.com/SC6534
Old Nov 15, 2005 | 01:10 PM
Originally Posted by blarg
I took a clip of my SC during idle. Let me know if there's any problems downloading the clip.
****WARNING: Since this is a free file host expect to encounter some pop-ups****
http://www.filefactory.com/get/f.php...4c0dfc3263c008
...and my v2 which is what he was talking about....
thanks digital for hosting it....
http://www.lavene.net/digital/nycmax...eo/VID0032.AVI
Old Nov 15, 2005 | 01:13 PM
except now i have that marbles in a can noise and my pulley feels very tight and firm when i try to shake it loose so i still dont know wut the issue is....i guess i just need a rebuild??
Old Nov 16, 2005 | 11:06 AM
BlackCat's Avatar
RIP '98 Maxima SE
After loosening the belt, the pulley should be nice and tight by hand. If there is any play (ie. slides back and forth on the spindle towards the engine block) then the pulley is loose. If thats not a problem then the V2 needs a rebuild soon. Costs about $350US.
Old Nov 16, 2005 | 02:22 PM
blarg's Avatar
Blah + Arg = Blarg
I changed the hosting location of the video file since I think it might've discouraged people with the popups.
This should play straight into the browser. Any feedback would be appreciated.
Old Nov 17, 2005 | 08:36 AM
thanks, whats the process for that? you've done it before right??
Old Nov 17, 2005 | 09:33 AM
BlackCat's Avatar
RIP '98 Maxima SE
Actually, its not the dreaded marbles-in-a-can noise at all but it sure sounds more like a V1 to me. Does the tag on the blower actually has V2 stamped on it?
Old Nov 17, 2005 | 09:38 AM
BlackCat's Avatar
RIP '98 Maxima SE
Oh yeah...a couple of times already because I haven't torqued the retaining bolt on the drive pulley enough. If the bolt holding the drive pulley comes loose the pulley will loosen too and becomes a bit unbalanced which results in that awful marbles-in-a-can noise.
Last time I fixed the problem I noticed that little square peg that fits into that slot between the spindle and the drive pulley is getting worn and isn't square like it used to be. Its supposed to keep things snug fitting. Has anyone experienced the same problem?
Old Nov 17, 2005 | 01:22 PM
mine is still squared, and even worse, its sturdy and making the noise, i think ure right....
the metal sleeve on the airfilter came loose and the fins were chopping it up...had a few metal shavings in there....now i fixed it and its still making the noise...i blame the installer for this....but whatever....
and yes his blower clearly said v2 on it.... mine u can barely hear (before this marble in the can crap), but his sounds clearly supercharged....
Old Nov 17, 2005 | 10:11 PM
blarg's Avatar
Blah + Arg = Blarg
Yeah, the tag has V-2 on it. If you look really close you can faintly see it.
Old Dec 6, 2005 | 06:00 PM
ewuzh's Avatar
Did this ever get resolved? Mine is starting to get loud like that too...
Old Dec 7, 2005 | 12:15 AM
maybe ures s finally broken in? or check ure oil also!
Old Dec 12, 2005 | 01:07 PM
vortechpower's Avatar
The little metal peice you refer to is called a "key". I have had my pulley come loose more than once. Most recently it has come extremely loose on a 600 mile road trip. I had the blower rebuilt at 98k and it has only 14k on it now. I am hoping the bolt or the key had came loose and that I dont need a rebuild. If I need a rebuild I will feel very ripped off by vortech seeing how I only got 14k out of this one! I have not taken the time to look at it since I took it off since the last allen bolt I went to take of broke the tip of the wrench off in it.... Your blower sounds like the pulley may be coming loose. It is hard to tell when the belt is tight against the pulley. It all starts with a small amount of play and get worse and worse.
Old Dec 12, 2005 | 01:27 PM
Stephen Max's Avatar
Sounds like a V1 to me, too.
Old Dec 12, 2005 | 01:40 PM
mine still sounds like SHYT, it used to sound good, now its leaking a bit of oil ,so that confirms its rebuild time, fins look good....guess its the inards...
Old Dec 13, 2005 | 07:25 AM
C MAX's Avatar
im having the same problem too. its wierd i got the s/c back after a rebuild and it ran fine, then my waterpump started to leak so i had to take it off to change it and when i put the s/c back on all i hear is a can of marbles at idle only. i called vortech and they said as long as it stops after 1,000rpm its normal and if i decide to send it back they wont fix it unless its a actuall bearing problem. my thing is it purred like a kitten until i took it back off and then walah marbles noise. at the first start up its quiet but once it warms up it makes the noise. its too cold now to try and mess with it but its driving me nuts.
Old Dec 13, 2005 | 07:41 AM
Chunger's Avatar
My other car is a Hybrid
Couple of notes from my almost 5 years with the SC:
The pulley should only be tight in relations to the shaft. Pulley should spin the impeller by hand with a little effort.
Some V2s are louder than others (probably with age but mine is still pretty quiet though i don't put many miles on it a year).
Try a few drops of oil on the shaft between the pulley and the S/C body. This has quieted down some idle noise for me a few times, though someone else said it didn't work for him.
Old Dec 13, 2005 | 11:38 AM
maybe this will work for blarg, but if i rest my hand on the SC i feel it knock and kick while its running...its so agonizing....i was able to pull up in front of a bunch of ppl and they heard NOTHING....now its all clunking and shyt, everytime i read this thread it reminds me of my previous stealth status.... but then after 1,000rpm it is gone though....but at a light i feel like sitting in neutral with my foot on the gas revving up to 1,000rpm...this bites....
JoeWhit
Sep 20, 2015 08:01 PM
1Phat Max
Jan 11, 2002 06:38 AM
IBBallN3
29
Nov 18, 2001 06:27 PM
